3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
homemade ripstik / waveboard
This is step by step instructable how to make a cheap ripstik-waveboard. The orginal one is more stiff but mine works well.
Step 1Things you need from the hardware-shop
- Two pipes: 30cm and 20cm
(one should fit in the other one)
- 4 pipe clamps with nuts and props
- 5 webs for handsaw
- 50x40cm pice of 12mm plywood
- 2 rotating furniture wheels
- anti-sliding tape
89 comments
1-40 of 89next »
Jun 24, 2011. 2:35 PMinstruct39 says:
the footpads kinda remind me of kayaking paddles!
Jun 24, 2011. 9:37 AMbennyboy1507 says:
This looks really cool, i do wanna try this, but i was a little confused on how you use the hacksaw blades.
Apr 26, 2011. 9:25 AMCubie2 says:
I currently already have a ripstick but this has inspired me to make my own. It looks WAY nicer than the cheap plastic things they sell you at walmart. ;)
Jan 1, 2011. 4:17 PMxbox650 says:
what size pipe??
Dec 29, 2010. 9:15 PMxbox650 says:
if i dont want to use saw blades, than what do i use that would last longer but still fit in the pipe.(and) wouldn't the little pipe rub real hard agents the in side of the bigger pipe piece? (i need to know!!)
Aug 23, 2010. 5:10 PMshockhappy says:
i really wanted to make one since i saw your instructible! so i did, its currently in the prototype stages im working on a second one i kinda changed the torision bar method cuz i couldnt find pipes that fit nicely, so after wasting 20$ on various plumbing junk, i soon ralized i couldve gotten something that worked for 5$ ... but it came together in the end! i am pleased! :)
Aug 31, 2010. 6:39 AMcyclops0000 says:
where did you get those casters? i couldn't find anything that worked! what size caster is that?
Sep 29, 2010. 2:28 AMshockhappy says:
theyre from home depot, the size is 4 inch, i had to cram the sides together, becausr they were too wide fort the wheels... its had to find casters that fit
Aug 31, 2010. 6:51 AMcyclops0000 says:
is the aluminum bar necessary? or could i use wood?
May 19, 2009. 6:44 PMLilPurpleCow says:
How does it stay together, if the smaller metal pipe is inside the big ones? Is it screwed down or somthing? But if it was screwed it wouldn't spin, would it?
Aug 31, 2010. 6:45 AMcyclops0000 says:
i just bought some regular hacksaw blades from home depot. will 10 of those work instead of 5 thick hacksaw blades?
May 23, 2009. 8:12 AMLilPurpleCow says:
Oh, ok, although a saw blade sounds dangerous.. haha but the ripsik thing looks really cool, and this would probably save a lot of money, since they're like $70...
Jun 17, 2010. 7:16 PMDIY and STUFF says:
cheapest i think was $52
Aug 29, 2010. 2:40 PMcyclops0000 says:
i found one on craigslist for 15$
Dec 15, 2010. 12:27 AMvader406 says:
...but this looks so much cooler!
Jun 21, 2010. 4:01 PM01010110 says:
I'm planning on doing this but I think i'll use steel sheet instead of saw blades. a bit more expensive but much more durable in the long run.
May 22, 2009. 12:03 AMFriedo says:
Excellent work bro! I've been thinking about the design for my waveboard(got a knockoff at CircleK :) and wanting to improve it, now you've made it so simple! Maybe I'll follow your example and put up an 'ible on how to mod one! Cheers!
CircleK?
May 21, 2009. 5:53 AMkoecke says:
What is the purpose of cutting the hacksaw blades in half? Why not just leave them full width and stack a few more? Neat idea, thanks.
May 21, 2009. 2:30 PMracastro62 says:
I can see two reasons: - The wider the blade, the bigger the pipe diameter. That means more dead weight (bigger clamps, etc.). - The torsion characteristics depend on: Blade's alloy, blade's width, blade's thick. When you make the blade less wide, this means the whole pack is more flexible (it accepts more torsion). Putting both halves makes it more resistant, but always flexible. Think about those blade springs used in cars (no torsion, but flexion).
Jun 16, 2010. 4:50 PMDIY and STUFF says:
nvm bout exspensve
Jun 17, 2010. 1:09 PMracastro62 says:
Didn' understood your comment. Would you mind to write it using full words? I'm a (very) seasoned guy, and I don't send or receive SMSs in my mobile... Thanks a lot! :)
Jun 17, 2010. 7:07 PMDIY and STUFF says:
nvm means never mind
Jun 16, 2010. 4:49 PMDIY and STUFF says:
same here holy crap i didnt read yours till after i read his plus it would be less exspensive
May 21, 2009. 7:02 AMmacmccune says:
thats what i thought
Jul 16, 2009. 12:51 PMwinterflood_j says:
Hi, Interesting torsion spring technique ! How did you cut the hand saw blades? The ones I know of (hack-saw blades, usually for cutting metal) are extremely tough (and brittle, they tend to snap if abused) -Jonathan
Sep 26, 2009. 8:31 PMjamiespark says:
i did this once but if u use wood ones and layer a bunch it works
Sep 4, 2009. 11:01 AMsharlston says:
the anti-slip tape is grip tape and the furniture wheels are casters other than that its a great ible
Sep 3, 2009. 7:31 PMxerxesx20 says:
Nice. I wonder if anybody else has made one, if I made one i'd use toilet seat/lid combos for a laugh.
Aug 29, 2009. 3:12 PMitsthatguy says:
I've been trying to figure out how to put some kind of binding system on my ripstick but the plastic ripstick skeleton is just too weak to support them but with the wood it would be so easy just to add some wakeboard bindings or attach some shoes thx soooooooooooooooooo much
Aug 19, 2009. 1:00 PMboy9 says:
I made one just like yours and it does not work. :(
Jul 14, 2009. 5:17 PMUni Spin says:
can you put a movie to your great instr
Jul 12, 2009. 1:01 PMStoic0209 says:
How smooth is the ride? What kind of size and hardness of wheel did you use? (I'm making one in the same manner, thanks for the Instructable!).
May 21, 2009. 3:07 PMcowscankill says:
Does it wobble? There were tons of kids on those when I was in Korea. I mean, TONS. No skateboards. You like, wobble back and forth to move.
Jul 11, 2009. 4:42 AMbylerfamily says:
The ripstik was invented in Korea.
Jul 11, 2009. 10:52 AMcowscankill says:
Hahaha, That explains it.
Jul 12, 2009. 5:53 AMbylerfamily says:
Yeah,then the guy sold it to a company in the US.
Jul 11, 2009. 3:02 AMcyberowl says:
Lol, everything is relative. I bought a waveboard yesterday. I know that I paid an expensive price, but I'm in Switzerland, so everything is more expensive. I paid U$ 164.-. Yeah, I know, it hurts. The funny part is that only waveboards from Streetsurfing for selling here. No ripstik or others. I would love for my next board to inspire my self from ur guide, but on other side will have to get the tools and a place to make it... but will keep this great guide in mind. Cheers
Jul 9, 2009. 11:53 AMcristyrain says:
In my area (California) a typical hacksaw blade is 12 mm wide. Cutting that in half, to less than 6mm makes for a pretty thin piece, so even stacking up 5 of them, I'm not real comfortable that with a hole drilled in it, that it will withstand the twisting. Since you (author) are quoting dimensions in milimeters, and referring to a "handsaw" blade, perhaps in your experience the blade you cut in half lenghwise is wider than 12mm. Please let me know the width of the handsaw blade, after it's been halved. I can then decide whether to use the full 12mm or cut it down. Thank you!
1-40 of 89next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:wolfsshade
