Nightlight led laptop from USB
 by torx
This instructable arises from the need to illuminate the keyboard of the laptop without having to move the display to retrieve some light when working with your computer at night and without other lights on. I have plastic that is lightweight and does not risk of crawl the homes of the laptop.
Step 1: The materials
The material that I used can be seen in figure is two different plastic profiles referred one "L" and a "H", the 4 white LEDs (beam of 20 °, voltage 3.7 v), limiting resistors (not present in the figure), the plug USB and other things of easy availability.
Kalibar07 says: Jun 12, 2011. 1:01 AM
how about a way to actually install the LED's into the case of the laptop so that they are completely integrated into the system...?? would make keeping your laptop clean and organized rather than having a bunch of stuff attached to it.. just an idea
Broom in reply to Kalibar07Mar 5, 2012. 8:20 AM
I've been "inside" laptops, and I gotta say: there is NO spare room inside. The engineering that goes on to make room for the video and mechanical connections through the hinge are immense; embedding LEDs there is pretty much right out.
There might be room for flush-mount LEDs at the top, but I think the easiest solution would be a permanently mounted "lip" at the top. You'd have to make sure it didn't interfere with the latch, of course, and you'd want to leave clearance for any front connectors (smart cards, microphone, whatever) that your laptop has.
torx (author) in reply to Kalibar07Jun 12, 2011. 2:43 PM
It would be a good idea actually; the fact is that it's not on my scope because of my limited technical knowledge.Thanks to the stimulus Kalibar.
Considers, finally, that you cannot change any equipment without seeing its decay.
SharpyWarpy says: Jan 15, 2011. 8:04 PM
Just to let you know I built the light and I'm enjoying it. I made mine a bit differently than yours. Instead of the H channel and L shaped plastic I used chloroplast. I used blue LEDs, 7 of them. I calculated my resistors for the LEDS for 10mA of current so the light would be very subdued and the bulbs will last a long time. I have attached some pictures. The first is without ambient light or flash. Picture 2 is with ambient light, a reading light fastened to the head of the bed. You can see the reflection of the reading light on the laptop screen. Picture 3 is without ambient light or flash. Last picture shows under the hood. I hot glued all the connections of the chloroplast. I did not build an H channel, I glued the piece containing the LEDs directly to the front bracket. The assembly wanted to flop forward because of course it's front heavy and also because there's a bit of a drop off -- a curvature -- on the back of the screen. I solved that problem by applying a thick bead of hot glue to the rear inside corner of the rear bracket and positioned it onto the top of the screen where I had put a piece of aluminium foil to prevent the glue from contacting the computer. After about an hour I removed the foil and had a almost perfectly conformed bracket that did not tip. Thanks again, torx for the terrific instructable.
torx (author) in reply to SharpyWarpyJan 16, 2011. 3:15 PM
I like very much, the light is strong and has a very nice!! You think that you can publish it as a proper instructable?I think it is very interesting and practical. About the issue of supply current of leds I think you've done very well to stay low because I did experience to burn my white leds powered 20ma.
Excellent work Sharpy.
SharpyWarpy says: Jan 9, 2011. 8:52 AM
Well done, torx. Congratulations on what appears to me the best design I've seen yet for this problem. A very worthwhile project of which I will most certainly make good use. I like that it is removable so the laptop retains it's portability. I am truly inspired and I thank you for sharing this with everyone.
torx (author) in reply to SharpyWarpyJan 10, 2011. 4:21 PM
Thanks, I'm glad you like it, and I'm happy to have shared with you this construction.
Welcome to instructables and happy new year!
missourimanwphc says: Jul 6, 2010. 2:06 PM
Is possible to add a dimmer switch to lower the amount of light?
torx (author) in reply to missourimanwphcJul 6, 2010. 3:31 PM
This thing is certainly feasible and would be a touch of finesse that would certainly, If someone on the NET will suggest a solution for this circuit will be appreciated, because I couldn't do anything but put a trimmer resistive that place in series to the circuit, increases the resistance value of limitation thereby to the current total. Thank you Missouriman...
Solderguy says: Jun 23, 2010. 10:06 PM
This is probably the most useful thing ever. If you add a switch you could turn it on and off without having to plug and unplug it.
torx (author) in reply to SolderguyJun 24, 2010. 3:09 PM
Thanks for the praise Solderguy. About the switch I will support and it was my intention to do it, then instead, due to some difficulties in terms of feasibility from me encountered I preferred to do one thing easier. Thanks again.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
