Fm Pirate Radio
Published
Introduction: Fm Pirate Radio
So you want to do some pirate radio , this is an intro into Micro broadcasting , this little transmitter is capable of transmitting around 500 mW of power over the Fm Broadcast Band (87.5 - 108 Mhz) . So the very basics , what do we have in the picture you might ask ? , well first of all we have a fm modulator that was bought brand new from Jaycar Electronics in Australia , it normally is enclosed in plastic enclosure and has a cigarette lighter attached to the end , well not any more as you can see :) , furthermore when you carefully take it apart you have the FM modulator which is capable of accepting a stereo 3.5 mm input / a sd card input and also included a infrared remote control.
One thing you find with most of these modulators is the lack of range they produce , mainly because of the approval or regulations of the country , well hey the government doesn't want pirates broadcasting in the millions around the country. well most Modulators are labelled with an antenna out , however they direct the signal into a few caps and inductor maybe a resistor and terminate the signal their , what you want to do is re-route the RF from being limited and use your own antenna or in this case into a Rf Amplifier for more bang!! this is only an intro of more posts to come , please feel free to comment to motivate me to post more instructables :) to follow , just to add in the picture is the fm modulator a 12 volt to 5 volt regulator circuit which is included in the modulator this converts your 12v dc car battery's voltage to 5 volts and a nice tv amplifier with 43 db gain to give 500 mW of power out the tv amp has been modified to suit... If your interested please comment for more posts :)
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    10 Comments
    so so nice that is my dream ,,plz circuit sechmatic and element pages,,please please help me to make it please
    hi there add me on facebook : can help u better there , sorry for the late reply :
    https://www.facebook.com/bart.morse.101
    Hi again thank you for response,i dont have facebook,f acebook is banned here !
    Tweeter
    Inistagram
    Wattsup
    Or other!
    Really i need your help please.thank you
    it sure is i will do some more posts in the future to come of a cheap 25 watt radio including antenna designs this will give you over 10 km radius transmitting distance in city and around 15 - 20km in rural environment
    the range with this transmitter with a 6db vhf antenna tuned to 98.5 fm is approx 2 km radius further in an open environment obviously the height of the antenna makes a differance plus the antenna has to be have a low swr (standing wave ratio) mine is 1:1.5 however further instructables to come that will cover over 10 km radius with 25 watts output :) you may want to keep an eye on that one as I will be showing how to inject the rf into a two-way radio (low band vhf) to obtain the 25 watts rf output :) I will check out your transmitter now cheers for the comment :P
    Please Follow me if radio transmitting is a passion or hobby of yours more interesting things to come :)
