3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
foam sandblasted sign
This instructable will show you how to make a small sandblasted looking sign from simple and easily obtainable materials.
Step 1The Materials and Tools
Styrofoam: any type will do, beaded white (thats what I'm using here), or the pink, blue or grey extruded type of polystyrene. urethane foam will not work for this project. The colored foam is usually sold under the name foamular and is found at most building supply yards as foundation insulation, they also carry the white beaded foam and you can find it in some craft stores also.
Stencil material: I'm using sign vinyl that I cut on my Summa plotter using Coreldraw, but, you can use contact shelf paper handcut with an exacto knife. or even cutout stencils using chipboard or other materials, be creative.
Sandblast: For this project you could use a sandblaster (very quickly) but because of the polystyrene we are going to use spray paint any brand will do as long as it's not water based, solvents in a spray can will also do, experiment.
26 comments
Jun 7, 2010. 4:30 PMreinlar says:
What reasonably cheap (and readily available) liquid type finish could you dip or spray onto your sign, to make it HARD and more durable and long-lasting than painted foam. I guess clear fiber glass resin & hardener would eat the foam wouldn't it???
I used to know a commercial sign maker who cut letters out of pink construction insulation type foam (from Home Depot) and he dipped them into something which hard-coated them for durability against the outdoor elements, but can't remember what it was. It would be perfect for making this sign technique durable enough to use outdoors. Anybody know what he used.????
Jun 7, 2010. 9:15 PMreinlar says:
Thanks for the links, but I think the stuff I'm talking about was (1) component, non-toxic, 24 hr cure, and cleaned up with water. The guy didn't even wear gloves when he dipped his signage into it. I'll track him down in the next few weeks and post his links. He may have even had a formula for self-mixing the stuff. It looked like white latex paint but thicker, dry to touch in an hour and in 5 days it was pretty dogone hard. Felt like plastic, but flexed enough so it didn't crack if you hit it. I know it was only guaranteed to remain intact for 3 years. He got repeat business, because his signs were good, and cheap. I also remember he attached plain roofing nails to the back of his signs and pushed them into holes with blue anchor plugs for mounting. Very simple, cheap and quick. His signs never got damaged, except during hurricanes of course. He made a ton of money traveling around Florida in April-August.
Jun 15, 2010. 12:40 AMadel_sebaey1 says:
v. good man; any other works pics.
Mar 23, 2010. 7:02 PMMig Welder says:
cool! that's tiny drill press!
Oct 4, 2009. 8:59 PMpenumbra_ says:
So you can paint over the initial spray paint coat with acrylic paint? Not acrylic primer? I wasn't sure how well acrylic paint would adhere to the enamel, but if you could skip a primer coat that would be nice.
Jan 9, 2009. 12:22 PMuguy says:
You could use some of the 2 part Faux Stone paint and make it really look like sand blasted stone. We did this at a vinyl sign shop I worked at. Looks Great, Great ible, thanks for sharing.
Jan 8, 2009. 6:12 PMscavanger says:
Great idea I always knew paint did this to foam, but never thought to use it to my advantage!
Jan 7, 2009. 1:21 PMWeissensteinburg says:
Cool! I've never thought that this property of Styrofoam could be anything but a nuisance.
Jan 7, 2009. 11:24 AMPS118 says:
I'm with the others. Very cool idea melting the foam on purpose to make designs. I bet you could use this to create molds for concrete or other materials. Also, wonder how far a person could take this. CNC / Reverse stereo lith machine, anybody?
Jan 7, 2009. 9:09 AMjeff-o says:
Wow, that looks really good! I like how you've turned a nuisance (melting foam) into something useful.
Jan 7, 2009. 6:34 AMwebman3802 says:
This also works great for making tombstones for Halloween. You can apply a stencil that will only etch the "RIP" or other letting, and use this technique once or twice (allowing to "dry" between sprays) to carve out the letters. Then, remove the stencil and apply a light dusting of spray to the entire tombstone to give it an overall grainy texture. For added details, you can chip out cracks and "crumbles" with the tip of a knife before or after spraying (this probably wouldn't work as well with the beaded white foam). When painting, after the main color, a dark wash of thinned-out black or brown will show off the details nicely.
Jan 7, 2009. 6:28 AMwebman3802 says:
I accidentally discovered this technique while making a blue foam King Tut mask for a sarcophagus I made for Halloween one year. I knew it would melt the foam, so I used one coat of water-based latex (brush-on) primer. Not enough, obviously, but instead of pitting the the foam, only a little of the solvents leaked through the primer, giving it a wavy, dented look in some areas. It worked well for aging the mask, even though I wasn't expecting the effect. You can also use a hobby knife to slice shallow cuts into the foam before spraying. More of the solvents will leech into the cuts than the surrounding area, and you will end up with slight grooves in the etched surface.
Jan 7, 2009. 4:01 AMcraig3 says:
if you use blue spray paint will the melted foam turn blue?
Jan 7, 2009. 3:58 AMrimar2000 says:
Very smart, good work.
Jan 7, 2009. 1:09 AMcourtney says:
nice! I used a similar technique to faux finish some Styrofoam volcanic rocks for an art project, but never thought of making a sign that way. cool!
Jan 7, 2009. 12:20 AMgmjhowe says:
Nice work, alot simpler than i first thought!
Jan 6, 2009. 10:05 PMChrysN says:
That looks really nice!
Jan 6, 2009. 9:43 PMCameronSS says:
Very nice! It looks great!
Jan 6, 2009. 9:41 PMRaisedByRobots says:
interesting idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:peterman921
