3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
gas bottle wood burner
hi everyone ,,,this is my first attempt at a log burner ,,,, it seems to be OK so far, but i have few questions I'm hoping  one of you can answer
 as you can see in the pics i chosen to have my bottle on its side ,, and my door is bottom from second bottle .... the chimney is 4 inch in diameter and protrudes about half way into the bottle ,,, but has baffle plate in front of outlet on the inside .
my question is when i close the door the fire goes out  or dies to a point of going out  but burns fine with door open .....
the vents in the door are approx ,,, 1.1/2 inch with butterfly's but do not seem to flow enough air to keep fire going ..
can anyone shine any light on were I'm going wrong
thanks  Ian
8 comments
Nov 5, 2011. 9:22 AMrblenkinsop says:
Nice looking heater. I would agree with the others in that your air vents need to be in the front of the door and be adjustable as to allow different air flow amounts in.
You might think about re-working the legs so you could cut the bottom out to allow for easier cleaning of the unit.
Good job though. Post some results of how it works after the modifications.
Apr 15, 2011. 6:43 AMshannonlove says:
The details of any burner/stove are in the interior so a diagram, with dimensions, of the interior would be helpful for us to have. But I'll make some educated guesses based on what we have now.
The most likely cause of the problem is that the chimney terminates "about half way into the bottle." That would mean that half the bottle's interior is above the exhaust. Since hot air rises, the most heated air, and the most oxygen depleted air will rise to the top and stagnate there. This will (1) kill your "draw" (the pulling in of fresh air by the rising of hot air out of the chimney) and (2) it will fill up the top half of the bottle with fire smoothing oxygen depleted air. The depleted air layer will grow larger until it smoothers the fire.
Ideally, the chimney opening should be at the highest point inside the interior such that the hot air will naturally rise towards it. This creates a built-in air pump to supply the fire with oxygen.
If I am correct, the burner works with the door open because the open door disrupts the layer of stagnant in the top half.
Jul 14, 2011. 6:38 AMhippytyre says:
That makes perfect sense to me, lob off the extra bit of flue/chimney on the inside and see if that works. I'll be building a bottle stove myself at some point as soon as I have the materials.
May 17, 2011. 6:03 AMKelticpaddler says:
As well as Shannonlove's comments I have the following.
I can't tell from the photographs, but it looks like your vent tubes and your chimney are ont the same side of the stove. With the door shut and the vents open, the "draw" of air across the fuel is virtually nil. With the door open the "draw" of air runs across the fire (from the open door), hence keeps it alight.
You may need to move your vents to the front of your stove to encourage "cross flow".
I also heard that airflow should be "under" coal, but "over" wood. Maybe weld your vents to the door, just above the level of your wood.
I hope that this helps.
Jun 21, 2011. 12:47 AMKelticpaddler says:
Hi Spamfritter
What I forgot to say was, that is a stunning looking burner...what a great job!
I hope that it eventually "behaves" for you.
It reminds me of some of the earlier steam engines, in particular "Stevensons Rocket" built and run from my home town of Darlington.
A couple of wheels welded to the side of your burner and you would have a "themed" wood burning stove....even if it is a little cheesy. :-)
Jun 18, 2011. 1:46 AMglensinstructables says:
I toatally agree with Kelticpaddler, your vents need to be on the opposite side to the flue to draw the fresh oxygen across the fire.
Jun 20, 2011. 5:56 PMl8nite says:
It looks like it will be a great little heater when the bugs are taken care of. I'm going to agree with the others about the exhaust stack, if you look inside any woodburner be it a franklin stove or a bbq smoker the exhaust is at the top and as unhindered as possible. If the 3" of intake don't seem to be enough after that fix, personally, Id add a reducer and 2.5" extension to the exhaust to get the smoke above head height, of course Im assuming this is going to be used on an outdoor patio
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:spamfritter
