i will show you how to make a homemade projector using mostly things you can find around the house. (remember to read the whole thing before you start because i am adding new info at the end as i learn more, im a beginner 2)
Step 1What you will need
you will need a large cardboard box, i used a cornflake box, you need a fresnel lens and a regular magnified glass i found the fresnel lens at a shop advertised as (credit card sized magnifier) for about 5 bucks and the magnified glass should be about 2inches across, you also need a bright light, the brighter the better but led is good because it needs to be cool or else you will cook the lcd i got the lcd from ebay for $28.00 and it allows you to plug anything into it. you will need a round cylender the same width as the magnified glass (i used pringles chip container) the last few things you will need are aluminum foil ,tape and scissors.
i bought that square looking led light of ebay for $20 but i cant use it yet because it needs a heat sink and fan, the other one runs cooler. 12v
what does the frensel lens do?
It doesnt seem to be required because of its placement... i Guess?
Dont trust me thou!
Yours is amazing.
I am using a sprint pocket pc with a touch screen so it might be a problem accessing media but it will do.
I just had a few questions?
DO i need a frensel lens?
What kind of light should i use? (how bright?)
and
can i use a slr camera lens instead of the magnifying glass u used in the front?
Thanks
and please help me!
Unfortunately, this does usually mean taking some expensive equipment apart - like a TV or computer monitor! - but the good news is that you could use equipment that isn't working properly. Look for a computer monitor with a broken backlight, because you don't need that part to use it for this build.
simbu
any other types of lcd can be used which are available in indian market in low cost?
simbu
9843774939
pondicherry
I'm currently looking for a fresnel lens. Can you please tell me if this one could do :
http://cgi.ebay.in/Fresnel-Lens-Replacement-Part-4-Nikon-SB-600-glass-new-/140560494012?pt=LH_DefaultDomain_203&hash=item20ba0eedbc
there's also a bigger one :
http://cgi.ebay.in/BIG-TV-100-INCH-DIY-PROJECTOR-TELEVISION-FRESNEL-LENS-/110687737615?pt=LH_DefaultDomain_203&hash=item19c580d70f
I'm asking as my LCD size is different from BOTH of these..so I've no idea if these lenses will or will not do
Thanks for the wonderful 'ible !!:)
You can get 55"X36" for $18.30 / yard. So obviously 55"x72" screen would be $36.6 plus shipping of about $15+.
http://www.rosebrand.com/product703/Projection-Screen-and-Rear-Projection-Screen.aspx
What I'm looking for is the fresnel lens..these are the most hard to get..especially since now nobody uses slide projectors !
This is also by Airmail, so the UK Postal service (Royal Mail) say that it should arrive in approximately 7-10 days.
If you are interested then do email me and I would be happy to help!
I found this on ebay :
http://cgi.ebay.in/3X-10X-Magnifier-Magnifying-Glass-w-LED-TORCH-UV-/250779781782?pt=LH_DefaultDomain_203&hash=item3a63a3ca96
and this :
http://cgi.ebay.in/First-Aid-Kit-Magnifier-Light-/280712282609?pt=LH_DefaultDomain_203&hash=item415bc181f1
I'll give these a try and if they don't work, seek your help !
Many thanks again :)
2 Cool
3 wow
4 is it easy?
2 :)
3 :)
4 its not too hard, i can make one from scratch in a day
Thanks in advance
