how to make a strong genorator
 by agedesign
Featured
this project came to me after i had noticed that there is not many differences between a ac motor coil and a dc motor coil. well the only difference was the size. so i got started!
the tool list that i used is quite extensive and some exeptions could be made the tools i used will be listed below
drill press
lathe
philips screw driver
welder
a black and white marking pen
hobby knife
table saw
square
hack saw
silicone
supplies
plastic block (size will vary to the size of your motor coil)
AC motor coil
magnets
brushes and springs (be sure that they are from the same motor coil)
key stalk
sheet metal
small pieces of tin
washers
bolts
screws
Step 1: Step one (frame)
first you wnat to organize what you want to do first the frame or the motor. i started with my frame. i would show you step by step the drilling and welding but i had to make it first to make sure it works
the first thing that i did was took the key stalk and cut they in two lengths and put the two smaller pieces parallel and the longer pieces on top so they are on the edges of the smaller pieces. double check to make sure that it is square then weld it together. then take the sheet metal and weld it to the bottom of the long key stalk. then with a piece of sheet metal that is the same width as your plastic block. center your plastic block on the piece of metal you cut and mark the metal with the white marker were the plastic ends on each side then drill a small hole in each corner inside were you marked for your screws. keep the holes as close to the corner as possible  to avoid having a screw go in to were you will have to drill on the block. then square up the plate on top of the long key stalk closer to the middle and weld it down
HoldOnTight says: Aug 21, 2012. 10:18 AM
Thanks for putting your ideas into a prototype. I think I have some old but big rotors from dead AC motors lying around and it would be cool to build a generator or motor from scrap parts. DC motors and generators are SOOOO expensive compared to their AC counterparts. Your idea has value! Thanks for sharing. You got my vote!
agedesign (author) says: Aug 18, 2012. 2:18 PM
i did do testing on this genorator it was produsing 3v at low speed thats hand cranking it and 12v at top speed spinnig it with a drill
i still havent seen its top speed as a motor yet but its like a bushinged motor . not ment for long use but if you put bearing holders in it and bearings it might last a long time and be useful
fastrat2000 says: Aug 17, 2012. 6:37 PM
Nice I like that all the parts are common ez to get, and fairly ez to set up, I sure it works but wonder how well. Some testing would nice. But one thing I don't see is cooling this type motor have a lot cooling, some mods you may like to play with is clocking the brushes around some should change where it make its power at.
I know some don't like the brushes or that its DC. At this scale DC is grate if your powering some needs DC, there loses in AC to DC conversion too. More testing I think is need see if make power that could useful even if not up to par with some AC gens if cost less and ez to make it still may have a place, or maybe just some thing fun play with.
Now what you done is take U type motor and use it core to make a DC motor, or DC gen if you like, U type motor don't have the back EMF, why they are used for high speeds, so your core likely rated 10-20K rpm that maybe good, but does this make good DC gen core, it can turn high RPM, but what it make power wise and at what type speed and load, I think a lot more testing need done to say
Thanks for the build 1/2 want to build one just try it I could a flop but could gold too, Tesla didn't get his at the time.
Rat
databoy says: Aug 16, 2012. 9:15 PM
This project should be entered for the Darwin Award. Someone with no electrical knowledge will attempt the build and electrocute themselves. It is called back EMF.
AC was invented by Nicola Tesla to overcome the inefficiencies of DC generation. Sliprings are far more reliable than any DC commutator design. You will never match the power to weight to efficiency and cost using a DC commutator over an AC slipring design. Also the placing of the brushes on a commutator is very critical otherwise you will experience severe arcing.
If you want to build a very efficient generator/alternator use a car or very heavy duty truck alternator. They all generate three phase AC which is rectified to DC.
manuka says: Aug 16, 2012. 3:49 PM
Agreed! Slip rings, which ride on smooth surfaces, don't hence have to experience the rasping wearing action of brush to segmented commutator. They can be extremely durable, & car alternators usually outlive the vehicle!
Automotive alternator slip rings however only carry modest currents (~a few Amps to energize the rotating armature), with the 30A range output taken from the fixed surrounding coils. This is low voltage 3 phase AC, which 6 diodes built into the alternator rectify  to DC for battery charging.
Go to a auto scrap yard, grab an alternator & pull it apart - it's very educational!
dawp says: Aug 16, 2012. 9:38 AM
Most universal appliance motors, electric drills, saws, hedge cutters, roto-tools, mixers and blenders and vacuum cleaners are of the brush-commutator design. So are the motors used in trolleys and diesel engines. They use this I guess because this type of motor is capable of light load high speed and low-speed torque. I don't understand the purpose of this project?.
seljer says: Aug 16, 2012. 6:48 AM
If it was a universal motor you could probably also have rewired it to be a self excited generator. Or just applied a DC current to the stator coil to generate the magnetic field and used it as a DC generator.
scraptopower says: Aug 15, 2012. 7:59 AM
Whilst to the conversion from AC to DC wasn't needed, the motor will now make a reasonable little generator! Try spinning it and see how much power you get out. It will probably work at quite low speeds.
Thanks for posting,
fozzy13 says: Aug 14, 2012. 9:23 PM
This is a cool project! And something I've considered doing before.
However, as others have pointed out, your terminology is wrong.  Judging from the stator you have pictured, it seems that you took it from universal motor, meaning it will run without modification on AC or DC. A pure AC motor looks far different than a universal or DC motor, and is also called an induction motor.
Cool idea nonetheless : )
rimar2000 says: Aug 13, 2012. 7:00 PM
I have read that a motor with brushes works indifferently on AC or DC.
I never did the try, because all AC motor I seen are 220 V, and all DC motors are 12 V or less. And all my power sources are 220 AC or 12V or less DC.
pfred2 in reply to rimar2000Aug 14, 2012. 8:01 PM
Put enough batteries together in series and you'll have the voltage. Although today the more practical solution is to use a phase inverter.
agedesign (author) in reply to rimar2000Aug 13, 2012. 9:46 PM
well i haven't done any reading on this project or heard of it running indifferently but i have done repairs on ac and dc motors.
the dc motors use a fixed magnetic field with magnets while ac motors use the alternating to have a electrical endused magnetic field using magnetic wire
so thats why i think that there is a difference between the two types of source with the type of motor
temper in reply to agedesignAug 13, 2012. 10:00 PM
Actually all motors are really AC motors - that's why there is a commutator (the thing the brushes slide across) - this turns the DC into AC through the coils (brushless DC motors do the same thing electronically).
What you have there is a universal motor - i.e. one that will run on both AC and DC. You have just turned it from a motor with an electromagnetic stator to one with a permanent magnet stator.
Actually, if you could replace the commutator with slip rings and powered it from AC you would have a synchronous motor - something really useful.
omnistructable in reply to temperAug 15, 2012. 12:47 AM
You are right, all motors but an inductive motor will run on AC or DC. Look at the sign on the information tag, it must show AC / DC
agedesign (author) in reply to temperAug 14, 2012. 3:02 PM
thanks for the information but i haven't heard of slip rings
temper in reply to agedesignAug 15, 2012. 5:37 AM
Oh slip rings are just two conductive rings around the motor shaft that the brushes rub against - they are wired to the rotor windings and pass the ac current through directly (i.e. as ac) rather than periodically switching the polarity around as a commutator does.
pfred2 in reply to agedesignAug 14, 2012. 7:58 PM
You haven't heard of slip rings because they basically suck so they're not used much. As others have pointed out the motor you started with is called a universal motor. It would have run on DC just fine without any modifications at all. The only common motors that are strictly AC are induction motors. They run because of current phase change.
Gordyh in reply to pfred2Aug 16, 2012. 6:50 AM
Slip rings are not that bad. Every time you drive your car or truck, ect you are using them. They are built in to the alternator, and I have seen them last for 280K miles and more.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
