3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to add EL wire to a coat or other garment
Step 3Plan the light layout
plan the light layout
Adding EL wire to clothing can be a good project for a beginner who has limited experience with electronics or sewing. However, you should be aware of the limitations of EL wire when you plan your design.
The center core of EL wire is made of solid copper, and like any solid wire it will break due to fatigue damage after repeated bending. On the human body, the elbows, knees, shoulders, and hips undergo the most movement. You can make the electronics last longer by mounting EL on areas that don't flex as much, and using stranded insulated connector wire (which can flex) to join the glowing pieces together inside the garment.
Plan the placement of EL wire with temporary markers like pieces of string, pins, or stickers, or make a sketch on a digital photo of the garment. You can follow the seams, or add axtra lines as desired. Decide which sections can be lit up with a single continuous piece of EL wire, and which will require multiple pieces.
Then, decide what path the wire will take for each section, and mark the entry and exit points. To make sharp "T" shaped junctions, you may need to run the wire inside the jacket at some locations.
2 comments
Jan 14, 2010. 7:33 PMCBence says:
 I think I saw this shirt in BRC!
Mar 24, 2010. 9:21 PMfreexrider says:
r u talking about Brissie Riders Club?
Mar 29, 2010. 1:23 PMgruffy says:
hahahaa i think he's talking about black rock city. the site of BUUUURNINNG MAN.
huge festival every year in the black rock desert (hence black rock city)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:enlighted
Founder / Chief Fashion Engineer of Enlighted Designs, Inc., specializing in custom illuminated clothing and costumes for performers. 10+ years experience with fabric-mounted LEDs, EL, and other lumi...
more »
