3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
hacking a car stereo and a computer
This is in response to my posting of case mod
carig14 ask me to do this so blame him .
I take no responsibly for you using power tools on a computer!
The same with eye protection , hearing and such.
If not familiar with a complete computer build then this is way over your head.
Try something like this on a junk tower first .
I will not go into the details of the MoBo install or any of the computer building.
Step 1Strip out the computer tower
I will not make this on how to build a computer loads of instructions on the web for that .That said eather start with a new tower or strip everything out of an old one .
This tower is a lenov ADM that was used in my lighter mod .
The tower must be complety striped as chips from the sawing /grinding will flat mess up electronics .
I located on the plastic faceplate where I wanted the stereo mounted marked it with a sharpie the stereo has a thin sleeve for mounting it into the dash I slid this off and used it to trace the outline of the stereo mounting hole.
Drill a 3/8" hole into the 4 corners of faceplate then connect the holes with a saw ( jig or sawsaw) light work with a file made the sleeve fit the faceplate nicely.
I then mounted the faceplate to the tower,dropped in the sleeve and traced the cut I needed on the face of the tower.The side the MoBo mounts to was in the way of the stereo so it was rough cut to make room.
41 comments
1-40 of 41next »
Sep 1, 2011. 7:37 AMtlee23 says:
i did mine the other day and it works great but i got a brand new case and put the stereo at the top and put a shield in it so i could have speakers built in and the pc is all still working fine at the same time so yeah but it was a lot harder to do my case for some reason it had more metal to cut out then my first one
Aug 30, 2008. 12:38 PMcarlg14 says:
you done it well done it looks nice and do be honest i have never seen a car stereo installed to a computer what psu are you using for your computer?
Jun 15, 2009. 12:00 AMtwocvbloke says:
It looks like the centre console from a modded ricer (no, not racer, ricer!!!) car... :P I've often thought of fitting a car stereo into a PC case, but I just couldn't be bothered to... :D Nice work... :)
Oct 24, 2009. 9:31 PMkumaru says:
That head unit was GREAT in my honda!
(I'm serious, btw, haha!)
Jul 10, 2009. 9:42 PMhack124x768 says:
Holy cow that would be awesome... Bit more expensive than the old ps1 screen hack though.
Feb 12, 2010. 1:56 AMLance Mt. says:
 Dude if you keep this up your com's gonna go all sentinel on you XD
Feb 15, 2010. 11:00 PMLance Mt. says:
 lol, your punishment to it would to BLUESCREENOFFDEATH him. Hehehe,
 WHY WAS I PROGRAMED TO FEEL PAIN?
Actually, that would be more like mac.
Aug 30, 2009. 11:27 PMDerin says:
a note about the cd drives: most drives come with another faceplate which makes 2 paint the second one red and install that or remove the installed faceplate and tray cover to paint those
Jan 31, 2009. 3:01 PMYerboogieman says:
:-D i have that same stereo!!! They should have put more than 4 RCA ports on it, great stereo.
Aug 31, 2008. 7:32 PMguyfrom7up says:
you know, I was just thinking about making a little capacitor penguin that looks exactly like that! lol
Aug 30, 2008. 9:46 PMalex-sharetskiy says:
So um, why do you need a stereo? you already have a cd drive, and that computer probably came with powered speakers
Aug 31, 2008. 9:43 AMalex-sharetskiy says:
well, ok, it wouldn't put out 80watts X 4 channels
80 X 4 = 320
so that stereo puts out 320 watts total
But where does that power come from? your PSU
so your PSU is 12v, just like a car battery
but not enough amps, your psu probably puts out ~3 amps
now here's the problem;
Watts = Amps X Volts, right?
So your PSU puts out 12v X ~3Amps = 36 Watts
your stereo needs 320W+ to operate properly, but your PSU gives it 36W
-The sound quality will be heavily distorted at high volume-
Aug 31, 2008. 8:53 PMalex-sharetskiy says:
look at the little lable on the PSU, find the 12v row, and find how many amps it puts out, make sure that you are looking at the 12v "thing"
Sep 3, 2008. 5:51 PMPunkguyta says:
Not to mention your CPU, which for the most part is the most power consuming component in your PC, is probably around 50 watts or less (44-50 giveortake). And that's assuming you can actually push it right up to 100%, don't forget though it's gotta take a breath every few cycles so it's not really capable of surging it's rated power in a constant power draw.
Sep 3, 2008. 5:57 PMPunkguyta says:
Oh yeah, and not to mention that I had a 150 watt audiovox amp hooked to to an old old P1 power supply, it was like only a 250 watt power supply and a handful of amps. The only time anything overloaded was from giving the amp too high of an input signal from my ipod or whatever to it's RCa jacks and It was too much. But I don't think that had anything to do with the power supply it self.
Sep 1, 2008. 6:04 PMalex-sharetskiy says:
ok, never mind, sorry for the trouble
Sep 3, 2008. 9:16 AMtedsmokeone says:
we got tunes hahahahaha
Sep 1, 2008. 8:45 PMJahoovi says:
finally someone posted something about hacking into other people's items
Aug 30, 2008. 5:17 PMsr1sws says:
I like the assistants.
Aug 30, 2008. 6:58 PMsr1sws says:
Heh... maybe it's the gin, but I can't find the thread with the 'assistants'. Can you give me a hint? Thanks!
Aug 30, 2008. 7:36 PMlearningmasters says:
and it works as a computer nice!!!!
Aug 30, 2008. 1:35 PMtyeo098 says:
I have that exact stereo in my trck, does yours skip to the next track like partway through a song?
Aug 30, 2008. 2:53 PMtyeo098 says:
I meant the sd card lol How long have you had it? But all my songs are from limewire lol, but they play fine on other things hmmm...
Aug 30, 2008. 5:31 PMtyeo098 says:
btw the title should read 'hacking a car stereo INTO a computer' not and
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:bikerbob2005
