3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
hand-soldering teeny tiny chips!
Have you ever looked at a chip that's smaller than your fingertip, and has no pins, and wondered how you could ever possibly hand-solder it? another instructable by Colin has a nice explanation of doing your own reflow soldering, but if the your chip is not BGA, and you want a technique that's quicker and won't put as many poisonous fumes into the air, read on...
p.s. here's what you need:
- soldering iron (fine tip)
- microscope (or very, very good eyesight)
- some flux will help (flux pen)
Step 1Check out the chip
Check out the chip
Make sure you know which orientation the chip is supposed to go on the PCB. In this picture, you can see the little dot to the left of 'CYG'. The convention for chips is that that the little dot indicates the top-left corner of the chip, and you can have a look at the PCB layout diagram to figure out how the chip is meant to be oriented on the board.
46 comments
1-40 of 46next »
Jan 9, 2012. 9:18 AMOrngrimm says:
I prefer to presolder the chip (Like you did here), but then after the positioning (and securing), ill take my heatgun, set it to 410°C and quickly solder all points down in a few secs. No additional solder is needed and the result is much less excess tin around the pads.
I succesfully soldered this way down to 0201-sized SMD-Items. Havent had to solder 01005 (Fortunately) but who knows...
Anyway: Your instructable is nice and explains the process quite well and also does note the important part of checking the solderpoints afterwards.
Nice instr.!
Jan 15, 2012. 12:03 AMkruisengruven says:
I like the sound of a heat gun. Do you use a pencil style heat gun, or can a regular size heat gun work? Just blast it for 5 secs?
Jan 15, 2012. 4:32 AMOrngrimm says:
Unsure what it is called in english... Native swiss guy here speaking german ;)
I use this one: http://ch.farnell.com/steinel/hg-2310lcd-eu/heissluftpistole-230v-eu-lcd/dp/1712315 which is with 330 swiss francs a very expensive one...
Cheaper ones also work no problem... But i like the option to regulate the temperature to degrees and not only with "1-10" and also being able to adjust the airflow independent from the rest...
So yes: Large one; not stylus-type like http://ch.farnell.com/oki-metcal/hct-900-21/heissluft-loet-entloetstation/dp/1015504 as an example.
Heatgun may NOT be the term you use... In german it is "heissluftpistole".
Heissluft = hot air / heat
Pistole = handgun / gun
So heatgun seems to work... Also wikipedia knows it with this name:
http://en.wikipedia.org/wiki/Heat_gun
"They are also used in electronics to desolder circuit board components" is even listed in the wiki! :) And also there is a citation needed.. Maybe they want to link to here? ;)
Nov 21, 2011. 9:08 PMcgosh says:
Great Instructable, terrific photos! Thank you.
I like Caig Labs Circuit Writer, a pen-shaped dispenser that places a small dab of conductive glue that dries hard. For tiny connections, transfer it with the tip of a straight pin. No worries, no shorts, no heat. Clean surfaces, but flux is probably not needed. About $20, check Froogle.com
I've used it to place surface-mount capacitors, resistors, etc. directly to the pins of mini-DIP IC's and create power buss traces on the case, so I make tiny projects with no PC board, then encapsulate with clear epoxy or hot-melt glue. Use 40-ga. Kynar or "wire-wrap" wire for jumpers.
For a tiny solder pencil tip, file a piece of solid wire to a point and hold with pliers and wrap it tightly around the tip, then tin the wrap and the point. The common copper wire used for electric outlets is handy.
If your eyesight is lacking, try a pair of "readers" eyeglasses at any drugstore for a few dollars or get a set of magnifying glasses on a flip-up headband.
For a steadier hand, hold tools closer to the work, same as you were taught to choke-up on a baseball bat to improve control. Also hold your hand against a solid surface, same as steadying a camera.
The "ground" shown in the center of the chip above also acts as a heat sink, so heat will determine its need. Digital circuits rely on solid supply voltage and reliable ground. If either is the least bit flaky, odd results will occur, so make sure both are solid.
Nov 21, 2011. 12:27 PMkc8hps says:
I had a chip have crack issues on the joint/trace junction etc. I found that by using a flat nose 30 watt iron I could flow solder over all traces. some became joined but that is ok because your only half way there.
Take a piece of solder wick and lay over a line of connections. have a slight film of flux on your wick. heat it and any solder not attached to a trace/connection will be removed by capillary attraction to the wick, leaving nice chip to joint attachments. remember to lightly use some alcohol to (read Q tip) to remove excess flux as sometimes I can make a chip act funky.
Nov 21, 2011. 5:19 AMbeehard44 says:
I have a different technique. I first apply some solder on 1 PCB trace, let cool. Place chip with a bit of downward pressure, make sure it's aligned, melt the solder. Then i just take advantage of capillary action and melt the solder on the traces and it'll just go to the pins. Too much=short though. Alot of flux helps.
Jul 17, 2008. 11:01 AMDerin says:
my friend said that he had a chip smaller than his thumb,I shoulda believed him!
Aug 30, 2011. 1:15 PMS33PlusPlus says:
Many chips are smaller than a grain of rice these days. Open up some broken electronics made in the last 5 or 10 years, I doubt you'll find chips with actual through-hole leads.
It's rather irritating when your parts *require* a custom etched circuit board to even be used.
May 21, 2011. 6:46 PMtinker234 says:
wow that is small hey could i make a robot that small hmm i wonder
Nov 3, 2010. 12:00 PMThe Mattster says:
There is one huge problem with your method. You put solder on each pad, which has thickness. Then you melt only one pad, when you do this all the other pads will keep that one pad from properly seating. As a result the entire chip will not be seated properly. If you could heat all pads at the same time, then this would work.
What I do is put solder on only one pad, then solder down that one pad. Then I head each trace and have the trace melt the solder. This will cause the solder to wick-up onto the pad. This way all the pads are properly seated.
I like your ideas of using the Flux marker, I didn't know these existed.
-Matt
Mar 22, 2009. 2:29 AMSquink81 says:
Thanks for the good tips. I have never done anything before............I am starting out doing whatever I can do with electronic stuff, because I started with PCs...um, this is my project and after reading your post I may have a go at this 3rd generation ipod headphone to motherboard connecton repair job. Tricky because the wires on the "board" part are torn from the chip pins.
Feb 7, 2009. 2:34 PMWesley666 says:
Just as a question, did you mean to buy a chip that small or were you just not paying attention? As well what are you building?
Feb 9, 2009. 7:46 PMWesley666 says:
Good answer! LOL
Jan 29, 2009. 4:57 PMAtomSoft says:
NO need for steady hands. Just get some Masking Tape and your set. Use a razor to cut a long thin strip and place over half the IC and then solder a few pins and remove tape and continue the rest.
May 25, 2006. 12:07 PMCheyyne says:
Nice! Doesn't really address the major problem, though, and that's the requirement of VERY steady hands...
Jun 25, 2008. 6:03 PMGrey_Wolfe says:
Take some dramamine before soldering (or dissecting tiny critters). Will steady your hands right up. lol People have been know to use this tactic to fool lie detectors as well. though at larger intake levels.
Jun 15, 2006. 8:16 PMxenobiologista says:
I took a developmental bio course once where we had to dissect zebrafish and mouse embryos and the prof made a point of telling us not to drink coffee on lab days =D
Jun 25, 2008. 5:58 PMGrey_Wolfe says:
I used to work for a company that made ery specialized computers. Since our order numbers typically were in the teens for a given year, we did everything by hand. There were only like two surface solder parts per system, but this is actually the same technique I used.
Aug 27, 2007. 9:10 AMsafdar says:
whats the point?
Sep 12, 2006. 11:41 PMg_c_c says:
Another good tactic is to put a drop of solder on each of the pads, use a flux marker on them, then use a torch to heat a razor blade to red hot. I've only tried it once, and on larger parts than that, but- might be worth a try.
Aug 9, 2006. 3:42 AMbfr says:
Cool. I didn't believe this was possible when I first heard about it, but now I think it's just as easy, if not easier than soldering leaded packages since bridges are harder to make. I use paste rather than solder though which makes a big difference. I also remove the solder balls with wick first so the chip sits flat. A chisel tip also helps a lot, fine tips aren't that great unless you have a metcal :-)
May 25, 2006. 10:51 PMwiml says:
Nice howto. One quibble— the dot actually indicates where pin 1 is. For most chip packages, pin 1 is in the top-left, but that's not always true. PLCCs have in 1 in the middle of one edge, and the dot is there. (The even poorer man's reflow is solder paste and either an oil lamp or a stove burner. Tricky to get the temperature profile right, but it works. I recommend an aluminum heat-spreader plate. Actually, I recommend using better equipment. :-) )
Jun 5, 2006. 10:14 AMbikeNomad says:
http://www.sparkfun.com/commerce/present.php?p=Reflow%20Skillet is a tutorial on using an electric skillet for reflow work.
May 26, 2006. 10:57 AMchuckcolby says:
If you put a piece of Kapton tape on the bottom of the chip and cut the tape so it is flush with the side of the chip, it will keep solder from going under the chip. This means less chance of out of sight shorts and it also makes it much easier to remove the chip by using Solder-Wick to remove the solder at each pad.
Jun 5, 2006. 10:12 AMbikeNomad says:
The tape won't work for this chip or any other center-pad QFN chip because they have to have their center soldered down for thermal reasons. Also, this kind of chip *should* to have solder underneath it, since that's where its leads are! If you solder without any going underneath, you'll have connections that will crack easily.
May 29, 2006. 9:22 PMjohnpombrio says:
I wonder if there are sockets for these surface mount chips. I guess you could also solder leads to the pads then snake the leads through the thru holes on the board. I watched a factory worker repairing surface mount stuff and she had the finest tipped soldering iron and a big magnifier!
Jun 5, 2006. 10:10 AMbikeNomad says:
There aren't sockets for these chips (other than maybe test/programming sockets, but you can't afford them). For one thing, the center slug must be soldered down for thermal reasons. But look at http://www.schmartboard.com/ for easily-soldered boards for a variety of package styles. For instance, this 20 pin chip should work with http://www.schmartboard.com/index.asp?page=products_csp&id=74
Unfortunately, the chips that I've had to use in this kind of package (switching power supply regulators) can't stand the extra lead length.
Jun 1, 2006. 12:18 PMbikeNomad says:
Instead of tweezers (which take a third hand if you're holding solder and an iron), you can do what I did and make a jig for SMD soldering out of a piece of wood and a piece of wire.
May 26, 2006. 10:18 PMkimota.nomis says:
This is a great instructable. Very useful. I would only suggest putting more emphasis on the flux. Effective use of of a liquid flux can make things MUCH easier. It helps get the pins and pads heated quicly, it also helps the soldier magicaly flow to the right places. The flux despenser I use has a little needle to release small drops of it for fine work like this. I hope you post more like this one, it may inspire someone to build something they otherwise would be afraid to.
May 25, 2006. 2:14 PMskipandmadge says:
The major problem with this technique is that the ground slug in the middle of the part usually needs to be connected to GND for properl electrical connection, heat dissipation, noise reduction (ground return current noise), and mechanical stability.
A hot air pencil for plastic welding (such as the expensive Leister Hot Jet S http://www.malcom.com/products/hotjets.php ) with liquid flux makes this a very easy process. Tin the pads of the part and the board as evenly as possible. Place the part in the proper location with flux underneath.
Apply heat with heat gun until the part literally "sucks" into place. While reflowing give a gentle tap on the side of the part (with tweasers) to nudge the part out of place so that it will naturally rebound into the proper location.
With inexpesive boards such as the one shown in the above photos, multiple reflow processes will eventually cause the pads of the part to be lifted. For part removal, use the same process (lots of flux and gentle heat). Once you can tap the part out of position you're reflowing and can then pull the part directly off the board.
For an inexpensive heat gun, the major consideration is to not use too much heat, and to MINIMIZE the airflow (otherwise you'll blow parts off the board).
Jun 4, 2006. 7:47 PMpellepeloton says:
Stereo Microscope would be nice but expensive so I bought handsfree magnifier glasses to fit into my head like a cap and with a hinge to push up the lenses. These are available at electronics hobby shops.
Jun 3, 2006. 7:46 PMnv0u says:
Reflow would work better, however instead of using a hot air gun (which could blow the thing off the board) try using an old convection oven. Set the temp to about 150F for 5 mins or so, then crank the temp up to 400F for about 1 minute max. Watch in amazement as all the parts seat themselves.
Jun 1, 2006. 12:06 PMbikeNomad says:
And one possibility for the hotplate is to get an old electric skillet from the thrift shop.
Jun 1, 2006. 9:25 AMprometheus314 says:
I've heard of alternate methods of soldering the tiny, tiny MLF packages by putting a bit of solder/solder paste on the pads then placing the board with the micro held on onto a hotplate to reflow the solder. Whole thing ends up being flat, and it permits soldering to the large ground pad.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:davidmerrill
currently a graduate student at the MIT Media Lab
