So i had to make something ,and came up with this ....
A wooden hand grenade wich can also open your beer.
Remove these ads by
Signing UpStep 1Drill a hole
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
You keep up the good work, be safe, and always think outside the box, never limit yourself or your ideas by saying well if i had a lathe i could.
you are a true artist keep it up i hope to see more post on here from you.
Safety first
FUN POLICE
a drill press has much bigger bearings spaced apart witch help a lot with side loads
ever seen a milling block. i use them all day.
you can even get a small cheep drill press and make a mount for it so its sideways
to do much bigger things like a baseball bat. most have good 15mm+ bearings and more then one set plus changing the belts will help. it adds some level of slip witch will help the motor live longer
but if you think your going to do more then 2-3 just get a desktop unit from like harbor fright or some place i seen small units well under 100$
most hand drills only have one side to side bearing (just to keep it centered) and good thrust bearings as that's where the load is
add to it most drills are not meant to be on at high speed for any long time period.
well that's my 2cents
