Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
any help with that?
(By the way.. i use the chain that i got from the Speedster rollercoaster set.. is that diffrent to original chains?)
The Chain Itself Is Fine, It Sits Perfectly On The Gears,
Im On about The Grey Bit You Use To Hold The Bit Of Knex Onto The Chain.. That Slides Off It..
Heres The Link For The Coaster Im On about
http://global.knex.com/uk/age-7+/speed-coaster.php
r
p.s.im not going to check back often so dont expect to hear from me in about a week
and at the bottom i used two big gears placed together with a blue spacer in between, facing the same direction.
rymndgeekyguy is correct.
You need to add eithr mor gears sticking out along the backside or a rod with spacers on it.
also, if this doesn't work and you cannot take of one chain link, then you can try to replace one of the chain links with one of those clippe thingys shown here.
hope this helped!! (even though it is a liiiiiiiiitle(that ws sarcasm) late.
p.s.m heres a pic if you can see it.
picture here
could not get a picture
Also, I forget who, but someone on instructables has a link to a youtube video of the lift which has a link to the instructions on knex.com
I'll try to find the link again
'the mini chain lift'
I had tested it without actually holding the chain tight, so the ball carrier kept bending with the added weight of the ball and the ball kept falling off.
I built the mini chain lift, about 5 feet tall, using all of my mini chain links but one (I only have one of the ini rollercoaster knex sets ): )
It works perfectly!!
Thank you so much!!!!
