Introduction: Floating Candles
This is a weary sexy way to have your candles
You will need:
A candle
The bottom of a tin pop can
Something to melt the wax with (I used a soldering iron)
A lighter to engine the candles with
And a lot of time :)
Step 1: Melting
Place the candle inn the tin can bottom
and place the soldering iron on the side of the tin can so it will heat up and melt the wax
Tip heat the wax from the bottom instead of the top it will make it much easier ;)
and wait this proses will take some long time
You cold also place the tin can and the candle in a pot on the stove, but you should put some tin foil in the pot before you put in the candle and tin can to make cleaning up more easy :)
Step 2: Pushing Out the Wax
Now check if the wax is dried
if it is push on the bottom of the wax from the other side
Step 3: The Maiden
Now you are finished
You will just ned to place them careful in the water and light the candle ;)
Lamps & Lighting Contest
