Hidden Outlet Camera
12,885
178
11
Posted
Introduction: Hidden Outlet Camera
Prank Challenge
Runner Up in the
Prank Challenge
have you ever had a great prank but no way to take a video without it being obvious?
this instructable will show you how to record a prank with the victim not seeing the camera
Step 1: Parts & Tools
parts
  1. an outlet (one that isn't installed
  2. an outlet cover
  3. a small thin phone (i used a blackberry)
  4. the protective casing for the inside of an outlet
tools
  1. a flat head screwdriver
  2. phillips screwdriver
  3. glue (or glue gun)
  4. heavy duty scissors
Step 2: Take the Outlet Apart
take out the screws in the corners
then pry the plastic part on top off
Step 3: Cut the Plastic Piece
cut off the plastic that is shown in the picture
Step 4: Glue the Bracket On
glue the metal piece on to the plastic that you cut off
Step 5: Glue the Buttons Back On
if your outlet had buttons glue them back in
Step 6: Cut Some More Plastic!
cut off three 3 in long 1 in wide and a one 1 1/2 piece of plastic from the outlet protector
  1. three 3 in by 1 in piece
  2. 1 1/2 in by 1 in piece
  3. 1 in by 1 in square
  4. two 3/4 in by 1/2 in
Step 7: Glue More Stuff!!
glue each of the three in long pieces onto the top and sides of the outlet cover (this will make it look like a bad installation)
then glue the two 3/4 in by 1/2 in pieces to the top of the bracket (on either sides of the screw)
Step 8: Drill a Hole
drill a hole in the middle of the 1 in by 1 in square (this will be how you hang it)
and glue it to the top of the two 3/4 in by 1/2 in pieces (make sure to also glue it to the plastic piece at the top)
Step 9: Bend It!
get the 1 1/2 in by 1 in piece and bend it to a right angle an inch down the piece
Step 10: Position and Glue
position the phone so its camera is behind a hole and put the bent piece so it holds it in the same place and it (the bent piece)
Step 11: Done!!
now put it on camera mode and hang it by the hole in the 1 in by 1 in piece
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
11 Comments
how do you keep the camera on so that it stays on I have a Samsung and the camera will eventually switch off
There is a setting so it DOESN'T shut off. It tends to run the battery down quicker but it can be done.
I like the idea and the way you built it but isnt it illegal to film anyone without their permission?
Usualy it's only Illegal if you have a "Reasonable expectation of Privacy" Some Offices may call it workplace harasment though !
G'day mate ? in the state of South Australia as long as you have a notice warning people you are filming them it's not illegal to notice could be as simple as smile your on camera
Now I can catch my sister eating my candy. No one will notice an extra outlet righhhht?
Lmao awesome Idea ! Another good reason to keep your old Smart Phone when you upgrade :D
Just think. If everyone sees this, we'll never know if we're being watched. We have no more privacy! I'm totally voting! :D
