Good Powerbank From 1$ Powerbank Case
2,315
32
7
Posted in TechnologyElectronics
Introduction: Good Powerbank From 1$ Powerbank Case
we all face problems from the fake capacity of power banks ,
mainly the power banks have pretty good circuits but the cells they give are very bad .
Here i am showing how to retrofit a cheapy power bank 1$ with good cells 18650 .
i n many countries the higher capacity power banks cost more
so we can use some good reliable cells and a damn cheap PB to make a reliable
usable device .
Step 1: The Refit
Grab a 2 cell power bank at low price ,
desolder wires
new cells sometimes come seperate ,
so need to scratch with sharp object and solder cells in parallel
install in to the case .//
Step 2: The Safety Cut Off
The litiums must cut at 4.2V ...
DANGER : some of the power bank charger circuits DONT cut so how to know ?
Well charge the cells for 1-2hours , monitor voltage
if it is crossing 4.2 , the cut is not there
So , instead of using OPAMPs etc , we can have a simple circuit like this to cut off
select zener as zevervolt + 0.7+0.7=4.2V zener can be 2.7V
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Make it Move Contest
    7 Comments
    Thanks for this circuit, it looks like it might do for something that I have been wanting to build.
    Do you have any thru-hole replacement for the MOSFET? The only places with the IRLML2502TRPBF show it as a surface mount device. Thru-hole would be a lot easier to solder.
    I am ordering another common Logic level mosfet SI2302... any logic level mosfet with 1-2AMP current capacity will work
    If I apply more than 5V at the input, any problem ?
    some really nice and cheap circuit exists how take care of all the charging process. By example the mcp78831 http://ww1.microchip.com/downloads/en/DeviceDoc/20...
    It´s not easy to solder on protoboard, but still possible. I guess you should be able to find PCB or kits for it. Something else to be aware of when using lithium batteries is over discharge and over discharge current. Some batteries integer such protections but you will also find PCB or even battery holder with integrated protection.
    some issues with the special chips are 1)chip itself will cost like another powerbank 2)pcb + wiring will take 10-15$ or many painful diy hours 3) many of the chips cant do 1AMP charging many need 6V as input 4)yes difficult to procure in many parts of the world
    Yes it'a true. The chip on the picture only allow 500mA, is not easy to solder (but only takes minutes) and cost one dollar...add another one for the capacitors resistors and led...
    thatz a great build ... grabbing the caps in a SMD bulk bag it can be done in 'some' countries ... here in india people in small towns are not so fortunate .
    but now a days the mosfets are available online all over the country .
