Step 5Attach the lcd
iImage Information
i got this lcd from ebay for 28bucks just type in 2.5 inch lcd reverse monitor or something like that it needs to have the composite input (red yellow white plugs) if it only has the yellow one thats fine. so once you get it unscrew it and be very careful because the lcd is easy to break , take the metal case off the lcd and all the plastic filters until you can see through the screen(it will still be bury to see through) then place it infront of the fresnel lens (it should be upside down and backwards) when your picture is the right way on the wall, tape the screen on and you are done! now just put a lid on the box and stick the cables out the side of it
any other types of lcd can be used which are available in indian market in low cost?
simbu
9843774939
pondicherry
if so i just wanted to know if it was easy or hard to get the backlight off
http://electronics.shop.ebay.com/Car-Electronics-/3270/i.html?_nkw=2.5+lcd&LH_BIN=1&LH_IncludeSIF=1&_catref=1&_trksid=p3286.c0.m489
thanks,
locci
do a vid im making one
