3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
homemade ripstik / waveboard
Step 4Making torsion-bar spring
Take 5 handsaw blades and cut them longways in half.
Take two pices of 5mm thick aluminium 10x30mm.
Drill 3 holes in each. Two 3mm and the middle one 2,5mm and make a thread for 3mm screw in it.
Screw those plates the the board just behind torsion bar
Put all of the torsion-bar parts together.
Put the handsaw blades inside the torsion-bar.
Mark where the holes for screws should be and drill them in the blade-halfs
3 comments
Jun 21, 2010. 4:01 PM01010110 says:
I'm planning on doing this but I think i'll use steel sheet instead of saw blades. a bit more expensive but much more durable in the long run.
Jul 16, 2009. 12:51 PMwinterflood_j says:
Hi, Interesting torsion spring technique ! How did you cut the hand saw blades? The ones I know of (hack-saw blades, usually for cutting metal) are extremely tough (and brittle, they tend to snap if abused) -Jonathan
Sep 26, 2009. 8:31 PMjamiespark says:
i did this once but if u use wood ones and layer a bunch it works
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:wolfsshade
