Introduction: Heated Grips Out of Houshold Items
items needed:
old toaster {broken is fine)
14 gauge wire
can of plasti dip
toilet paper tubes
Step 1: Prep Filament
Remove filament from toaster. Take one of the filaments and connect one end to negative on 12 volt battery. Take other end and clip to pos. on battery, keeping filament away from conductive surfaces. Slowly shorten lenght of wire connected too pos on battery until you get the filament to heat up to the point where it is hot but does not burn you. Cut filament to lenght at that point.
Step 2: Prep Tubes for Handlebars
Cut length and width of paper tubes to fit snugly around handlebars, "these can be put right over original grips". Then measure filament and calculate how many tracks u can put across tube. I used two filaments so i could space them 1/4 inches apart and fed both filaments, but one should be fine and end up spaced about 1/2 inches apart. Drill small holes (1/16 th inch) in ends of tube so filament can be woven onto surface of tube. The filament is run across face, then when pushed thru to back make the short jump to next (adjacent) hole then back out to the face for the long run across. See pic of tube face and back. Leave enough filament on bothe ends to soldier. The filament will not take sodier so you will either have to use crimp ons or put enogh sodier to surround filament and adhear to feed wire.
Step 3: Seal Tubes
After the filament is all threaded and ends to battery are preped make sure filaments are all straight dip the whole tube iin plasti dip and hang to dry. Repeat this 3 times. Then just put tubes over handlebars. I used electrical tape to secure them. A inline fuse should be used, and preferably tied into ignition switch so as not to kill the battery if it is left on. Feed 12 volts to wire ends and enjoy. It is recomended to put a 2 position swich and put a heavy duty resistor off one leg to give a high and low setting. Not sure on resistor values, mine is all shink tubed up and not visible. Hope u enjoy this. Mine get really hot on high and i usually use low.
Jury Rig It! Contest
