the ones i made were 90 and 180v but the more
hv turns you do the higher the voltage(about 1v per turn)
this circuit runs best @2.4v-3v
Remove these ads by
Signing UpStep 1Materials.
toroid core(ferrite)
2n3904(sometimes others work too)
512ohom resistor
winding wire(0.15mm approx)
0.2-4mm as well!
neon glow lamp (i used maplin rx70)
time!
:-Have done some research as some ferrites have low or high Hysteresis -understanding that some saturate with magnetic field and some enhance field strength /Flow.....?
Cheers
The only problem I've got is the heat that builds up in the transistor(2N5294). My another doubt is, whether we could modify the setup to run a dc motor, like simple rectifiers or something.. Thanks for the great instructable. Been searching for a guide to increase DC voltage.
Have a look at the image I have attached it will show you a ceramic capacitor in parallel with the motor and give you an idea of what to look for.
P.S no Im not going to get one online, I'm not old enough. :)
Charles
I know what you mean about the high voltage, I once accidentally shorted a camera flash capacitor with my fingers, it was like being punched in the arm, and left a nasty little path of dead skin into my finger. I have been very cautious of high voltage since then.
I have never had good efficiency with this circuit, even the successful coil burns 60 to 70% of it's power depending on source current and voltage. Having said that it could drive a "low" voltage (fires at ~110v, stays partially lit right down to 70v ) Nixie tube for a couple of days on an 1000mAh 1.5 volt cell, which was fairly impressive. Currently I am looking into more efficient circuits. A 555 timer based version seems promising.
Drew
Great instructable 10 + rating and 5 stars
but i haven't got o-scope traces because mine broke so i have to make another circuit.
when i made a circuit i will take more o-scope pics.
[http://www.talkingelectronics.com/projects/FluorescentInverter/FluorescentInverter.html]
