3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how-to build MACKRA a serb variant.
Project MACKRA was started after I saw the many problems with pre-built robotic platforms e.g. size, programability, mobility, need for batteries,PRICE, and most being dedicated to a single microcontroller.
the goals of the MACKRA project were to do the following:
1.create a cheap, and easy to manufacture chassis
2.draw all power from only a 5 volt source
3.no motor controllers would be required
4.only a small number of parts would have to actually be made
5.portable
6.easy to trouble shoot
7.all components would have to be able to be locally scourced e.g. radio shack, lowes, and local rc hobbie shops.
8.reliable
9.have the online community be able to readily accept it like the serb and arduino
the possible applications:
1. learning concepts of real time programming
2. learning about automation
3. used in a classroom setting as a alternative to LEGO robotics platform
4. learning about opencv and xna to provide stimuli to a system
5. learning about locomotion and coordination of simple movements to preform complex manuevers
6. demonstrate to students that this level of work can actually be accomplished without being a genius
7. developing navigation algorithms
8. demonstrating to students how many little systems can work together to achieve a task simply rather than one complex sluggish ýsystem
9. open creative possibilitys to students, as the platform can be made for around 80 bucks, and has plenty of room to grow.
Step 1Manufacturing: the base plate.
manufacturing: the base plate.
due to size differences in computers, the demands of the user, and materials available each MACKRA robot is different in size, but the same in functionality,
for mine i used a 1/8th thick peice of plexiglass cut to 150% scale to the perimeter of my netbook
then i took a servo and on each corner traced its outline and  used a square nut to mark were each bolt would have to have its hole drilled so the nut would rest securely against the side of the servo, effectively sandwiching each servo in place
then i drilled 4 holes, one on each corner to run the bolts that will hold the top plate on
13 comments
Oct 4, 2010. 9:23 PMpompom728 says:
I feel like a noob but when i copy the arduino file, paste it in arduino enviroment and click upload is gives me an error saying, " 'servo' does not name a type" and i get a whole bunch of this at the bottom
sketch_oct04a.cpp:1:10: error: #include expects "FILENAME" or
sketch_oct04a:1: error: 'Servo' does not name a type
sketch_oct04a:2: error: 'Servo' does not name a type
sketch_oct04a:3: error: 'Servo' does not name a type
sketch_oct04a:4: error: 'Servo' does not name a type
sketch_oct04a.cpp: In function 'void setup()':
sketch_oct04a:8: error: 'lefttop' was not declared in this scope
sketch_oct04a:9: error: 'leftbottom' was not declared in this scope
sketch_oct04a:10: error: 'righttop' was not declared in this scope
sketch_oct04a:11: error: 'rightbottom' was not declared in this scope
sketch_oct04a.cpp: In function 'void loop()':
sketch_oct04a:24: error: 'lefttop' was not declared in this scope
sketch_oct04a:25: error: 'leftbottom' was not declared in this scope
sketch_oct04a:26: error: 'righttop' was not declared in this scope
sketch_oct04a:27: error: 'rightbottom' was not declared in this scope
sketch_oct04a:31: error: 'lefttop' was not declared in this scope
sketch_oct04a:32: error: 'leftbottom' was not declared in this scope
sketch_oct04a:33: error: 'righttop' was not declared in this scope
sketch_oct04a:34: error: 'rightbottom' was not declared in this scope
sketch_oct04a:38: error: 'lefttop' was not declared in this scope
sketch_oct04a:39: error: 'leftbottom' was not declared in this scope
sketch_oct04a:40: error: 'righttop' was not declared in this scope
sketch_oct04a:41: error: 'rightbottom' was not declared in this scope
sketch_oct04a:45: error: 'lefttop' was not declared in this scope
sketch_oct04a:46: error: 'leftbottom' was not declared in this scope
sketch_oct04a:47: error: 'righttop' was not declared in this scope
sketch_oct04a:48: error: 'rightbottom' was not declared in this scope
sketch_oct04a:57: error: 'lefttop' was not declared in this scope
sketch_oct04a:58: error: 'leftbottom' was not declared in this scope
sketch_oct04a:59: error: 'righttop' was not declared in this scope
sketch_oct04a:60: error: 'rightbottom' was not declared in this scope
sketch_oct04a:64: error: 'lefttop' was not declared in this scope
sketch_oct04a:65: error: 'leftbottom' was not declared in this scope
sketch_oct04a:66: error: 'righttop' was not declared in this scope
sketch_oct04a:67: error: 'rightbottom' was not declared in this scope
sketch_oct04a:76: error: 'lefttop' was not declared in this scope
sketch_oct04a:77: error: 'leftbottom' was not declared in this scope
sketch_oct04a:78: error: 'righttop' was not declared in this scope
sketch_oct04a:79: error: 'rightbottom' was not declared in this scope
Oct 4, 2010. 10:37 PMpompom728 says:
Wow im retarted... there is no "" after "#include". the program should read...
#include ;
Servo lefttop;
Servo leftbottom;
Servo righttop;
Servo rightbottom;
int incomingByte;
blah blah blah...and so on and so forth.
was that a mistake or was that intentional?
Sep 13, 2010. 10:52 AMsunshiine says:
Pretty impressive work of art! Great job.
Sep 13, 2010. 11:46 PMsunshiine says:
Purdy huh? I can't wait, I like purdy stuff!
Sep 11, 2010. 1:32 PMacksheep13 says:
I plan to make this project and optimize it for a range sensor so it will be automomous without a computer that way i can make a mobile waiter for distributing food/drink
Sep 9, 2010. 6:55 AMalex12349 says:
it's awesome for me
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:kyle brinkerhoff(mormon.org)
hi i enjoy making ludicrisly over the top and complex devices.... only thing that helps with the ADD..... Being an ameture engineer, I refuse pick the easy option, but rather the one that seems best, ...
more »
