3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY- homemade projector
i will show you how to make a homemade projector using mostly things you can find around the house. (remember to read the whole thing before you start because i am adding new info at the end as i learn more, im a beginner 2)
Step 1What you will need
what you will need
you will need a large cardboard box, i used a cornflake box, you need a fresnel lens and a regular magnified glass i found the fresnel lens at a shop advertised as (credit card sized magnifier) for about 5 bucks and the magnified glass should be about 2inches across, you also need a bright light, the brighter the better but led is good because it needs to be cool or else you will cook the lcd i got the lcd from ebay for $28.00 and it allows you to plug anything into it. you will need a round cylender the same width as the magnified glass (i used pringles chip container) the last few things you will need are aluminum foil ,tape and scissors.
i bought that square looking led light of ebay for $20 but i cant use it yet because it needs a heat sink and fan, the other one runs cooler. 12v
148 comments
1-40 of 148next »
Sep 17, 2011. 9:26 PMguygalgut101 says:
Do I have to use the frensel lens or can I do it with out it?
what does the frensel lens do?
Oct 20, 2011. 12:53 PMbooliminator says:
I was wondering the same!
It doesnt seem to be required because of its placement... i Guess?
Dont trust me thou!
Oct 20, 2011. 12:24 PMbooliminator says:
I am in the process of attempting the same project.
Yours is amazing.
I am using a sprint pocket pc with a touch screen so it might be a problem accessing media but it will do.
I just had a few questions?
DO i need a frensel lens?
What kind of light should i use? (how bright?)
and
can i use a slr camera lens instead of the magnifying glass u used in the front?
Thanks
and please help me!
Jan 17, 2011. 11:10 PMsupreme-ette says:
What kind of projector is this? Could it project a movie/vid, or just a still image?
Jan 20, 2011. 7:01 AMsupreme-ette says:
Could I get that type of LCD from an out of used digital camera?
Aug 6, 2011. 6:15 AMosmith3 says:
you need an LCD panel which will take the type of video signal you wish to use it with - so, if you want to project Television, your LCD panel will probably come from a miniature LCD TV which has a Scart socket on it, or if you want to project a computer screen, your LCD panel will have to come from a flat-screen computer monitor.
Unfortunately, this does usually mean taking some expensive equipment apart - like a TV or computer monitor! - but the good news is that you could use equipment that isn't working properly. Look for a computer monitor with a broken backlight, because you don't need that part to use it for this build.
Aug 6, 2011. 6:18 AMosmith3 says:
this is ingenious!
Jul 9, 2010. 5:55 AMjothi.instru says:
hi.... can u say wat is that fresnel lens mean... is those available in shops...
Jul 30, 2011. 11:59 PMsimbu.rm says:
hi Fresnel lens very low cost of ebay.in for just Rs.675/- only
simbu
Jul 6, 2011. 12:53 AMpriyank9755648457 says:
from where i will get the lcd?
any other types of lcd can be used which are available in indian market in low cost?
Jul 18, 2011. 7:34 PMsimbu.rm says:
hi priya you can get lcd very low cost of ebay.in
simbu
9843774939
pondicherry
Jul 1, 2011. 10:07 AMmohsin2202 says:
triplet lens is best but u used Magnifying glass. tell me hows image quality? n focus.
Jun 10, 2011. 2:44 AMkatareprat says:
Awesome ! It inspired me to make my own one too :)
I'm currently looking for a fresnel lens. Can you please tell me if this one could do :
http://cgi.ebay.in/Fresnel-Lens-Replacement-Part-4-Nikon-SB-600-glass-new-/140560494012?pt=LH_DefaultDomain_203&hash=item20ba0eedbc
there's also a bigger one :
http://cgi.ebay.in/BIG-TV-100-INCH-DIY-PROJECTOR-TELEVISION-FRESNEL-LENS-/110687737615?pt=LH_DefaultDomain_203&hash=item19c580d70f
I'm asking as my LCD size is different from BOTH of these..so I've no idea if these lenses will or will not do
Thanks for the wonderful 'ible !!:)
Jun 22, 2011. 7:53 PMrcisneros says:
Check out this vendor. They sell screen by the yard for front and rear projection. You can check out their tutorial about colors to find out which one would work best for you.
You can get 55"X36" for $18.30 / yard. So obviously 55"x72" screen would be $36.6 plus shipping of about $15+.
http://www.rosebrand.com/product703/Projection-Screen-and-Rear-Projection-Screen.aspx
Jun 22, 2011. 9:33 PMkatareprat says:
Thanks a lot but I guess the screen is usually not the biggest problem..you can always use a wall !
What I'm looking for is the fresnel lens..these are the most hard to get..especially since now nobody uses slide projectors !
Jun 24, 2011. 12:02 PMrcisneros says:
Your missing the point. It's a giant lens. It's not just some cloth. The screen is the lens.
Jun 11, 2011. 3:12 AMkatareprat says:
alrite. Although I live in India and hence can't afford the one you suggested,I do understand that buying a lens bigger than the screen should not be a problem. So will try to find one !! Thank you !!
Aug 6, 2011. 6:05 AMosmith3 says:
Katareprat, it is very easy to get Fresnel lenses of many kinds here in the UK - if you would like me to buy some for you, I can get two the correct size (55 x 85mm) and send them to you in India for £6 (about 450 Rupees).
This is also by Airmail, so the UK Postal service (Royal Mail) say that it should arrive in approximately 7-10 days.
If you are interested then do email me and I would be happy to help!
Aug 7, 2011. 5:17 AMkatareprat says:
Thank you osmith !!
I found this on ebay :
http://cgi.ebay.in/3X-10X-Magnifier-Magnifying-Glass-w-LED-TORCH-UV-/250779781782?pt=LH_DefaultDomain_203&hash=item3a63a3ca96
and this :
http://cgi.ebay.in/First-Aid-Kit-Magnifier-Light-/280712282609?pt=LH_DefaultDomain_203&hash=item415bc181f1
I'll give these a try and if they don't work, seek your help !
Many thanks again :)
Aug 7, 2011. 7:30 AMosmith3 says:
no problem - just let me know! :)
May 24, 2010. 7:04 PMThe nerdling says:
1 Can it work with a olympos cmera LCD?
2 Cool
3 wow
4 is it easy?
Jun 20, 2011. 3:18 PMPINKmonster325 says:
In answer two your 4th question, YES!!!
May 14, 2011. 5:34 AMsanjay_lim says:
can you elaborate on LCD? , which make ? part no.?
May 27, 2011. 7:40 PMdelaneypratt says:
sucks how you have to be a pro member to download the PDF
Nov 13, 2010. 11:57 AMkiramaya says:
a normal maginifer will do the job,did u use a triplet lens
May 13, 2011. 9:23 PMswapnil24 says:
will you please make a video of each step that how you build it please...
Apr 18, 2011. 11:25 PMcefurox says:
what is your power source for that light? I have a strong lamp but I don't know how or what I should use to power it. Let me know, thanks
Apr 15, 2011. 5:28 PMCOASTER19 says:
what light did you use? I have tried a bunch of lights, and none seem to produce a viewable image.
Thanks in advance
1-40 of 148next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:porkypinekiwi
