Introduction: Hovercraft
more thrust less friction
Step 1: Matterials
two meat tray one smaller than the other(smaller the better)
1.5v motor
9v battery
and copper wire
Step 2: Construction
on the bigger tray make a square hole then put the inlet so it can fit stick it together
Step 3: Construction
take one match cut 4 into 1cm attach than on the 2 meat tray so it look like figure 3
Step 4: Finished
put every thing together like on figure 4 then u done and u now how to connect the wires
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    what can i use instead of the smaller tray
    what do u mean by inlet
    using matches for a propeller doesnt seem that practical
    This works just fine, everyone. DO NOT knock it until you make it!! Also there is another one like this by Dr. No. Nice instructible, keep up the good work and keep contributing. Don't let these critical nasty people discourage you. They are probably just jealous anyways...makes them feel better to knock people down.
    First off, you really need pictures if not a video of it working too. Also, the design doesn't look that great... It's better to have a skirt around the exhaust hole/s to catch the air and hold it for as long as possible instead of letting it escape quickly like this design would. That way there's a nice cushion of air. Also the fan placement is bad. The fan should be inside of the inlet hole instead of just part of it being over it. That would give you much more power. The fan should also be facing upwards so that way it won't always pull the hovercraft in one direction (unless that's what you want, which isn't what I'd want). You're almost just giving the basic idea of a hovercraft instead of how to actually build one as there are so few specifics about how to make it.
