Introduction: Heatsinking Leds by Recycling Old Transformers
Picture of Heatsinking Leds by Recycling Old  Transformers
hi
in this tutorial i will show you how to recycle old transformers into led cooler
first :why cooling an led ,if you worked with power led before there is something you must know ,unlike normal small led which doesn't produce any heat (warm)
power led (1watt or more) produce's alot of heat if it ran at the maximum power in a previous instructable i made a 1 watt flashlight using 2 AA batteries , the maximum voltage for an led is 4.1 v , (2×1.5=3) so the led ran at a lower voltage ,in this instructable the led will run at 3.7-4.0 v (li-ion)
tip:the cooler the led was the brighter it will be ,lower temperature=longer lifespan
instagram.com/hamza_M.G
twitter.com/hamza_elgendy
follow =follow back
Step 1: What You'll Need
Picture of What You'll Need
you will need
1:an old transformer
2:thermal compound
3:electrical tape
4: 4×zip ties
5:power led
Step 2: Dismantling the Transformer
Picture of Dismantling the Transformer
how to dismantle the transformer
1:using a flat head screwdriver or a knife push up the metal peices from the marked areas
2:it will give you 2 shapes an (M) (|)
Step 3: Making the Cooler
Picture of Making the Cooler
how to assemble the cooler
1: stack five or more peices of metal ,and put a dot of thermal compound between then
2:hold them up together with a peice of electrical tape or zip ties (as seen in the picture)
Step 4: Attaching the Led
Picture of Attaching the Led
1:now connect the wires to the led as seen black(-) red(+)
2:push the two led terminals up so they don't shortout when you put them on the metal cooler
3:put some thermal compound on the led and attache it to the cooler as seen
thank you and please like an follow for more awesome projects
Step 5: Another Option
Picture of Another Option
you can also use the other shape to make a heatsink
rimar2000 (author)2015-01-05
1) Copper or aluminium are FAR BETTER than iron to cooling. I insist: FAR BETTER!
2) If you join them with a piece of electrical tape, you are annulling the cooling of that part. Electrical tape acts –in this case– like an overcoat or a shelter.
3) You could better take advantage of cooling, leaving spaces between "wings" of pieces of metal. The air could so flow between them.
HAMZAMG1999 (author)rimar20002015-01-05
thank you for the tips i really appreciate that
(1) i know that copper and aluminum are better but am recycling old transformers so i only got metal
(2)i used electrical tape in this project because i used a 1watt led so it doesn't produce that much of heat and it only covered a small area ,zip ties would have been better
(3)i wanted it to small ,slim and do the job ,fins would have worked better incase of a fan
About This Instructable
649views
10favorites
License:
Bio: HAMZA MOHAMED GAMAL ,, Egyptian ,,15yrs ,, twitter:@hamza_elgendy ,,instagram:hamzam.g ,,vine:hamzamg M.G
More by HAMZAMG1999:heatsinking leds by recycling old  transformers   powerful 1 watt portable led flashlight
Add instructable to:
