3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
golf ball centre line marking jig
If you enjoy playing golf and are trying to improve your putting game you probably find that there is so many things to focus on and its hard to work out which one needs fixing. A great way to start is with a line marking jig. It allows you to accurately mark the centre line on your golf ball. When you line up your golf ball's centre with your target its one less thing to worry about. Instead of buying a shop bought jig which can be hard to find and expensive to buy try this quick and easy instructable.
Step 1Make a 44mm hole in some 12mm ply
take a piece of 12mm ply and cut it into a rectangle 70mm by 90mm. Use a holesaw to cut a 44mm hole through it in a central location.
6 comments
Feb 5, 2009. 12:44 AMCaseyCase says:
Superglue isn't ideal for gluing wood. Wood is too poreous and will "suck up" the glue like a sponge to the point that the bond between the two will be affected. How about using wood glue (Elmer's, Tightbond, etc.) or a polyurethane adhesive (Gorilla Glue) instead?
Feb 5, 2009. 4:58 AMpullinsb says:
Mixing baking soda with superglue makes a really quick expoy-like glue. This would give it a thicker consistancy and keep the glue from being soaked into the wood like you say. I agree that superglue may not be the best medium for securing the two pieces of wood, but this is a low- to no-load bearing situation. If I were building stairs, I'd go for screws.
Feb 5, 2009. 12:29 PMCaseyCase says:
Interesting! (Baking soda and superglue) I will have to try that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:timbo2222
