3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
HOME MADE knife sharpener
  • last photo ←
I could never sharpen a knife worth a beans so this is my first attempt of making my own. It works pretty good. I have plans of making another one .
19 comments
May 19, 2011. 12:18 PMadillbeck says:
My pocket knife is a folding utility knife. I got it for my art classes where you were cutting stuff all the time, and it was a lot more handy than a normal box cutter.
Blade gets dull or chipped I just pop it out and put in another...
That being said, this could be nice for kitchen knives.
Feb 26, 2012. 8:23 AMpfred2 says:
I sharpen utility knife blades, a lot! I put a better edge on them than comes from the factory too.
Apr 3, 2008. 1:44 AMPrometheus says:
When sharpening knives, always cut into the stone, sharpening a knife like a barber's razor will lead to burrs which will cause the edge to deteriorate rapidly. Cutting in prevents these burrs, and produces a much finer edge.
Sep 9, 2009. 3:13 PMcl0ney says:
i'm no expert, but from what i've read from professional knifesmiths, they sharpen the edge until they get a burr, then they flip it over until they get a burr on the opposing side, then "strop" the burr off. this combined with a "relief" (according to what i've researched) will produce the sharpest edge possible. i also read that you want a +27° only on combat or utility knives, a 20-25° on pocket knives, and 12-18° on cutlery (cooking) knives or knives that should be razor sharp and for light purposes. i hope that helps.
May 1, 2011. 6:01 PMDeliciousMystic says:
As a professional chef, I would say that 12-18 on cutlery is very sharp, but also very frail... If you want to sharpen your knives a lot, every day or more, then go for it, but I put a 30 degree edge on mine, which is generally sharp enough to shave an arm with, and also can hold up to the repeated abuse from chopping and slicing.. and I only have to really get after the blade and re-sharpen once a week, and thats with hours on the cutting board every day.
Oct 6, 2011. 11:31 AMrenx99 says:
You are absolutely right about the smaller angles being frailer. They dull quicker even on a high quality blade. It was always explained to me that it's a trade off between easier to cut with (lower angles) and easier to maintain (higher angles). Finding that balance is important. I think I'll try a 30 degree edge on a kitchen knife and see how it holds up.
May 19, 2011. 7:32 AMspark master says:
I had one I made with a 78 rpm record player all guts removed except motor , then glued various grits to cardboard circles. Change grit by popping off ht e 'record" of grit, put on a nwe one.
But this is a sweet homebrew. Also go to Mother Earth news for other option belt sander home brew.
Feb 2, 2011. 1:33 PMLoneWolf says:
Awesome work!!! 5*
Nov 4, 2010. 6:15 AMpookie2 says:
looks very easy to sharpen knives now ..
Jan 2, 2010. 3:59 AMOle bally says:
 As an ole Pro Hunter, I often have to sharpen knives! To keep an edge on the knife, I use the top edge of the truck window pane. Open the window til its about 2/3rds the way down, jam the door open with yr knee and then sweep the knife blade along the glass edge, cutting into it at about a 15 degree angle. Do it quickly so as to keep the same angle of the cut throughout!! You will get a slight burr on the blade, but about 20 sweeps will keep it razor sharp! I strop it on my hand! Don't cut yourself!
Apr 3, 2008. 1:41 AMPrometheus says:
27 degrees is the accepted standard for overall durability and sharpness, for those who wanted to know.
Mar 17, 2008. 4:10 AMthewoodcarver says:
I like the idea since I am always sharpening knives but what angle are you setting it at or is it adjustable ? Is it made for the one stone you have there or can coarser or finer ones of different sizes be used?Instead of a slide show imho it would be better as a step by step maybe your next one can be .Very nice idea and something that I need to make.... adding it to my favs
Mar 18, 2008. 4:06 PMwaterppk says:
I use to have a knife sharpening kit when i was younger that had 3 settings, 15*, 30* and 45*, a 45* sharpen would last longer but be "duller" overall, whereas the 15* was like a razor but would dull quickly :)
Mar 17, 2008. 11:21 PMshilohjim says:
You did a fine job but if you don't have the materials just laying around it would probably cheaper to buy a Lansky sharpening kit. Sometimes it's just fun to be able to build it yourself.
Mar 17, 2008. 3:34 PMGorillazMiko says:
Awesome! I just use that brick thing and swipe it back and forth-- but this is way cooler. Nice job!
Mar 17, 2008. 6:02 AMmfunk says:
This is inspired! I have been looking for a way to sharpen my own. Favorited.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
73
Author:coolbeansbaby68(www.redneckgadgets.weebly.com)
Just a normal guy trying to make it in life .Good paying job but mindless sometimes .I enjoy making things in my garage to keep my mind going .. Its fun making something new but its more fun taking ...
more »
