3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Greenhouse From Old Windows
This is a brief guide on how I took some old windows from houses they where tearing down in my neighborhood and turned them into a small greenhouse in my back yard. I collected the windows over the course of a year and a half and the build took about 3 months, spending one day a week on it. I spent about $300 for the lumber for the frame and screws, caulk, latches, etc. That's almost 10% of what a greenhouse kit would cost. The size I built was 7 ft high x 10 ft deep x 6 ft wide. But the size of your greenhouse will depend on your windows and the time you want to put into project.
Step 1Collect Windows and Plan Two Pair of Equal Sides.
Look for old windows and save every one you get. After you have many, lay them out and play a game trying to make two pairs of "walls" both the same height. Two to three inches won't matter as you can cover the difference with wood. Smaller holes will need to have glass cut for them or filled with something else. Keep in mind that one end will need a door and the other a hole for a fan.
110 comments
1-40 of 110next »
Mar 21, 2012. 11:46 PMjmccallen says:
"Choose a length that allows at least 14" of the stud to be placed in the ground for support."...as in buried in the ground like a post? standard non-treated 2x4's?
Mar 21, 2012. 11:50 PMjmccallen says:
nice touch with the dutch door...easy to convert from any existing door you might have around..
Mar 2, 2012. 4:05 PMtrish330 says:
this is exactly what i have been saving those windows for in my garage. I will be clearing some area near my compost pile.... what a great idea and thanks for the step by step!. I live outside of Chicago...
Jan 15, 2012. 6:25 PMdenebrock says:
Love this idea!
May 16, 2010. 7:10 AMmakalove says:
When our local community gardening group was offered a bunch of windows by a guy who was remodelling an old house, we were told by our local county extension office that building a greenhouse from discarded windows was a bad idea because of the possibility of injury due to broken windows. Greenhouses should be paned with shatterproof substances because regular household window glass could break badly and seriously injure someone inside the greenhouse. Just a caveat.
Dec 26, 2011. 8:48 PMJWEngland says:
I have three greenhouse, and used regular windows for the construction. They have been in use now for more than 11 years, and with only five broken window panes. One from Hurricane Opal, the other four normal accidents that would have broken just about any window.
Sep 13, 2011. 1:51 PMjohnny3h says:
A warning about single pane ordinary glass hazards is warranted, BUT...
There should be no regulation preventing the use of used windows with single pane, single or double strength glass.
I to am in the process of trying to collect enough old windows to build a greenhouse of a reasonably usable size.
In the meantime, I got really lucky when a couple of neighbors replaced their large "patio" sliding glass doors.  They each consisted of TWO glass panels [one fixed and the other sliding], giving me FOUR large double glazed [insulating] panels.
And the REALLY good thing about them is that they are both made with TEMPERED glass which is genrally much stronger, AND IF broken, shatters into hundreds of small "pebble-like," pea gravel sized pieces which are not as dangerous as the shards from broken ordinary glass.
Not yet having enough windows collected to build a greenhouse, I used the 4 double insulated panels to make four COLD FRAMES,  which work great.  Because of being double pane insulated panels, they each are very heavy, but with proper [ergonomically speaking] handles and automatic [gravity-pendelum action] prop rods, they are managable.
I made the cold frame bases of treated 2x4 framing, with the cavities filled with discarded Styrofoam sheeting [picked up wherever found discarded], covered with 1/2 inch treated plywood on the outside, and 1/2 inch untreated, but exterior grade, plywood on the inside.  I then lined the interior walls with a construction water barrier film to give some limited protection to the plywood.  To facilitate replacement of the interior plywood wall panels if it should ever be needed, I assembled the entire structure with Galvanized drywall screws.
Before varnishing, I carefully caulked all exterior crevices that might allow entry of weather [wind or water].  Finally, ALL outside wood exposed to weather was sealed with a properly applied [per label directions] triple coat of Polyurethane Varnish.
Unfortunately, I have no photos, AND have sold both cold frames a few years back.  A "out-of-towner" guy made me an offer I couldn't refuse [$500 each], and so I've got to start over in the process of collecting tempered glass double insulated panels.
May 21, 2011. 4:54 PMkaterlyn says:
my sisters inlaws had a green house two people used for years and years....no such problems except weather and age...breaking windows...They even had dogs and cats around.
Jul 26, 2010. 8:08 AMpeapeam says:
, you gave me associations to some thriller movie now. Can't remember what it was called, but a lady got "murdered by greenhouse"... I just love the greenhouse here, it is just sooo beautiful! Make me want a mini version for my balcony! Mine wouldn't be a walk-in model though, but rather a "closet" version... :)
Nov 2, 2010. 7:09 PMBuckyH says:
I'm sure the name of the movie is "The hand that rocks the cradle."
Jun 13, 2010. 9:43 AMjaustin168 says:
Gotta love the Nanny State....
Jun 14, 2010. 6:55 AMmakalove says:
[shrugs] not saying we didn't still use the windows! but people should have all the information when looking at a project so that they can make an informed decision.
Oct 25, 2011. 6:01 PMmlayton howell says:
You have given me such inspiration. Our local court house was having their windows replaced. We scored 10 windows 35"'by38" and 10 windows 33"by35" and several more assorted sizes. All are double paned and we got the gasket around them. Couldn't get the channels. If we use 2" by 4"s and put a 1/2 inch channel in each to secure windows, would this give me enough structure safety? Don't know construction but really am inspired by you.
Sep 30, 2011. 10:32 AMneuronical says:
We have hundreds of windows in our barn and I am getting ready to start the design and structural planning of a very large greenhouse. I will trade windows for expertise, project help or ???
Aug 4, 2011. 12:13 PMibarnett52 says:
thats awesome im collecting windows right now gonna build a big one
Jul 29, 2011. 8:38 PMkruegekm says:
This instructable is awesome! Such good description that makes it seem possible. Also, I like how it evolved over time with the various materials scores. Inspiring!
May 21, 2011. 4:50 PMkaterlyn says:
This is great. I have a lot of extra windows I got half price of very low prices, at the local Habitat for Humanity Restore....that would be a good source of reasonable windows.
A neighbor made a green house of windows, he set it on concrete from an old barn that was on the property years before.
Jan 4, 2010. 6:48 AMdavyR says:
Very nice, also a good idea with the rocks. I used to have a similar setup in my garden, but it didn't last very long, because the wooden foundation was standing in mud and water during autumn and spring all the time, which resulted in it rotting away very fast. (I think we had to fix it after only 3 years)
Jul 26, 2010. 8:23 AMpeapeam says:
Wouldn't old railroad sleepers be an idea then, if you can get hold of some? Those does not rot easily...
Apr 1, 2011. 3:47 PMsindaear says:
If you decided to use railroad ties be careful how you use them. If they are separated from the greenhouse entirely (with non-porous floor) they probably won't be a problem. But they coat them with chemicals to prevent them from rotting and also they regularly spray pesticides on the tracks to kill the weeds. You probably don't want those chemicals near you or your plants, especially if you are growing anything edible. Just something to watch out for.
May 8, 2010. 4:48 PMchmisc says:
Great Instructable.  If you need windows, check with your local window/glass supplier/installers.  Most will let you have the old windows they remove from home renovations, especially if you give them a wish list.  Otherwise they have to pay to take them to the landfill.
Jul 26, 2010. 8:15 AMpeapeam says:
Our local landfill has a recycle section. When you go to toss something, if it is recyclable, you get to leave it there for free (you get to do that with some other things too, but you have to sort them into different bins yourself). It's a big building, and people come there to leave all kinds of things for the home they don't need anymore and others come to find free furniture etc. etc. Think I'll have to go to see if there are any windows there. If something hasn't been claimed by somebody else within a week, the landfill people remove it and discard it. It's just like a second hand store for things for the home, only it is free for all. :) All landfills should do that, what a wonderful way to reduce the amount of garbage and great for those with little money... :)
Mar 21, 2011. 10:48 PMpaxxy says:
that has got to be one of the coolest ideas I have seen-- I so wish our area had something vaguely similar!! :)
Mar 21, 2011. 10:47 PMpaxxy says:
....for those who want a cool looking compact version or want less commitment to building... for a balcony or back of house, I have seen ones that used 4 of the same sized windows and against the side of a home in the back front, side, side and then top...-- basically the front and side pieces were either framed together or screwed together with brackets and the top was hinged on the left side or right , opening sideways...
You can put bricks on the ground perimeter area and place on top of the bricked area...
Mar 21, 2011. 10:29 PMpaxxy says:
Chef...great idea...I have seen this before on re-purposing sites and they have captured my heart-- and I was thinking to add to the dimension ... some artwork and color to some of the windows-- do a stained glass creation in some of the windows with the light/darker colored glass rocks they sell cheap and gorilla glue-- make LOVELY scenes like a star, the sun etc...you can get these rocks at craft stores and the $$ store in bags...make on a few windows or eventually many of them...let light iin and create privacy at same time... Also I just found 15 double paned windows ( w/o their sashes) in aluminum or vinyl frames and would love to put them together but nailing these isn't an oprion..any suggestions??
Jan 30, 2011. 5:54 AMgypsie114 says:
THIS SO WONDERFUL OF A IDEA I HAD TO MAKE ONE. I LOVE IT. I EVEN SIT IN IT ON THE WINTER I MADE IT 8.X12 ROOM . SO PRETTY TO SEE THE SNOW FALL AND BE SUROUND BY YOUR PLANTS ALSO. IT LIKE HAVE A LITTLE SAFE HAVEN THKS TO THE ONE THAT COME UP WITH THIS IDEA. MAY GOD BLESS YOU .
Mar 16, 2010. 8:34 AMtappan says:
Thanks for this instructable. It inspired me to make one of my own.
The taller side is south facing. All of the windows can function(open/close) save the two big picture windows on the east and west sides.
I added 50 gallon water barrels to disburse heat gain throughout the night.
Next to add are solar panel and fan.
Jul 26, 2010. 8:20 AMpeapeam says:
That's just great! A mini-mini version of yours, is just what I need on my balcony! How much more charming than one of those vinyl covered shelves... :)
Jul 26, 2010. 9:31 AMpeapeam says:
Just an idea... I only have a balcony. Do you guys think I could use one of these pine book-cabinets as a balcony greenhouse? I of course would paint it well, so it can take the elements. Could also remove the top and put in a little window there which can be opened. The cabinet has glass doors and sides. There's lots of used ones for sale these days at low prices. Just saw one for $60.
Apr 20, 2010. 3:11 PMdeechurch says:
Great instructions! This is a project I have wanted to build for awhile. Hope I can find more windows soon so I can get started.
Question...I have access to two solid pieces of glass from old shower doors. Is this glass okay to use? (I understand it is tempered or shatter-proof.)
Thanks!
Jul 26, 2010. 8:17 AMpeapeam says:
Thanks for giving me that idea! Shoot, someone I know just threw out some... That would be something I could use too on my balcony... :)
Jun 25, 2010. 5:46 PM2-tired says:
Love the plans, have bunch of windows we plan on building into a Green house soon,............. but In our 'corner' we HAVE to have a permit if the structure is fixed in the ground in ANY manner. We plan to build our greenhouse on treated 4x4 skids. Our goat coops, chicken coop' storage sheds are all on skids (hubby has become very adept at this.) Not that it would ever be moved, but technically it would be considered a movable construct and therefore not require a permit or be taxable. Just a bit of FYI for those in a similar building code environ.
May 26, 2011. 11:16 AMceknight says:
Wow! You're right, that is a MAJOR score! Those mechanisms are hard to come by and expensive.
May 18, 2010. 6:12 AMceknight says:
You've got some very ingenious little bits in this greenhouse. Love the hinged window stops for the vent area. Great job!
May 17, 2010. 1:19 PMweesuzi says:
@chet.  Mate probably one of the most useful and well documented ables I have ever seen on the site.  Well done, looks lovely.
Apr 17, 2009. 9:23 PMRead Head says:
It's adorable. I want one.
1-40 of 110next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:cheft
