3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how-to build MACKRA a serb variant.
Step 5Manufacturing: final assembly
manufacturing: final assembly
final assembly is fairly easy, all you have to do now is set each servo into its correct mount point and wire them to the arduino, you can A. make a adapter that makes it easy to deal with or B. use the bread board . finally run your usb cable for the arduino through the hole in the top plate and plug it into your arduino. now run the four bolts through each corner and tighten them just enough to ensure enough pressure is placed on each servo so they will stay locked in.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:kyle brinkerhoff(mormon.org)
hi i enjoy making ludicrisly over the top and complex devices.... only thing that helps with the ADD..... Being an ameture engineer, I refuse pick the easy option, but rather the one that seems best, ...
more »
