Remove these ads by
Signing UpStep 1Make your tees
You will need either two or four "tees". Two if you are putting your hose-in-hose system in series with your passenger heating system, four if you are putting it in parallel with it. Series means that coolant will flow through the hose-in-hose first and then the passenger heater core, parallel means coolant from the engine can take either route or both - hopefully it will choose both. Also, you can get 90-degree "elbows" if the routing of your hoses will be less kinky that way. Plan ahead!
You will need pieces of "half-inch" copper pipe - which is actually 5/8" O.D. You will need two-inch long pieces, because the Tees you have can't be used alone. Also, to merge two Tees (to make a four-way) you need a short piece of pipe. This will all become obvious when you look at the parts in your hand, and try to put the coolant hose onto one of the tees without first installing a bit of pipe. You can probably get the store to sell you short pieces of pipe, if they have it in a scrap bucket, since you only need two-inch long pieces.
While you're at the hardware store, get yourself the 3/8" aluminum tubing which will be your fuel line. It comes in a circular roll about 2-3 feet across, and you can straighten or bend it with your hands.
Most big hardware stores don't carry this stuff - but the small ones like Ace do, and they have copper tees and scrap buckets of pipe too.
The pieces in this image have already been soldered together. How to solder or "sweat" copper pipe is another instructable entirely!
10
comments
Add Comment
jerkey (author)
says:
jerkey (author)
says:
jerkey (author)
says:
Add Comment
