Flat Pack Birdcage
186
Posted in HomePets
Introduction: Flat Pack Birdcage
Hi, My name is Manou Storms. I am studying industrial product design on Howest in Kortrijk, Belgium.
We had an assignment to make something flat packed. I've chosen to make a birdcage flat packed.
If you want to make it your own, follow my steps!
Enjoy
Step 1: Materials
Materials:
-illustrator document or a spiral in plexi
-strong thread (visdraad)
-crimp beats (+tongs)
-magnetic clasp
-sandpaper for birds
-pliable transparent plastic
-glue
-clips
-a thick wire
Step 2: Lasercutten
If you want to make it like I did, you have to cute this file out. I made an illustrator file, so you can cut it with a lasercutter.
Step 3: Determinable Fixed Location Between the Ribs
Throughout a strong thread and crimp beads you can determine fixed locations between the ribs of the spiral.
1.put the thread through the hole
2.put on the thread a crimp bead
3.squint the pearl
On the 10th rib you have to put a magnetic clasp beetween the ribs.
Step 4: The Bottem
To make the bottem, you need your bottem sheet, glue and flexible plastic.
1.You have to cut it like the picture
2.you have to bend the smal parts
3. You Have to glue the biggest parts on the bottom circle
4. Glue the smal parts on the outer circle
Step 5: Hanging System
You want your cage to hang zo you need to make a hanging system.
I made it from a wire.
You can bend the upper part like a coat hanger. The bottem part like you can see on the picture.
Step 6: Attach Bottem to Cage
You can use some clips to attach the bottem to the cage.
Step 7: Decoration
You can use some branches where your bird can sit on. The troughs you can choose by yourself.
Step 8: Your Cage Is Ready!
Et Voila, your cage is ready! Enjoy!
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    Just don't flat-pack your bird inside it! ;)
