Introduction: How to Build a Cargo Bike
Picture of How to Build a Cargo Bike
three years ago i bought a trailer to get my son to our swimming-place or to the nice playground that's a bit more far away than the small one around the corner. everything is fine with that trailer, though i always have some kind of insecure feelings:
- the trailer is quite low and altough it has a small flag attached to a stick that should make it more visible i think it can easily be overseen by cars on the street .
- sitting in that trailer the kid is around 1 meter behind me so i don't see what he's doing or how he's doing unless i turn around. not a good idea while riding.
visiting copenhagen in december 2008 i saw lots of cargo bikes there used for transporting kids so i decided to get me one. a quick look around convinced me that buying one is no option for me (much too expensive) so i wanted to build one. since this is the first bike i built i had to go through some trial-and-error situations, but in the end all came out well. after some research on the internet i decided to build a bike similar to the christiania bike. this is how i did it:
Step 1: Recycling an Old Bike
Picture of Recycling an Old Bike
i got myself an old crappy bike and cut it in two halves along the black line.
EDIT: If you want to build this make sure you use an old bike made from steel (check it with a magnet). Aluminium won't work!
Step 2: Frame Construction
Picture of Frame Construction
the next thing was to construct the front frame. i thought that bigger would be better so it became 100 by 100 cm. this was not a good idea, but more about this later. what you see in the pic is the frame made of steel tubes (welded) and the rear part of the old bike.
Step 3: Wheels
Picture of Wheels
the idea now was to mount the front wheels directly to the frame (see detail). looking at pics of original christiania bikes i saw that they put the wheel axis not in the middle but a bit more to the front of the frame. also i wanted to have a handlebar that can be adjusted in height, thus only two short steel tubes were welded to the back of the frame where i wanted to put the handlebar in.
EDIT: the wheel axis at christiania bikes is moved a bit to the front but still behind the pivot. mine was in front of the pivot... i changed it after riding the bike for a few months and now steering is much easier :-)
Step 4: Front Frame Test Assembly
Picture of Front Frame Test Assembly
first test assembly: looked good :-)
Step 5: Rear Part
Picture of Rear Part
now to the rear part of the cargobike. i took the handlebar's pivot from the old bike, welded it to a steel tube and then welded the steel tube to the rear part of the bike. the angle you see in the pic between the steel tube and the pivot was again something i saw on a pic. this was the second bad idea to do - more about it later.
EDIT: after using my trike for some time with NO angle and some discussions later (see comments below) i must say it would be better to have an angle between the steel tube and the pivot. measured at a christiania bike it should be 9.5 degrees in the direction you see in the pic - which is the opposite direction of the standard castor angle on a bike.
Step 6: Connecting Parts
Picture of Connecting Parts
the inner tube of the handlebar's pivot gets welded to the front frame and then i did a ...
Step 7: Test Assembly II
Picture of Test Assembly II
... second test assembly. it looked great and i was quite happy.
Step 8: Making It Stronger
Picture of Making It Stronger
the rear part undoubtedly had to be stronger. so i added a second steel tube and a bracing.
Step 9: Handlebar
Picture of Handlebar
the handlebar consists of three tubes connected with 90 degree tube-angles.
Step 10: Brakes
Picture of Brakes
for the brakes (old ones from another bike) i screwed two steel plates with holes to the frame.
Step 11: Test Assembly 3
Picture of Test Assembly 3
test assembly 3: looked good. but as i tried to ride it i recognized i was nearly unable to turn the bike in any whatsoever direction. after some research i discovered that the angle of the pivot might be the problem. also i read that any pedal-driven vehicle above 80 cm in width has to be checked by the authorities here. since i wanted to avoid this i had to make it smaller.
Step 12: S**t...
Picture of S**t...
cutting the front frame, making it smaller and building a new pivot (taken from another old bike) were the next things to do.
Step 13: Frame
Picture of Frame
finally the frame was done. what followed was to mount the brake cables and all the usual stuff to the bike. one issue that had to be solved was how to operate the two front brakes with one handle. talking to a friend he came up with a nice solution: (see next step)
EDIT: two more improvements were necessary after some time
1) mount some cross beams between the handlebar and the front frame (see pic 2 in this step) and
2) mount some more cross beams on the lower end of the pivot to stabilize it further (see pic 3+4 in this step)
Step 14: Adaptor for the Brakes
Picture of Adaptor for the Brakes
this adaptor delivers the power of one handle to two brakes simultaneously. and last but not least one needs a ...
Step 15: Final Assembly
Picture of Final Assembly
box to transport kids and things with the bike. that's it :-)
further improvements will be some cat eyes and other security stuff.
Step 16: Edit: Adjustable Steering Damper
Picture of Edit: Adjustable Steering Damper
after improving a few things (see the edits in some of the steps above) the last thing to do to complete this battleship was to add an adjustable steering damper. since these things can be quite expensive i built my own with a spring and a turnbuckle. works fine :-)
Step 17: Edit: Final Considerations
Picture of Edit: Final Considerations
the measurements in this pic are the actual ones of my bike. if i would build one like this again i would change some things:
1) don't make the handle bar straight. it should be bent like in the drawing. this will save some space and allows to sit more straight.
2) use 20'' wheels for the front. this lowers the center of gravity and improves the handling on sloping grounds. the problem that arises is that you can't use the simple pivot i used - there's not enough room left between the ground and the box. a solution would be to
3) use conical roller bearings (these are parts used in cars) instead of the pivot .
4) don't build that double-break-thing for the front wheels yourself. you can purchase a better thing known as "double barrel brake lever" quite cheap which allows for independent adjustment of the two brakes.
5) adopt the size of the box to your needs. for me it's fine - i need to transport two kids and stuff at the same time (some times there are 4 kids and their things in the box...). if you don't need that much space make it smaller! because even the slightest wind is a burden if you have to pedal against it... one way to go would be to build a box from cardboard and to refine it until you think it's good. then build it from wood.
6) a camber of wheels improves the handling even more.
7) before building the frame watch some of these videos, this will help a lot: http://www.youtube.com/results?search_query=Bicycle+Frame+Building&aq=f
if you ever build a bike like this or get infected by the cargo-bike-virus and build some other construction please let us all know. post a pic or a link in the comments-section!
emmettg2 (author)2017-06-05
I built a cargo bike similar to yours but when I turn the cargo ares in the front the bike frame leans. If you turn too far it pulls the bike over. Do you have any idea of what causes this and how it can be fixed. My theory is that it is similar to the "wheel flop" that you see on chopper motorcycles and the overall wheel base might be too long.
carkat (author)emmettg22017-06-13
hi, hard to say from a distance. do you have a pic of your bike? there could be a few reasons for this... e.g. if the 90 degree-angle of the pivot is not really accurate the bike leans in turns (this is used with christiania bikes so that it feels more natural to ride the bike in turns). also if you turn too far the weight gets probably shifted to one side while the effective wheelbase gets smaller (think of the points where the wheels touch the ground: with a 90 degree turn they are all in line while the weight is on one side - this can't work :-) ). if you're riding too fast the weight wants to keep on track in turns while you try to move it somewhere else, this can pull your bike over, too, as i experienced in person a few times ;-)
DanielJ185 (author)2016-08-29
Hi guys,
im trying to find some drawings to build this bike in the image. if somebody can help me, i will very appreciate.
any new pls write me : dalarcon798@gmail.com
Thanks in advance!!
Regards from Perú
carkat (author)2016-06-25
..aaand another one did it :-) joel from sweden sent a link to a documentation of his bike: http://recycle-design.blogspot.se/2016/05/slutpro...
check it out!
pozole13 (author)2013-05-05
Slowly but surely working on my first one. I am using 20 inch wheels that I found at some garage sales.
I am realizing that I am going to have to use tapered (conical) bearings rather than the steering fork due to the lower ground clearance. I understand that Christiania uses tapered bearings as well.
There are not a lot of instructions online how to set up a shaft and tapered bearings for a cargo bike, but there is one here at 2:20-3:44 that might be useful for some.
http://www.youtube.com/watch?v=XSOTP1xj36Y
carkat, is this the way you envisioned the conical bearings working?
As always, thanks!!
mdubois6 (author)pozole132015-06-10
hello, i also have 20'' wheels, but i seem to have enough clearance under the pivot (even if it came from a tall bike, my wife's bike pivot is 3,5cm shorter), 4cm, without tyres
carkat (author)pozole132013-05-05
hi,
yeah, this would be the pro-approach. i was thinking of using bearings including pre-made housings and somehow attaching them to the frame so there's no lathe needed. examples are here , here and here (e.g. hub II).
another approach would be to adjust the clearance so you can use the bicycle head tube like this guy did here
dottorbiker (author)2015-04-12
Dear friend,
thanks a lot for your instructabls: it's great and now I must make my cargo bike!
I read many times your guide but I have some questions:
-for the cargo are good square steel tubes 30 mm*30 mm (2mm oh thickness)? and for the frame/pivot tube?
-the angle of pivot is right in my photo?
-the dimension are good?I'd like to have a big cargo bike!
thanks for your support and sorry for my english!! =)
Michele
carkat (author)dottorbiker2015-04-13
hi,
the overall measurements look good to me. for the cargo area i used 20 x 20 mm tubes with 1,5 mm wall thickness and for the frame it was (i think) 25 x 2 mm. the pivot tube is taken from the donor bike (see step 5). and the angle looks perfect :-)
good luck for your build!
SimonM4 (author)2015-01-09
Hi, I'm inspired by your project and very impressed. I was looking at another cargo trike project on instructables... the person has put the pivot at the back of the cargo section (see pic of red cargo trike below). The result is that it is a little bit higher than putting the pivot beneath the cargo section so it should reduce the possibility of the pedals hitting the ground. Do you think there are any disadvantages to doing it like this? I was wondering if there would be more stress on the pivot doing it this way?
carkat (author)SimonM42015-01-10
hi,
the problem with this position of the pivot is that steering becomes problematic. it works well with (very) high loads and when you're (very) slow, but other than that the steering tries to break free.
imagine you have a two-wheeled cart you DRAW behind you with one hand. the cart moves in the direction where you go / where you draw it to. now, if you PUSH it with one hand it would go in the direction it thinks is best :-) the same happens here pushing (pivot in the back) vs. drawing (pivot underneath slightly in front of the wheel-axis).
if you have problems with pedals hitting the ground you could either change the cranks to shorter ones (which also helps with higher load since pedalling becomes easier) OR maybe find a bigger bike for the project. usually a 26'' should do.
SimonM4 (author)carkat2015-01-10
Thanks for the gems!
I'd like to use a handlebar pivot as you have done under the cargo section but it seems that it makes the bike to low? I'm a bit confused as to why that doesn't work...Does the pivot hit the ground? If I use a bigger bike will that solve the problem?
mmmh, sounds strange. if you were able to pedal on the bike (which i supppose) before you cut it to make the cargo bike you should be able to pedal now, too... and no, the pivot should never hit the ground...
the only thing i can imagine is that you have a really long handlebar pivot (e.g. as some dutch bikes do) which is too long to place it under the load. in this case you would have to shorten the tube.
do you have a photo or drawing of your bike? maybe that would help to figure out the issue.
Excuse my confusing way of explaining this! I haven't made anything yet- although I'm planning to start next week. I saw through reading the posts on here that there was an issue with using a handlebar pivot as the pivot for the cargo section (I saw that you recommended the possibility of using a wheel hub bearing instead). Please can you explain why using a handlebar pivot is not a good idea? I'm quite keen to use a handlebar pivot to save money and make use of the part so it'd be great if there is a way to...
carkat (author)SimonM42015-01-11
there's no problem with using the handlebar pivot. using the wheel hub bearings just allows for more clearance to the ground. and it looks more professional ;-)
SimonM4 (author)carkat2015-01-12
Good news 8) I'll post some photos of how we get on..
urbanyeti (author)2014-11-05
Hi, was just wondering about the mesurements from the bottom brack to the pivot of the cargo box.
carkat (author)urbanyeti2014-11-05
hi, that depends. have a look at step 17 in this instructable:
https://www.instructables.com/id/how-to-build-a-car...
there you have some measurements from where you can calculate the distance. hope that helps!
kehrlich1 (author)2014-08-04
my first foto
kehrlich1 (author)2014-07-14
Hello Mr. CARCAT how and what you welded steel pipe and dural frame bicycles? TID? MID? CO2? I'm starting to build a coffee bike
Thanks for the answer I'm from Czech Republic
carkat (author)kehrlich12014-07-14
hi, with my first bike i used CO2 (it's called MIG/MAG here, don't know the english term). in the meantime i'm using TIG (WIG in german) which gives much nicer results. if you know how to weld i would recommend the latter one.
all the best for your build!
kehrlich1 (author)carkat2014-07-15
Hi, sorry, sorry, sorry, yesterday I tried frame with magnet and it is steel. Everything will be sorted out is simple. Next week we start building :-)
carkat (author)kehrlich12014-07-16
hi,
no worries! all the best for your build!
My problem is: how to combine old and new pipe frame, which is made of iron(steel). The frame of the bike is dural (aluminium)
carkat (author)kehrlich12014-07-15
i'm afraid this will not work. at least you can't weld those materials together. a long time ago i was working on something similar and a friend of mine suggested to glue the pieces together (steel and aluminium) with special industrial-style glue. but i don't have any experience with his (i dropped the project back then). i guess it's better to find an old steel frame and start over. sorry i don't have better news...
kehrlich1 (author)carkat2014-07-14
Hi.So it is better to TIG weld. A weld together a frame alloy wheels and steel pipes, or using the dural tube?
hmm, i am afraid i don't really understand what you mean. maybe you start with the front part: welding the tubes for the cargo-box. the next step then would be to make the rear part and connect everything. hope that answers your question?
Ds_man made it! (author)2014-03-04
Hello Mr.Carkat
I have no words to express my gratitude to you !
Not only that you gave me self confidence and make
me believe that i can do it,
But you also showed me the way . . .
I Used the Welding machine only once before this project,
Hope i welded them strong enough so thay
wont fall apart when i'll ride :-)
When I ride this Cargo-bicycle
I am sweeping so many compliments from passers-by thanks to you !
carkat (author)Ds_man2014-03-06
wow, what a beauty! thanks a lot for sharing your work here, it's always great to see other builds and improvements :-)
just one question: how long approximately did it take you to build this from start to finish?
thanks,
carkat
Ds_man (author)carkat2014-03-08
The first 3-4 days i worked intensive, but after that i went once a week and it tool me about 6-7 weeks to the final result.
As you may know It never really ends, there is always room to improve
But in the meantime I'm satisfied with this,
The only thing that bugged me a little is when traveling at high speed the handlebar get out of control which is a bit scary, maybe the "Steering damper" you came with can solve the problem?!
i was thinking of taking a hydraulic arm from an old car back door, And try to connect it to the central pivot, it might give some stability to the handlebar... (I saw something similar done at the original Christiania bikes)
if i'll do it i'll let you know.
Thanks, Dvir.
paco perez (author)2013-11-17
https://www.instructables.com/you?show=PUBLISHED
paco perez (author)paco perez2013-11-17
thanks Mr. Carkat
pozole13 (author)2013-05-11
Thank you for the suggestions and the link to the video, which was really inspiring as well! I might add the extra tube to raise the bike as in the video. Another suggestion from a friend who builds motorcycles and rotorcraft was instead of machining a pipe, I could also cut a tube with a slightly smaller diameter and use it as an inner sleeve to hold the bearing cups in place.
mick bull (author)2013-05-01
Think you have made a dam good job, ive just made 1 for my dog who has arthritis and have used tips from many builders including yourself, glad you were there to help me. Have a look at mine if you have time and tell me what you think, many thanks Mick. http://tyler-trike.doomby.com/
carkat (author)mick bull2013-05-03
thanks a lot for sharing your build, it looks amazing! hope you have a lot of good times with your dogs at the beach :-)
drozio (author)2013-04-07
here are some pic, work in progres. hope you like them
carkat (author)drozio2013-04-08
wow, looks awesome! thanks a lot for the pics :-)
drozio (author)2013-04-04
hey there, I am trying to build the same cargobike, but I have some problem with the cables to the rear end. to the brakes and to the gear (speeds), I didn't like the way you put them, it look like a big mess. do you have another solution?
dotan
carkat (author)drozio2013-04-06
yeah, for running the cables along the frame i'm using short pieces of steel tubes welded to the frame. the inner diameter of these tube pieces is chosen according to the outer diameter of the cables:
but be sure to run the cables from the handlebar downwards in the middle of the back of the box, so that if you turn the box the cables don't get in your way.
pozole13 (author)2013-02-15
I thank you again for this wonderful tutorial and the drawings of the fork pieces. I am in the U.S. and using some U.S. measurements, but this is really a great contribution to those of us who are trying to be "sustainable" all over the world. I am looking forward to getting a successful build and then tinkering with the bike for some time to come.
Sorry for all the questions, but I am curious about the second (lower) long steel tube in Step 8. It looks like it has a nice bend in it, and I am curious as to how you did that. Did you measure the radius of the bend and use a tube bender, or did you bend it in some other ingenious fashion? I can't thank you enough for your work!
carkat (author)pozole132013-02-17
hey :-)
the bending was really low-tech. i filled the tube with sand, closed the ends with tape and bent it over a small piece of tube with a bigger diameter i had lying around.
in the meantime i built myself something similar to this: http://youtu.be/PqZoEd8iNjk which is a good investment if you are going to bend tubes more often than once in a lifetime.
carkat (author)2013-02-01
oh, thanks a lot for clarification! never heard of gauge before.
i didn't make any mods since the last one mentioned in the i'ble. but be careful: if you take building this bike seriously it could happen you won't be able to stop building cargo bikes. they are always open to mods and improvements - an endless source of inspirational tinkering :-)
pozole13 (author)2013-01-31
Sorry it took a while to reply, the reCAPTCHA on this site has been a problem. Anyways,thank you so much for the explanation and drawing of the "forks". FYI, Gauge is a U.S. measurement for steel thickness, and 11 gauge is the equivalent of 3mm. Thanks again, really excellent work. Any mods or updates on your cargo bike?
pozole13 (author)2013-01-21
Great work and really inspiring! I have purchased some square tubing and am ready to go. Just a couple of questions:
1. What did you use to create the forks for the wheels on either side of the box? Was it something like 11 GA steel, and if so, what was the diameter of the holes and rectangles?
2. Did you use GMAW welding process, GTAW or something else?
Awesome work, this bike looks great!!
carkat (author)pozole132013-01-23
1. hm.. don't know what "11GA" means. they are made of ordinary mild steel, thickness is 3mm, other measurements see images below.
2. GMAW. but if you're able to do GTAW welding i'd recommend it. looks much better and the stability is the same.
carkat (author)carkat2013-01-23
what i forgot to tell you about the measurements: there are different diameters of wheel axles possible, so you might want to measure the diameters first and then change the diameter of the hole accordingly (i got 10mm axles). and make sure that there is enough space left between the whole and the upper end of the fork so that you can turn the nut easily when mounting the wheel.
"hole" not "whole" in the last sentence, sorry.
tobiasfjeld (author)2012-11-20
Very good post, starting to make my own right now.
camping crazy (author)2012-10-15
how do you turn i wish i had a welder id try somthin like that nice instructable
strangebike (author)2012-07-18
I love the point you have left in the cock up's as well and not been too scarred to tell anyone. A great ible I'm possibly coming down with something!!
About This Instructable
418,643views
518favorites
License:
More by carkat:fail: a full tilting 3-wheeled cargo bikebuild a 2-wheel cargo bikehow to build a cargo bike
Add instructable to:
