From Battery to Wall Wart in 10 Minutes (with No Soldering)
66,170
495
46
Published
Introduction: From Battery to Wall Wart in 10 Minutes (with No Soldering)
About: I'm an Italian freelance structural engineer, graphic designer and photographer, and I'm teaching physics in Waldorf schools. I always investigate electronics, robotics and science in general, I'm a passiona...
If you like electronic gadgets as I do, you constantly need to charge many batteries, since battery powered devices are still much common. But batteries pollute, disposal has a cost, batteries themselves are not cheap at all if you buy good quality ones.
There is also another issue, many devices work good with alkaline batteries (nominal 1.50V / cell) but have faded display or a weak life with Ni-MH and Ni-Cd batteries (nominal 1.25V / cell) even if just charged.
For this reason is good to adapt your device to be connected to a wall power supply. Wall wart chargers for cellphones can be bought at every electronic fair for a pair bucks, and you probably already have some of them unused at home. Any wall wart from 4.5 to about 30V DC output will be good for this project.
So, let's see how to convert your batteries compartment to receive that wall-wart's plug.
Step 1: Components and Tools
You will be surprised to know how cheap this project is.
The main component is a tiny voltage regulator, the L78L33 in my case, but you can buy one with an output voltage from 3.3 to 24V, to match voltage of your device. This regulator can deliver a current of 100mA, this means that it's suitable for devices which usually drain the batteries (let's say 2400 mA) in not less than one day, so I think all the clocks, alarms, wireless devices, etc.
If this won't work, you can use a powerful voltage subbply as the LM78XX serie (up to 1000 mAh).
Refers to the attached data sheets for pins layout.
Then we need two ceramic capacitors. You can buy them or find on some dismantled electronic stuff. The values of 100nF and 330nF are not mandatory and any similar value is good enough.
Furthermore these two capacitors improve the circuit safety and functionality, but they're not essential, so you can decide to avoid adding one of them or both.
Last component is a female socket suitable for my wall wart plug. Mine is a 2.1mm x 2.5mm power plug, but if you want to use an old Nokia cellphone's charger (for example) it's smaller, 1.3mm x 3.5mm if I'm not wrong. You can find any type of these sockets on eBay.
Step 2: Set Up for Connections
My first version of this wall wart adapter was soldered, but for my other digital clock I tried to avoid soldering to make this project to everyone's reach. If connections are not soldered are probably weaker and we need to avoid forces on them, especially when we move the single-core wires closing the compartment cover. To achieve this you have to transform your linear wire to a more flexible spring.
I prefer to use single-core wires since they're handy to insert behind batteries metal connections.
Step 3: Begin Twisting
As first step twist capacitor's legs as in picture. My 100nF cap is salvaged so it has very short pins, better to find some with longer ones, as the 330nF which is brand-new.
In second step add the TO-92 packaged regulator, so that the 100nF is on the Vout side (pin1). Notice that the schematic in picture (on the datasheet) shows bottom view.
Then twist this central pin to capacitors' twisted legs.
Last step is to twist remaining capacitors' pins to regulator's external legs.
Step 4: Add Wires
Now you have to connect (you bet... twisting it!) the wires ends on the regulator legs. Red one goes on the 100nF side (+) and black one goeas on the 330nF side (-).
Now you can inspect the DC-IN plug to see which is the central contact pin, which coincide with positive connection of the wall wart. Although this is true for 98% of wall warts, it's better you check on the psu label the connection schematic.
The regulator's leg on the 330nF side goes twisted on this pin (input +) and the central leg goes to one of the remain pins (ground).
Step 5: Drill Hole
The benefit to place the circuit in the battery compartment is that you can't insert batteries and plug together. This avoid you to burn the device with a double voltage.
So let's drill an hole with the proper diameter in center of the cover. My female socket has 8mm external diameter.
Insert the socket and screw it up.
Step 6: Close It
Arrange wires to they go toward the batteries positive and negative connectors. You recognize them because they're not connected together and the negative is usually a spring.
I noticed that you can easily push a wire end behind the metal connectors, so that they keep it firm. In this way you have no need to solder anything and you can replace the batteries whenever you wish.
Close the cover and insert the power plug.
Step 7: Partially Cloudy on a Bright Display!
The clock works very good and the display is much more visible than with rechargeable batteries.
If you want to check the voltage out of the circuit you can use a multimeter. As you see the voltage is pretty precise very near to 3.3V).
Step 8: Do You Want to Solder?
If you prefer to solder the pins together you can see my other adapter which works as well very good.
Following this tutorial you should be able to remove batteries from any your electrical device which has no power plug socket yet, so let me know if it worked!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    46 Comments
    I've purchased a multi-voltage adapter , set the voltage to 3 volts ( 2 batteries ) , connect the terminals directly to the battery terminals for a gas heater, burners worked, but did not open the gas valve.why?
    Well done, and very good job on the pictures - very good quality.
    The DC power jack shown has an extra terminal because it includes a switch. Connected properly to the existing battery terminals it will cut off the DC power supplied by the batteries and run the device from the supplied DC power transformer. That would allow you to choose to run the device with either batteries or an external adapter.
    are you sure that the switch is not Normally Open? And it closes when I insert the jack? I have to give a try... if you're right I can drill the clock body and leave the battery compartment available.
    Female DC connectors use common to switch between power supply sources. You can check the connector pins with an ohm meter or a continuity tester. When the power jack is removed from the DC connector, the two common(-) pins will be connected together. When the jack is inserted, one pin will not be connected to the circuit. Connect your battery pack ground to that open pin so that the battery ground only connects when the jack is removed.
    So instead of just connecting your power supply circuit directly to the battery wires, cut the battery common wire or add a jumper so it can go to the extra female connector lug. Connect the common wire going to the device on the other common connector pin.Then you can use either or both.
    Another way to calculate the voltage is to count the batteries and add 1.5 volts for each one. More voltage will require a different voltage regulator. I happen to have a thermometer that requires just one AAA battery. You could make your own regulator for them by using 3 1N4001(to 4007) diodes in series as each one drops the voltage one half volt. Plus would be the anode end from the power supply positive and common would be the cathode end(cathode has the stripe) of the 3 diodes.
    Right, if you need 1.5V you can use one diode after the voltage regulator, so to keep the possibility to use any power supply.
    Only downside to this is you leave batteries in a device and end up forgetting about them, leading to their corroding over time, leaking and ruining it. If you wanted constant power AND you were mindful to keep track of the batteries, sure, using that sort of power socket is a fine idea.
    The female power supply sockets all normally are wired that way. Wire the device to the wrong common terminal and nothing may work. You could also wire a dongle outside of the device using DC connectors with 2 screw on terminals, but that would not look as nice.
    The wall wart replaces the batteries so it would be the user's choice to use both. The cord would have to be unplugged for the batteries to work at all with the female connector. The connector used can accommodate up to 12 volt power supplies too so it might be a good idea to mark the required voltage on the back of the device. Smaller connectors for lower voltage wall adapters are harder to find.
    With this voltage regulator you can input a voltage up to 30 V, so any 5V, 9V, 12V, wall wart (common models) is good.
    And if the switch is normally closed (NC) so I made a mistake saying to connect to any of the remaining pins... since one disconnect when jack is inserted.
    I just LOVE this tutorial, I'm a mechanical engineer, but designing and building electrical solutions fascinates me, is there any way I can learn how to make stuff like this? any pointers?
    It seems you have already found the best place where to learn that ;-)
    Agree! :D
    I would suggest taking classes at your local community college, they usually teach "real stuff" and skip all that "theoretical stuff" that works on paper and not in real life. Or subscribe to an electronics magazine. GL
    I was actually considering the college thing, I didn't know if I can subscribe to few classes without being part of a program, have to check... it would be wonderful if I can do that :)
    Thats just reallyyyyyyy great just what i wanted but A Quick question.. What if my device uses 3 or 4 AA batteries(most of my devices are).... this curcuit wont work thn right ?? it'd b super grt if u guide me through with same thing with 3 bat. n 4 bat. devices seperately.. thanx
    that component exists with output voltages of 3.3; 5; 6; 8; 9; 10; 12; 15; 18 and 24 V.
    I think that L78L05 will work for 3xAA or 3xAAA batteries and L78L06 for 4xAA or 4xAAA, but for powerful devices, as a speaker or a lamp you should use LM7805 or LM7806.
    Reread step 1 where he talks about how to select the voltage regulator. In the case of 3 - 4 AA, that would mean 1.5V X 3 = 4.5 V and 1.5v X 4 = 6v. 5v should work fine for most cases with 3 or 4 AA batteries. These means you need a LM7805 with enough current to supply the device.
