3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hidden Door Bookshelf
Wall to wall bookshelves that conceal a hidden door. Made without casters. Some people call this a bookcase.
My home office was messy. After I am done it will still be messy but now it is finished AND it has the secret feature. Well it was secret, till I wrote this.
In one wall of my home office is a 5 feet tall 2 feet wide door to access the storage area and crawl space under the garage. This is where we put holiday decorations, old stuff, and junk.
This wall was the perfect spot for floor to ceiling bookshelves, which I have done lots of, but it had this door in the middle of the wall. The perfect answer was a bookshelf that opened.
One day my father in law visited and we started drawing pictures of how book shelf hidden door could work, how to hinge, where to hinge, how to hide opening, etc. Following are the highlights from the journey that followed.
Step 1Calculate dimensions
calculate dimensions
First thing I did was figure out how big and where a bookshelf would need to pivot in order to clear walls and neighboring shelves with minimum gaps. I positioned the hinge point 7" in from the right and 2" in from the front of the cabinet. For sanity I made a scale drawing of shelves and cut out the rotating shelf shape.
With a pin I tried different pivot ideas, validating my measurements. The goal was to have the vertical gap between moving shelf box and fixed shelves be covered with a single 4.5" trim piece.
I added a better drawing of the key part of the unit, the moving center. The left and right side shelves are not to scale. This was made with visio, which lets you adjust the rotation point, so i could simulate the shelves opening to show clearance.The visio file is attached if can read it. the close up is where i notched the vertical trim to allow the horizontal trim to pivot "through" it.
---Ken
shelf.vsd160 KB
shelf.pdf(613x793) 10 KB
285 comments
1-40 of 285next »
May 3, 2012. 8:43 PMRangerJ says:
I love secret compartments. Great job!
Mar 1, 2012. 8:21 PMJust Bill says:
These things always fascinate me. Good job.
Feb 20, 2012. 11:29 PMtinker234 says:
wow awesome place to hide to bad its not a secret anymore
Oct 3, 2011. 12:04 PMAxlTxl says:
that's awesome!
Great job, kenbob!!
Sep 24, 2011. 2:43 PMszulli-randall says:
Secret Bunker: http://www.instructables.com/id/How-to-Build-a-Super-Top-Secret-Bunker-under-Your-/?ALLSTEPS
I'm going to combine these two to make a Secret Bunker Under my House with a Bookshelf door. It will be AWESOME! I will post a video when it is completed and when I find a good house to do it with.
Sep 27, 2011. 10:52 PMszulli-randall says:
It is going to be like the Bat Cave from Batman.
Sep 28, 2011. 6:43 PMfacilitator476 says:
You say Bat Cave, I say MAN CAVE
Sep 9, 2011. 11:35 PMfmachado1 says:
amazing
Jul 27, 2011. 10:56 AMbon0410 says:
OMG! That was totally awesome!
Apr 5, 2010. 12:12 AMhiggster says:
 Love you work man!
One thought that I recently had while installing baseboard in my house. I painted my baseboards white like your bookshelf and later realized that if they had been a darker color or dark stained wood the gaps wouldn't have shown as much. just a thought to help hide your door.
I appreciate your instructable, i hope to build one to hide my staircase.
Apr 5, 2010. 2:33 AMhelifino says:
What would be cool is if the crown were designed to open up the same way as the upper window channel "door flipper" on a 55-57 Chevy Bel Air hardtop does.  When the window is rolled down or the door opened, the channel (attached to the roof) flips up out of the way...
May 17, 2011. 4:21 PMIrecreateit says:
Do you have a different link to the vids for the project? The one posted does not seem to work.
Apr 16, 2011. 4:42 AMuniquo says:
i think this design would be good for a built in wardrobe. Instead of spending money on 2 plain wood/mirror doors, you could have one side that is the bookcase, therefore doubling storage.
Apr 8, 2011. 4:15 AMRichard May says:
I really like this and want to make a bookshelf / cabinet exactly the same. I have been through the measurements and am preparing a drawing to work from but am struggling with the top and bottom measurements. Any addtional information would be greatly appreciated. What is the dimension from the top of the steelwork of the door to the bottom of the 2" x 2" ceiling anchor? What is the distance from the bottom of the steelwork of the door to the top of the box section floor anchor. What is the depth of the top facia which hides the ceiling anchor and what is the depth of the second section of facia below this? Also what is the depth of the facia a the bottom of the cabinet.
What is the depth from the front face of the bookshelf to the plywood at the back?
Sorry to ask so many questions, Your design is so well thought out that I want to make my measurements as close to yours as possible.
Apr 11, 2011. 3:52 AMRichard May says:
Hi Kenbob. Thanks for the PDF, it was really useful. Sorry to keep asking questions but I wonder whether you would mind me asking some more dimensions. I notice that there are two trims at the top of the bookshelf, one hiding the ceiling anchor and one hiding the steelwork of the opening door, what are the vertical dimensions of these. There is also a trim / plinth at the bottom which hides the ground achor, what is the dimension of this?
To allow the door to open and close I notice that you refer to the cabinet "passing through" the trim and that it has a 45 degree angle on it. Do you have any additonal close ups of this, either additonal diagrams or photographs showing this? Any images showing this would be greatly appreciated.
Just one other question, did you use 3/4" MDF / particle board (18mm) or 1/2" (12mm).
Thank you for your help with this.
Apr 12, 2011. 1:27 AMRichard May says:
Hi Kenbob, thanks for the additional information. Much appreciated.
Feb 26, 2011. 6:22 AMRichard May says:
Kenbob,
Thanks for the PDF, and the explanation, it is exactly what I need and is greatly appreciated.
Jan 11, 2011. 3:15 PMquillin says:
Very nice project, thanks for sharing. I actually have a customer to whom I suggested this basic idea to, they want to hide a gun safe and have a very basic panic room at reasonable cost. I found your project while searching for ideas. I need a nice locking mechanism, that is hidden and or remote controlled that would work if power was off. I am thinking simple slide bolts on inside to secure once inside, but need something more solid than magnetic catch for keeping it closed, this will be in a large (16x24) red cedar walk-in closet so "bookcase" will probably have sweaters or linens in it . Have plenty of woodworking tools and knowledge but still puzzled on lock. Any ideas would be welcomed. I need the ideas fairly fast if possible. Thanks in advance. Again very neat project and thanks for sharing.
Randy
Jan 31, 2011. 11:48 AMjrh065 says:
How about running a cable from a lock to underneath one of the lower shelves(not too low) you could attach a hand grab to pull that would pull the cable and thusly open a latch. You could install other additional locks inside so that a would be attacker couldn't get in if he happened to find the cable pull.
Jan 5, 2011. 3:49 AMsanewby says:
Excellent - I like the comment below that mentions someone using this application on a bathroom door - now that's fun and somewhat cruel for those who are not in on the secret :D
Sep 24, 2010. 12:52 PMLittlehawke says:
great post. I have been wanting to do this with the closet/pipe access to the bathroom door in our den. It's ugly and we need more bookshelves. Unfortunately, there's not enough room on the one side of the door to do a full bookshelf so it would have to have some sort of ornamental dohickey or slide to the side instead of outward on rails that are hidden under and over the shelves when the shelves are in place. Really cool project!
Aug 31, 2010. 10:19 AMjerhpk says:
If you cut the crown on a bevel, you might be able to hide the edges better. Plus, the wood will add just a little bit more backstop to prevent the door from going too far back. (It's just a little more insurance. It will not replace the backstop you already have in.) This is a very nice project. Thank you for sharing. (Now I need to figure out where I can put one.)
Aug 27, 2010. 1:46 AMtechsean says:
I'm hooked on Bookshelf doors myself. I keep wanting to build one so I can show it off. Seeing your project just helps to encourage me to get off my duff and just do it. Great work.
Aug 25, 2010. 5:52 AMEmmettO says:
I love bookshelf doors! My upstairs bathroom is behind one. My family always has to show new people that visit the house. It kinda kills the "secret" but it's fun showing people. For anyone looking to do something similar, regular door hinges are strong enough (I did use the beefyer looking ones) just use 3 or 4 instead of 2. The real trick is to keep the bookshelf from sagging. A good peice of plywood screwed into the frame on the back is enough. I looked at bank vault doors when I made mine and realized that the door would have to have an angle on the opening side. I figured it would have to be a 30 degree or something. As it turned out it only needed a 10 degree angle. I made my hidden book with a fence gate latch that poked through into the bookcase and then attached a hollowed out book to it. My bookcase is short and only 32" wide so it isn't extremely heavy. Another trick is that it's only 6" deep to keep down the weight, so it won't hold all our large books but it does hold all our novel sized volumes. Sorry I did this before instructables existed, so I have no pictures of the build. The door has been working fine for many years.
Aug 26, 2010. 7:33 AMaskjerry says:
I had build t bookshelf door some years ago, to keep the bookshelf from sagging and to be sure it didn't bind when closed, I installed a rubber wheel on the floor pointing up. I.E. the wheel was upside-down so that when the door closed, it rode up onto the wheel which then took the weight of the shelf and 900 pounds of books. When the door was open, the hinge point took the weight and the plywood on the back of the door kept the frame straight. But when closed... the bookshelf was supported by three points... the two hinge points and the wheel pushing up. In 5 years the door never sagged and nobody knew it was there. Jerry
Aug 26, 2010. 10:15 AMEmmettO says:
I find the phrase "I had to build (a?) bookshelf door" intriguing. Was it for work? If so how did you find such an awesome customer? I can't imagine someone saying "Jerry if you don't build a bookshelf door, it's curtains for you!" :)
Anyway that is a cool solution, all this talk has made me want to build another bookshelf door to the downstairs bedroom. I'd like to use your rubber wheel idea if it's okay with you. If my wife doesn't kill me at the suggestion I can make a ible about it.
Aug 26, 2010. 11:24 AMaskjerry says:
At the time the wife and I had some .... er... "stuff" I didn't want the kids to get into... and I wanted a place to hide it. (grin) I knew if there were wheel prints on the carpet they would figure out that it was there pretty quickly. By putting the wheel in the base of the frame it solved the problem. It was in a basement area, so needing to step up an inch onto the new floor in the secret closet was not a problem. I cut a rectangular hole into the bottom board of the frame and sat the wheel (non-swivel type http://www.globalindustrial.com/site/images/n-picgroup/3281.jpg into the hole. It worked fine. I put in a bit of epoxy to hold it in place... didn't really need to however. You could attach it to the door so that it is up from the floor 1/4 inch or so... then have a plate mounted in the frame 1/4 inch higher... that would also work... sand the leading edge to an angle to make closing easier. I also had a spring mounted to push on a bolt... the door pressed into the spring. When I released the catch the door popped open about halfway... made it look kool... and easier to use. I had a gate latch with a string tied to it... it went up over the room to the other side where I had a way to trip it. I would be on one side, and the door would open across the room. First time I did it the wife jumped a foot... that alone was worth it.
Aug 26, 2010. 12:22 PMEmmettO says:
Ok I wasn't expecting that. . . 8-0
The remote switch is a nice touch. Gives me a few ideas for modifying a regular doorknob latch. With a rope or cable, I could turn the mechanism for a doorknob latch by attaching an armature or just using a lever handle doorknob inside the wall. That way two cables (one for the inside also) could open the door. In the old movies they attach the latch to a candlestick because it's camouflaged with the decor. I have a thermostat on the wall right by the door. I could make it so that by tipping it the door would open!
Feb 20, 2011. 1:36 AMapplefanatic says:
im gonna make one with heavy duty hinges and a basic bookcase + molding do you think this will work? thx
Feb 20, 2011. 4:23 AMEmmettO says:
No, the "basic bookcase" isn't going to have enough rigidity. It would sag, drag and quickly fall apart.
The backing needs to be of at least 1/2" plywood, preferably 3/4".
The shelves need to be very well supported. I routered a channel in the side boards, and then glued and nailed them in place.
Aug 25, 2010. 12:26 PMEmmettO says:
I did have the advantage of having mine open into the bathroom, so I could easily cover the gap with trim. You needed the door to open out so I can understand why you went with the pivot. Did you angle the strike side of the bookshelf? It doesn't look that way from your scale drawings. How did you get the turning shelf from hitting the jamb?
I can see why you went with the metal frame, If I was making one as large as yours I would go with the frame also.
1-40 of 285next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
71
Author:kenbob
I am an engineer in high tech. I like to make things.
