Remove these ads by
Signing UpStep 1Tools and materials
-3/4" ply wood (design dimensions will be dictate how much you require)
-plate glass (the other factor that will dictate how much wood you require)
-wood glue and or silicon or latex caulk
-1 screws
-door and window foam weather striping
-sand (this one required 50 lbs)
TOOLS
-eye and ear protection
-skill or table saw
-router and 1/4 straight bit
-cordless drill
-ratchet bar claps
-drill bit
-counter sink bit
-phillips screw driver bit
-large dry wall square
-pencil
-tape measure
I have some play sand but it's really fine and I was wondering if their tunnels would hold up in it.
How do you give your ants sugar?
Do you find the colony consumes a lot of solid food?
Were you able to find the queen?
If you drilled multiple 1mm holes over the top the covered it from the inside with fine screen mesh you may get some good ventilation happening.
Be very very careful when giving the ants food which is "past its prime". A mould break out in the lower quadrants of the nest will surely devastate the population.
Another very interesting part of formicariums are the foraging areas. Not only is it amazing to watch their tunneling habits, it can also be astounding especially for children, to observe the foraging behaviours on a flat surface of area. Your setup could easily be adapted down the track to incorporate something similar to http://www.instructables.com/id/3_Foot_Tall_Ant_Nest_and_Foraging_Area_Authentic_/
On a side note I keep Australian Bull ants. I should update my I'ble with photos of them in the nest.
Here's a tiny pic, I didn't want to add load time to your I'ble with a heavy close ups.
