Step 11Ending notes
this guitar doesn't hold a tune. my guitar didn't hold a tune before, so that might be it, but be warned.
you may want to add side guards to the string organizer. on my design, the strings would fall off the side of the cylinder.
I know this is not an original idea. but it's original because I am the first to DIY this guitar (as opposed to the commercially available one).
this method doesn't work for fused neck guitars. only bolted ones.
you can endlessly adapt this method. I'm just documenting mine. for instance, ironsmiter added this comment (this is just an excerpt):
Step 4 ; It's usually called a Rabbet. Sometimes, mistaken for a Dado(which is really only a rabbet on the face side of the board, rather than the side).
Step 5 ; I think a Door hinge(maybe a little overkill) would be plenty strong, and a brass one might look nice too.
By using 2 dead-bolts on the back, and a piece of velcro strap, you could avoid the whole string winder issue. Basically, loosen the strings a bit with the tuning pegs, wrap the lower neck once with the velcro strap, undo the deadbolts, and fold. The strap should hold the strings pretty well in place, and the dead bolts should resist the folding forces well, when re-tuning the guitar.
I really like the strap idea- the string winder seemed like a good idea, but it doesn't work as well as i'd hoped. this just reiterates the idea that this isn't set in stone, and it's an endlessly changeable project.
7
comments
Add Comment
freeza36
says:
Add Comment
