Step 5Super extra bonus step!!
Enough of this silliness, here's what i did to change the value of a 47ohm resistor to 0.47 ohms.
1.) Slowly crush the ceramic type coating around the resistor with a pair of pliers, don't scrape it otherwise you'll damage the very fine wire.
2.) Once all the outer coating is removed unsolder the fine wire from one side of the metal end caps.
3.) Make a connection straight across the 2 end caps with the wire, and measure its resistance. if its not right make another another connection straight across with another length of the thin wire. this can get pretty fiddly.
4.) Wrap it up in tape
note: This is a very silly idea, the resistor cannot handle 3w's any more, and tends to get pretty hot when used in the circuit, i did this because I was desperate, and include it merely as a point of interest.
.47 ohm wirewound power resistors, 3W rating.
I "tinied" it, as the actual link is 252 characters long, but it's a search on www.mouser.com for the device.
Mouser does not charge a small order fee, and will ship internationally..
