3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
home made knife
home made knife
this is a knife i have constructed for fishing!
20 comments
Feb 13, 2011. 7:26 AMmdog93 says:
Did you use scrap materials (wood and metal) for this, if so what did you use and where did you get them?
I find it interesting looking at all the different items people reuse for their scrap metal.
Mar 1, 2011. 5:42 PMSylkhr says:
The reason you are supposed to use oil is that is quenches the metal more slowly than a water bath will. You'll have better results with your hardening if you use oil (old motor oil works well). Also, if you were heating your metal with a cigarette lighter, you aren't going to get anywhere near hot enough to harden it. In order to test if it is hot enough, you can use a magnet. When your steel becomes non-magnetic, it's time to quench. This is around 800 degrees C (1450-ish F). A blowtorch will work for smaller blades. I recommend Basta's ible' on this,
http://www.instructables.com/id/How-to-Build-a-Knife/
Sorry if this comes as condescending, I'm just trying to help.
~Sylkhr
Mar 1, 2011. 8:38 PMSylkhr says:
The brass rivets are a good idea. Glue is usually not enough to hold the blade on. Also, almost on the spelling, it's anneal, two n's
~Sylkhr
Feb 14, 2011. 10:59 AMmdog93 says:
cool. Good use of basic tools that. Was it a steel bracket?
Feb 15, 2011. 10:12 AMmdog93 says:
do you know what type of steel it was, how will the edge hold up?
Feb 18, 2011. 2:54 PMmdog93 says:
err both?
Feb 22, 2011. 3:39 PMmdog93 says:
ok thanks anyway
Apr 24, 2011. 8:48 AMinventor master says:
your kinfe may be defected and not as strong. if you add in two flat pieces of metal on both sides, wrap it with cloth and tape to prevent it from weakening. then take a hammer and pound it till is slim and smooth . then use a flame to make sure the blade is attached , and then pound it again to provide maximum shatpness. staple the tape and hot glue gun it. this will provide a stong sharp knife . hint lengthen blade
Feb 18, 2011. 5:30 PMArbitror says:
What is holding the blade to the wood?
Mar 1, 2011. 5:44 PMSylkhr says:
I was wondering about this as well. Is it some sort of glue?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:cobalt420
