3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
flat-pack explosive (squib)
This is a small electrically triggered flat pack explosive. Commonly called a "squib", it is often used in stage and film to trigger various special effects.
*** WARNINGS:***
  • THIS INSTRUCTABLE INVOLVES HAZARDOUS MATERIALS.
  • OXIDATION HAZARD.
  • EXPLOSION HAZARD.
  • YOU CAN HURT YOURSELF.
  • NOT FOR CHILDREN.
  • FOLLOW DIRECTIONS CAREFULLY, AND USE COMMON SENSE.
Step 1Gather materials
gather materials
Materials you will need:
  • nichrome wire (for igniter). Failing this, you can use some thin (30 AWG) copper wire
  • medium gauge (16 AWG or so) insulated wire (stranded), for trigger wires
  • normal bond paper
  • cellophane tape
  • aluminum power
  • potassium perchlorate
Tools you will need:
  • wirecutters
  • wire strippers
  • a small scale (capable of weighing small numbers of grams accurately)
  • a metal cylindrical roller
  • an anti-static computer bag
77 comments
1-40 of 77next »
Oct 8, 2011. 11:04 AMSD_cyborg says:
Can there be a lower scale substitute for this?
Where i can use a 9V battery.. ( making it portable :D)
and maybe replace the flash powder too?
Nov 4, 2011. 1:23 PMVadimS says:
You can use thin steel wire (much better then copper) for the igniter, a 9v battery should do the trick.
Dec 19, 2009. 4:20 AMlop145 says:
4x4 centimeter or inch?
Nov 4, 2011. 1:20 PMVadimS says:
" means inch
Aug 14, 2011. 8:05 PMjweaks says:
Gracious sakes! Don't plug into house current! Use a battery.
Jul 29, 2008. 5:31 PMszechuan53 says:
i'm 14. teenager, not child, w00t!
but seriously, i can handle this. i am willing to bet that i am the only one of my age interested in purchasing xenon diflouride and knows where to get it. i can handle a squib.
Dec 28, 2010. 7:26 PMPerfectPantaloons says:
i mix all my own explosives and i'm only 14, i can handles squibs too... PYROS UNITE!!!!!
Oct 9, 2009. 8:36 PMdla888 says:
Don't be too cocky.
A gunpowder squid you could handle but a flashpowder squib shouldn't even be made. A pile of flash powder will go boom, but you gotta put gunpowder in a case to make it go boom.
Oct 30, 2008. 2:07 AMArchive555 says:
I'm 14, and I too am interested in purchasing it ;)
Nov 8, 2008. 7:05 PMszechuan53 says:
umm... do you even know what it is?
Sep 4, 2008. 3:04 PMKataze says:
You'd be surprised, man.
Sep 3, 2008. 4:41 PMTombini says:
What would you want it for? Fluridation? Anyway Sulfur Hexafluride (SH6) is much more fun 6 times as dense as air and safe for the lungs
May 13, 2009. 8:32 PMnutsandbolts_64 says:
uhh excuse me, safe for the lungs?
now helium being lighter than air and inhaled makes your voice sound squeaky
Now think about sulfur hexafluoride being much dense, your voice will be deeper
and don't try it at home like what the mythbusters did ( usally its adam )
he said it "don't try it at home"
and may I remind you that your lungs need oxygen not SH6
plus SH6 is very reactive.
May 15, 2009. 12:37 AMTombini says:
SH6 may be reactive, if it actually existed...
Sulfides -2 charge and Hydrogen +1 (-1 in some cases)
Therefore; H2S = hydrogen sulfide, rotten egg gas
This is clearly not Sulfur Hexafluride which has a chemical formula of SF6
SF6 is almost completely stable I will use a quote from the wikipedia page on SF6 to prove this ;
"There is virtually no reaction chemistry for SF6. It does not react with molten sodium, but reacts exothermically with lithium."
And may I remind you that breathing in He or SF6 intermittently can be completely safe, the mythbusters only say to not try this at home because of stupid people using it in excess and drowning themselves.
SF6 is not reactive, and is completely safe if you do SOME REASEARCH
May 15, 2009. 6:14 AMnutsandbolts_64 says:
4 words you have a point
six times as dense, about a million more times as expensive. :P
Jan 18, 2009. 2:40 PMekulmeekul says:
i thought air was free? Plus not all 15 yr old teenagers (myself included) have access to a chemical supply or anywhere that will supply them with any sort of bottled gas no matter how harmless. not even oxygen! cmon who doesn't like to see extra oxygen fed to an explosive. Oh i know, the police!
May 11, 2010. 2:29 AMHonestinwilkesbarre says:
Your comments illustrate exactly why it;s illegal to provide such materials to teenagers (in the US). Just because oxygen is all around us, and a gas we need to live, doesn't mean it's harmless. Pure oxygen is highly flammable, and burns with an invisible flame. You could walk right into an oxygen flame and not know what happened to you. It would resemble spontaneous human combustion to anyone observing you. Concentrated oxygen could also have toxic effects.
May 17, 2010. 12:38 AMekulmeekul says:
oxygen on its own is not flammable... you need some sort of fuel, and yes, any flame when supplied with oxygen become almost invisible... so i get that bit, but a huge bubble of pure oxygen? burning? and someone walking into it? get realistic man! i dunno what planet your living on, but where I'm from, there aren't giant pockets of pure oxygen floating around the atmosphere, i hope that helps...
Jun 13, 2010. 7:04 AMHonestinwilkesbarre says:
Hmmm. You must be from a medically backward region. Where I live, those with lung disease sometimes are prescribed oxygen. My father was one of those, and the oxygen (which is pure) was delivered in pressurized green metal cylinders. Pure pressurized oxygen is also used in wielding. So I do live in a world with "packets" of pure oxygen all around us. You are correct, tho', oxygen on it's own does not burn. It needs fuel, and the fuel is what technically burns. Unfortunately, almost everything can be a fuel when oxygen comes into contact with it. Sometimes explosively. Perhaps you've forgotten, or never heard of, Apollo 1.
Sep 9, 2010. 4:50 AMekulmeekul says:
'giant pockets of oxengen floating around the atmosphere'... 'someone walking into it' Took that one out of context didn't you...
Sep 4, 2008. 2:03 PMszechuan53 says:
maybe for an element sample, as most other available forms of xenon aren't very visual. and, yes, i know what sulfur hexaflouride is. i'm crazy, not stupid.
Oct 5, 2006. 3:41 PMFalling_Jihad says:
Were can i obtain some of this aluminum powder and potassium stuff.
May 22, 2009. 4:06 PMThelonelysandwitch says:
this makes flash powder, just open some fire works, and it is premixed.
Dec 19, 2009. 4:15 AMlop145 says:
yeah and just mix it with other powders and accidently blast your hands of.
BAD IDEA.
Dec 19, 2009. 7:26 PMThelonelysandwitch says:
not if you know what your doing
Dec 21, 2009. 7:28 AMlop145 says:
if u mix 2 kinds of gunpowder with each other it proves u dont know what u are doing.
Dec 22, 2009. 12:27 PMThelonelysandwitch says:
no it just prooves that im stupid but im safe when i do things
Dec 27, 2009. 9:26 AMlop145 says:
then how exactly are you safe when you are being stupid?
Dec 28, 2010. 7:24 PMPerfectPantaloons says:
ever heard of a real life paradox???
Jan 29, 2010. 6:57 PMgarrettanderson983 says:
Mixing flash powder in a bag is a smart way to blow your damn hand off!!! that crap is DANGEROUS!!!
Feb 10, 2010. 4:13 PMstruckbyanarrow says:
its an anti static bag flash powder (FP) is ignited by friction, static, and heat, as long as your not heating or hammering the bag you are okay.
Oct 28, 2009. 2:59 PMjam BD says:
He He He Ha HA HA
BOOOM!!
looks good
Does it actually do any damage??
Dec 2, 2009. 3:02 AMKlive says:
it wont do to much on its own but if you use it as a primer for a more volatile mixture (anfo for instance) it can be SUPER EFFECTIVE.
Aug 15, 2009. 9:45 AMcoast2coastcreator says:
For a squib on like a wall or a rock seen from a medium distance, this seems okay, ( except the whole ac power deal... a bit unsafe), but the whole flash powder bit is extremely risky. 1 to 1.5 grams of flash powder is officially a federal offense to produce in your home w/o a license. I beleive the legal limit is .05 of a gram, and that is about the amount that goes into a Black Cat or other similar products. i make a simple FP (Mag/AN) and a gram of that stuff strapped to my chest would be a problem. You could use a mix of 74% Potassium Nitrate, 26% charcoal as a BP formula, use like .05 or less in place of the FP . Check out Indy Mogul for all kinds of good stuff like this
Aug 16, 2009. 11:34 AMLawyerSteve says:
What is a Black Cat? Has anyone tried this recipe on a living person (amounts adjusted for survivability assumed)?
May 14, 2009. 11:43 PMkicker109 says:
just watched the movie is there anyway that that would look like a gunshot? and with less smoke?
Jul 17, 2008. 5:44 PMfrontier says:
just curious i thought primarily gunpowder only exploded if it was in a solid container etc that can withstand some pressure? , which i dont think paper can.. is this only for regular gunpowder / black powder, and not for flash powder?
Oct 30, 2008. 2:14 AMArchive555 says:
I thought gunpowder didn't explode full stop, and that it just burnt EXTREMELY quickly, thus leading you to the conclusion that it actually explodes. Prove me wrong :D
May 13, 2009. 8:38 PMnutsandbolts_64 says:
I don't get the last of what you said but gunpowder deflagrates or something but if contained the hot gasses will build up and then BOOM!!! It explodes with a lot of smoke.
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:drboom
