........ I do apologise if it looks like I'm flogging a dead horse, this will be my last instructable on growing things with LED's.....honest.
I haven't found any commercial units that use high power LED's (then again i haven't really looked, and I like to maintain the illusion I'm being original :) ), so i figure this is probably different enough from my other attempts to be worth posting.
I probably better say that you really shouldn't be attempting this unless you have a sound knowledge of electronics and have experience working with mains electricity. Also there will be high voltage near a damp environment, which is generally not the best of ideas.
It also uses really bright light, and can probably do nasty things to your eyes if you stare at it, then again if you can read this you probably don't spend so much time staring at the sun/bright objects, so hopefully common sense will prevail.
Basically be safe, and don't attempt this unless you are positive you know exactly what you are doing.
Remove these ads by
Signing UpStep 1Parts
1x Large Tub.
1x High current 5v/10v supply.
4x 3w high power red LED.
1x 3w high power blue LED.
2x STP36NF06L MOSFET.
2x 100K 0.25W resistor.
2x 0.47R 3W resistor.
2x BC549B.
1x Aluminium Box.
1x Mains Lead.
Some wire.
Couldn't you just use all 5 leds in series with one current source?
website: www.ct-lighting.com.
sure we will not let you down,it's worthwhile to contact my company save your money.
http://www.growlightleds.com/pages/Grow-Tips-with-LED-Lights.html
Proper thermal compound will vastly improve heat transfer (if you doubt that one, try running a computer processor without thermal material between the proc and heat sink... smoke will probably soon follow... and not the good kind ;-) ).
Each and every led needs to be atleast 1watt each. Anything below that will be useless so don't use old leds out of toys or old boards, they simply will have too little Total lumens versus lumens per watt. You need atleast 10mm LEDs with 1watt per LED to supply enough light to the plant anything lower will not work. A good combination is a pannel made from 75% 1watt red high brightness leds, 20% 1watt blue high brightness leds and 5% 1watt amber high brightness leds. somewhere in the region of 660nm for red and 460nm for blue
There is also no effective difference in penetrative power for horticultural purposes between a 1W LED and a 3W LED. So anything over 1watt is just wasted. This means brightness has very little to do with the benefit you will get once you use 1wat leds. Don't confuse this with a pannel made from say 20 LEDs rated a 10watt as to one with 10 LEDs rated at 10watt. As the 20 watt pannel will use the useless 0.5watt leds verses the 10watt pannel that uses 10x10watt 1watt LEDs that are ideal. This has been tested and proven that 1watt single LEDs have great benefit to plants and anything less is just a waste of time and has no benefit at all to plants. The same applies with going brighter than 1watt has no benefit either.
Hope that may help some of you. Especially if you are growing indoors.
Also LEDs are more efficient than any other form of grow lighting available.
The commercially available LED growlights outperform all other growlamps from HID lamps to including high pressure sodium (HPS) and metal halide (MH) lamps.
So prepare to see other grow lamps become obsolete as LED growlight take over.
What matters is light output, normally expressed in lumens (or lux).
I'm sure that's what you're trying to get at, it's just that most people -including me - mentally equate wattage with the output of conventional lights types (incandescent, florescent, mercury vapour, sodium-halide, etc.) and can't "picture" what a 1-watt LED output looks like. It would probably be helpful to explain it in terms of output for comparison purposes.
Answers are appreciated
can you please verify your references in this information.
it seems as though you have posted the "1 Watt only" rule in every 'LED Grow Light' thread in instructables.com
Hoping you could shed some light on where it came from.
Mike
I don't see how plants could distinguish light from 100 1W LEDs from light from 10 10W LEDs. The energy contained in each photon is defined as hc/lambda and does not vary with the wattage of the source
You are however correct in saying you need big LEDs. Using small 5mm LEDs, you would need an absurd amount.
I concur with this "1-Watt LED grow light rule", but I must insist on a bit of reference, or a source for your view of it.
A german retailer sells 5mm 430 nm LED's
peak wavelength 430 nm,
viewing angle 16 degrees (±8°),
luminous intensity 150 mcd,
forward voltage 4.0 V
What do you think?
