3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
homde radio
homde radio
radio this instructible shows you how to make an basic radio.
Step 1
materials
coper wire
magnet
diod,
had phone
14 comments
Feb 5, 2010. 11:49 PMmemyselfand1 says:
Lern ot spel!
Behold, the English Nazi at work.
also, would there be any way of amplifying the signal?
Feb 28, 2010. 10:03 AMknektek says:
get a larger antennae. to get a stronger signal, the start of the antennae gets hooked up to a power source, ground to negative of power source. i think that it will work.
Feb 28, 2010. 10:19 PMmemyselfand1 says:
thanks.
just on a minor note, antennae is plural; antenna is singular.
Aug 14, 2009. 11:26 AMharryn81 says:
will this circuit work with today's headphones?
Sep 14, 2009. 7:52 PMpyra_builder_1337 says:
no you need the proper crystal style headphone
Aug 6, 2009. 12:55 PMshoomg says:
This is a basic crystal radio design. If you're interested in finding out more about crystal radios, google that term - there's lots of info about them on the web. You can also visit http://www.midnightscience.com which is an entire site about them.
Jul 27, 2009. 10:48 AMharryn81 says:
nice instructables.but where to provide power supply for this circuit
Aug 6, 2009. 12:52 PMshoomg says:
No power supply needed. This is a classic crystal radio that is powered by the received radio signal itself. The downside of this is that the signal strength is proportional to the length of the antenna you attach to it, so you need a long antenna to get enough power to hear the signal.
May 29, 2009. 5:00 AMextrordinary1 says:
back in the earlier days of radio, many used a dual coil set up. I used to have the design. I think it is in storage. The main coil acted like a primary transfomer coil to increase the amplitude in the secondary coil.
Mar 21, 2009. 7:18 PMbobkatzz says:
What "magnet"? This is a clasiic crystal radio design for the am broadcast band. There is no magnet associated with this project. You also will need a capacitor in parallel with that resistor for the earphones you get these days. A little more research on the author's part would have made it more useful. Good luck!
Nov 5, 2008. 5:45 PMXellers says:
What is the 47k resistor for? That is, if these are actually your instructions. It looks a wgole lot like you copied some diagrams from the net...
Nov 8, 2008. 7:17 PMDencohe says:
The 47k Resistor is to create a dc path from the diode to ground because the ceramic earphone needs a little bit of help doing this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:dciocoiu
I love aviation and Navel things. I am a big fan of Mythbusters. i also love science and chemistry so if you are a scientist or have some great science experiments please subscribe and we can put our...
more »
