How to Clean a Coffee Grinder
34,884
193
38
Posted
Introduction: How to Clean a Coffee Grinder
There are lots of ways to clean a coffee or spice grinder out there. I've previously tried using bread but found it gummed up and wasn't very efficient. I also tried both sugar and salt, but those seemed too fine to really grab all of the oily coffee grounds.
So how do I clean my coffee grinder? A small amount of rice and a paintbrush or toothbrush. Easy! :D
P.S. Don't ever clean your coffee grinder? You should give it a try! The oils from the coffee beans can go rancid over time, so you may be pleasantly surprised at how much better your coffee tastes after cleaning your grinder.
Step 1: Add the Rice to the Coffee Grinder
For most standard size coffee or spice grinders, you only need 1/4 cup rice. You can use any type of rice you want as long as it's dry and uncooked.
If you have a larger coffee grinder, just add enough rice to cover the blades entirely.
Step 2: Grind It Up
Process the rice until it is a fine powder. It should change in color slightly - turning a very light tan.
Step 3: Pour Out the Powder and Clean Up the Grinder
Tip the rice powder into the trash or a compost bin and then use the paintbrush to scrape out any excess powder.
If your grinder is especially stinky (or if you use it for both spices and coffee!), use a paper towel dipped in plain white vinegar to wipe it out. Keep the lid off and let it air dry completely before using again. The vinegar smell will go away as it dries.
And there you go! Enjoy your fantastically clean coffee grinder. :D
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    38 Comments
    Brilliant, and helpful!!! I’m looking forward to my “improved” cup of coffee tomorrow morning. Thank you!
    Tomascco,
    How did this work out in your burr grinder?
    Coffee and spices in the same grinder?
    Gives new meaning to "Coffee Thyme" :-)
    Love your play on words here with "Coffee Thyme" :-)
    This is a much better way of cleaning out my bean grinder than simply using a paper towel ... MUCH better! Thanks tremendously :-D
    There's a trick to using bread to clean the grinder. I use slices that I've let sit out for 2 days and get good and dry. They won't get gummy and you'll have bread crumbs for use later.
    I use my coffee grinder strictly for grinding herbs and spices. If I know I'm going to need bread crumbs, or I'm just getting low, I'll leave 8 slices of bread out. My grinder tends to stay fairly clean.
    I keep a 1 inch basting brush with the grinder and measuring scoop. Every single time I grind coffee I turn the grinder over to get the coffee into the lid, use the brush to clean out the grind chamber into the lid, empty the lid into the coffee maker, and brush the lid out. Takes about 10 extra seconds, but it looks like new and I never need to do a deep cleaning like this.
    I use an artist's brush on mine. One with 1/2 inch wide tip. It gets into the spaces beneath the blade.
    Yeah, that would work well too.
    I just used one that I had handy and knew was food safe since it's for basting and never been put in paint, unlike my other brushes.
    It's served me well.
    Nice! I've been doing the exact same thing for years, except I use my old shaving brush after I switched to electric shavers :-)
    Looks like you're using the same grinder as me in the instructable, so one question:
    When I bought the grinder, many Amazon reviews noted that grinding rice generated tiny pits in the plastic lid over time, making it cloudy, and so recommended "softer" starches like bread or paper towel; have you seen any cloudiness develop?
