3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to add EL wire to a coat or other garment
Step 4Select and order the EL wire and inverter
select and order the EL wire and inverter
Measure the total length of EL wire that you will need, taking into account parts that will be hidden behind the fabric, and add at least 2-3 inches at the end of each piece to allow for stripping and soldering the ends (or sealing the un-soldered ends). If you are not experienced with soldering EL wire, order extra so you can practice. You may need to cut and re-strip the ends multiple times.
There are many sources for buying EL wire online, such as coolneon.com and worldaglow.com
Thicknesses:
thin (angel hair)
normal thickness (2.3 mm diameter)
extra thick/phat (3.2mm or 5mm diameter)
I prefer normal thickness, high brightness wire for most applications. The thin wire can be bent into finer shapes, but it is more fragile (better suited for a hat or a tiara, for example). The thick wire is more durable, being protected by a thicker outer plastic core, but it cannot be bent as tightly and may not be suitable for designs with fine details or sharp bends.
Colors:
There are two standard phosphor colors for EL wire: aqua blue (which is white with a clear sheath when off), and white (which is pink when off, due to the addition of a red phosphor in the mix). The other colors (pink, red, orange, yellow, lime green, dark green, dark blue, and violet) are achieved by filtering the aqua light through a tinted outer sheath. Aqua tends to be the brightest, although the brightness can be adjusted when you select your driver.
EL Drivers:
EL wire uses a high voltage and high frequency alternating current to activate the phosphor. An EL driver, also known as an inverter, is required to convert your low voltage DC power from the battery into a high voltage AC source. The length rating of the EL driver should be matched to the total length of glowing wire that you want to illuminate, regardless of whether it is wired in series or in parallel.
Some drivers will produce a steady glow in your EL wire, others have built-in options for blinking and sound reactivity.
4 comments
Jan 2, 2009. 2:11 AMZeshanAli says:
I'm trying to make a jacket with around 200 ft of 3 different colors of el wire and I was wondering what kind of driver or sequencer you used on your leather motorcycle jacket with el wires? I'm trying to make the wires on the jacket have a similar chasing effect as yours did. And would it be possible to find a sound activated driver for around that that length as well? Thanks =]
Sep 21, 2011. 9:28 AMchekoalonso says:
I find it very interesting and I like to make the costumes but not to buy the cable EL, can you tell me where I can get the materials? or some other name to be known?
Jul 17, 2008. 6:21 PMKANahas says:
Those "thin conductors" are called corona wires.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:enlighted
Founder / Chief Fashion Engineer of Enlighted Designs, Inc., specializing in custom illuminated clothing and costumes for performers. 10+ years experience with fabric-mounted LEDs, EL, and other lumi...
more »
