fully automatic knex gun (UPDATED) by extreme builder
FIRST OFF: DO NOT BUILD THIS GUN, ITS A PROTOTYPE!!
This gun is based off of bakenbitz idea and i just improved it and changed it around. Its fully automatic. It works by cranking. I made this gun to shot airsoft bbs but thats just because i like that so u can make it shoot something else if you like. It probably shoots about 3 or 4 per second. It comes with a clip that holds about 23 bbs. If enough people ask for the instructable than ill do it. It still needs some work but it doesn't shoot to far but its a brand new design and there is nothing else like it that i can find. hope you like it. please comment on what you think about it and if you upgrade it please tell me thanks.
UPDATED NEW VIDEO
don't forget to rate and comment
PARTS LIST
connectors-6 double gray connector
-12 green connector
-26 purple connector
-12 blue connector
-77 single gray connector
-1 ball joint connector
-29 yellow connector
-36 black Y connector
-8 orange connector
-27 red connector
-19 white connector
-11 brown rod connector
rods
-87 green rod
-32 white rod
-26 yellow rod
-5 long gray rod
-1 blue rod
-3 red rod
gears
-2 small gear
-2 big gear
spacer
-10 gray spacer
-19 blue spacer
TOTAL
451
i made a real semi auto knex check it out
http://www.instructables.com/id/TRUELY-semi-auto-knex-gun/
MY NEW KNEX HAND GUN REVOLVER
http://www.instructables.com/id/8-SHOT-KNEX-HAND-GUN-REVOLVER/
MY 12 SHOT KNEX GUN
http://www.instructables.com/id/extreme_builders_12_shot_knex_gun/
hey everyone,
check out my youtube page
http://www.youtube.com/user/KNEmovies
Step 1: Body
make this
1-40 of 367Next »
Jasp3r says: May 29, 2008. 11:27 PM
I've only got a little gear without tan connector hole, so mine slips cuz it isn't attached to the axle. How do I solve that?
TheKnexDemon says: Jul 27, 2011. 6:18 AM
Get two stub connectors (small blue things with no hole) and try pushing them close up to the gear
mmuscarella1 says: Nov 24, 2011. 3:04 PM
if u use the tan ones with the stubs on them u can connect them in the small holes in the sides of the gears
TheKnexDemon says: Apr 6, 2012. 1:05 AM
But then when the gear rotates, it would be blocked by that tan connector which would cause many problems
Katarukito says: Oct 28, 2008. 5:16 PM
super glue
chasm says: Jun 5, 2008. 1:27 PM
You can't
XxsonicxX says: Apr 3, 2012. 3:08 PM
I need t say this... i isn't fully automatc, its crank action
dutch ghillie says: Feb 27, 2012. 6:59 AM
the grey clip is broken a clip to hold the bb's
danroy99 says: Dec 23, 2011. 7:38 AM
Does it work with metal bbs?
arjun1 says: Dec 16, 2011. 9:03 AM
does not work
jake scythe says: Oct 23, 2011. 8:35 AM
it is basicly a gattling gun in rifle size
donnie2 says: Oct 31, 2010. 2:30 AM
mine wnt work no matter wat!! :(
TigerNod says: Nov 21, 2010. 4:41 AM
As the description says, it's a prototype. I built it too, it is very unreliable.
qwerty987 says: Feb 1, 2011. 3:15 PM
when i built one it would blow up in my face every time but i will try again. it is ok if you make fun of me for it blowing up.
TigerNod says: Feb 5, 2011. 1:23 PM
Ow..... That's... Unfortunate.
I won't make fun out of you. It is a commonly known fact that most full-auto's have a tendency to blow up.
ryanreers says: Dec 28, 2010. 7:34 AM
if you switched the gears they crank would turn faster
Sketch98 says: Jan 27, 2011. 7:13 PM
but there would be less torque causing it to struggle under more rubber bands
knex1111111111 says: Jan 19, 2011. 3:08 PM
I added a motor instead of the crank and it became automatic.
the vengeful aug says: Jan 10, 2011. 7:22 PM
Rename this the PM63.
flyerminer says: Oct 10, 2010. 1:55 PM
plz find out a way to just use knex ammo and not airsoft bbs! it'd make meh happy. =D
Spycrab says: Aug 17, 2010. 7:10 AM
the 'airsoft bb's' thing disappointed me :\
Blackbird17 says: Aug 16, 2010. 6:02 PM
sry but i took this apart along time ago. we are moving soon so i cant do anything soon sry
Blackbird17 says: Jun 19, 2009. 4:01 AM
i can add a barral to shoot green rods if u want
ellis-perks says: Aug 7, 2010. 12:32 AM
could you plz send me some pics or a clip on how todo this. thanx
sukinmaru says: Jul 31, 2010. 1:59 PM
cool, you ought to make a Mulcher from GoW2
Merugop says: Jul 31, 2009. 12:32 PM
Oh yeah what are those grey parts in the middle
Abcwtfidontcare says: Jul 12, 2010. 8:44 AM
Those grey parts in the middle of the barrel are 3 tan clips.
anres321 says: Jul 5, 2010. 9:03 AM
hey I have made a fully automatic knex gun that works with a totaly diffirent system that is never used before on a fully automatic one. So would you plz tell me wath you think about it ?? here is the URL: http://www.instructables.com/id/Fully-Automatic-knex-Gun-it-really-works-/
snow clones says: Jun 20, 2010. 6:45 AM
Great gun; try making a high mag, high power, bolt slingshot sniper! I've made one and it goes about twice as far because you use a bullet that slides on the rail, and the power is a slingshot.
pokemonguy123 says: Apr 26, 2010. 12:43 PM
i have seen it on you tube im paranid630
joelyboy94 says: Apr 14, 2010. 5:31 AM
 Your photos are fine and your guns wicked, but you mite find knex mlcad useful - there are quite a few annoying flaws in the program because its pirate, but if u manage u can make decent images and instructions. im not gonna lie its hard but tell me if u want the program
smattman22 says: Jul 29, 2009. 8:34 PM
mine wont fire or pull back far enough.
extreme builder (author) says: Jul 29, 2009. 9:26 PM
you must of done something wrong than
smattman22 says: Jul 30, 2009. 6:09 PM
i have thick rubberbands. but it doesnt slide all the way foward
michiel123456789 says: Mar 30, 2010. 8:51 AM
I know what you mean. You've gotta add spacers (not connectors or there will be blocking something) here:
extreme builder (author) says: Jul 31, 2009. 2:54 PM
i dont know what to tell you. try less rubberbands
Buckethead32 says: Mar 25, 2010. 2:56 PM
your photos arent showing up on the screen but other guns are.  Do you know what that is
robb45 says: Mar 23, 2010. 11:44 PM
i made this gun end it sucks wen i want to crank it brokes
robb45 says: Mar 23, 2010. 11:52 AM
very cool gun does the mag works good?
i gonne make this gun now
snwboy123 says: Mar 6, 2010. 11:02 AM
you should make more steps for  num 2 but besides that its great
1-40 of 367Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
