Of course, some of you might consider it snake oil, or find that it dosen't help. Your milage would vary. This setup might work for muffling other things i suppose
The method i prefer is to plug in the headphones to a mp3 player, and just play random stuff at maximum volume for a few hours, let it rest and do it again, a few times. Your milage may vary, and some people use pink noise at lower than normal volumes. Your milage may vary.
The instructable below covers a setup that's cheap, made out of things you'd have around the house (you arn't going to break in headphones everyday) and mutes the headphones so you can break them in without disturbing anyone, or ruining your hearing.
Remove these ads by
Signing UpStep 1
2 pillows or more.
1 plastic storage box, preferably close to same size at the base as the pillows
1 sound source, preferably nothing powerful enough to blow out the headphones, but loud enough to give em a workout. A MP3 player of some sort would be good for this
Although there are no 'rules' for burning in, for best results, play a mix of music, various tones/sweeps, or white/pink/brown noise - do this for a minimum of 100hrs, while taking short breaks every 16-24 hours or so. Also, be sure that sounds you are using are fairly high quality.
If you're on a Mac, there's an app called BurnIn that generates high-quality white/pink/brown noise and allows you to time/track the break-in process for your cans. It also works for high-end speakers and buds, and allows you to track multiple burn-ins. It's $1.99 through the Mac App Store, which is a bit steep for what it does, but it simplifies the process nicely.
