3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
folding sawhorse
folding sawhorse
an easy to build, folding sawhorse -
you'll need:
4 - pieces 2 x 4, 30" long
2 - pieces 1/2" plywood, 1' x 3'
2 - 16 penny nails
1 - short piece of rope
Step 1Legs
legs
legs are 2x4's, 30" long - make 4 per sawhorse. Note chamfer on one end - this prevents binding when opening sawhorse.
16 comments
Mar 10, 2012. 9:44 PMShawn Stanford says:
Nice design, nice instructable! I put together two from scrap in short order. I didn't have any nails, but I did have a chunk of copper pipe left over from another project. I used 3" lengths of pipe and drilled holes with a paddle bit to make the hinges. Thanks!
Jul 16, 2011. 9:03 PMjfarry says:
Very good write up, made four for myself! Extremely easy! Gave you credit of course when I did my own write up about my experiences! Thank you!!
http://justmejustin.tumblr.com/post/7517913461/diy-saw-horse
Apr 19, 2011. 2:02 PMunclechime says:
just built a set...used 35 inch legs, 1 1/8 plywood for tops(48x8), and replaced 16 penny nails with 3/8 by 8 inch bolts. feel so sturdy I am thinking twice about the retaining rope. Can stand on both of them and they feel solid(200 lbs). Will likely put rope if I use it for heavy loads.
May 17, 2008. 11:19 AM4airtime says:
Great instructable, just made a set, one 32"& one 36" wide. I used 40" legs which gave a working height of 34-36"(thanx jackbroo). I used allthread instead of nails. These things are sturdy.
Apr 8, 2008. 10:02 PMcferrando says:
I just made a pair today. Nice idea and seems strong. I made mine out of 1X4's for the legs and 6" redwood dogeared fence for the span on the top. Also ripped down a couple of pieces of redwood at 2 1/2" and screwed them about 6" up from bottom of legs. This is where I attached my rope. With the rope lower on the sawhorse it seems to be sturdier. I am going to set these out in the weather for about a month to see how they hold up. If they do well without alot of warping and twisting, I will be making about 40 more. It beats paying $30 a pair at home depot. Great idea, thanks for sharing it.
Mar 4, 2008. 1:30 PMjackbroo says:
I just built a set. The next time I would use longer legs.
Jan 16, 2008. 10:04 AMhassi says:
I'll have one of these built this weekend...A darned good take on a necessary item... Cheers and a hearty "+"
Sep 22, 2006. 4:55 PMzachninme says:
Thanks for making a CAD drawing because you had no example, or no camera... (something I wouldn't do...) Cool!
Sep 22, 2006. 10:28 AMradiorental says:
nice! much easier to build that the clever stackable saw horses on make yesterday
http://pervivere.blogspot.com/2006/09/trigonometry-and-making-stuff.html
Although, maybe not as stable?
I would suggesting putting hinges on the posts to lock the folding point (hinge post to post)
Sep 22, 2006. 12:20 PMmeddler says:
this is cool, more so for one with little or no carpentry skills like myself.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:russingram
