Introduction: High Powered Bolt Action Pistol
This is a simple knex pistol. its bolt action or semi automatic and has a mag that hold 8 blue rods that can fire bout 40 feet
Step 1: First Make These Parts
this is the left grey rod piece
Step 2: Right Side
this isjust the right side of the gun
Step 3: Barrel
this is wat the left and right sides connect to.
Step 4: Assembly of Barrel
this is where u connect the left and right side to the barrel
Step 5: Continued
continued
Step 6: Handle
this handle is designed for low parts
Step 7: Add Handle
and handle in between th threee yellow conectors
Step 8: Bolt
this is th firing pin its simple and strong and th bit between the yelloow connector is a grey connector
Step 9: Add It!
how the bolt goes in(sorry bout camera flash)
Step 10: Magazine
simple 8 blue rod ammo clip
Step 11: Adding the Clip
just add onto the 2 snowflae pieces (the 2 rubber bands on to are to keep ammo in)
Step 12: Rubber Bands
add te main rubber band onto the bolt and on onto the trigger so it automatically cocks itself(lol)
Step 13: Ok U R Finished!!!!!
to load feed blue rods into the top of mag then pul back on bolt until trigger cocks
