3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
high power LED grow lights M.k2
Step 6Mounting the leds
Mounting the leds
The LED's get exceptionally hot, without some kind of heat sink they'll die on you, and you'll probably need a larger heat sink than you think, I chose to use the metal box I used to enclose the electronics as the heat sink, it's quite a bulky piece of meal, but it gets surprisingly hot, I'd recommend you use some thing larger.
The LED's I got had a star type heat sink attached to them, this makes it a bit easier to mount them, i marked out some fairly random positions and used some small bolts to hold the LED's in place, it would be a good idea to use some thermal paste to improve the heat conduction if you happen to have any lying around.
2 comments
Jan 11, 2012. 6:38 AMcodyg102 says:
Best affordable heat sink materials are (in order) copper, then aluminum - in case anyone's wondering.
Proper thermal compound will vastly improve heat transfer (if you doubt that one, try running a computer processor without thermal material between the proc and heat sink... smoke will probably soon follow... and not the good kind ;-) ).
Feb 9, 2009. 5:54 PMjarvist says:
If you don't have any heatsink compound, use some toothpaste - its still 100x better than having the inevitable air gap (ran my Core2 Intel CPU for a few months...). Just use a tiny amount an smear the LED around to get a nice coating. You might want to clean + wipe the box nicely first to ensure a good flat connection.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:}{itch
