the tool list that i used is quite extensive and some exeptions could be made the tools i used will be listed below
drill press
lathe
philips screw driver
welder
a black and white marking pen
hobby knife
table saw
square
hack saw
silicone
supplies
plastic block (size will vary to the size of your motor coil)
AC motor coil
magnets
brushes and springs (be sure that they are from the same motor coil)
key stalk
sheet metal
small pieces of tin
washers
bolts
screws
Remove these ads by
Signing UpStep 1: Step one (frame)
the first thing that i did was took the key stalk and cut they in two lengths and put the two smaller pieces parallel and the longer pieces on top so they are on the edges of the smaller pieces. double check to make sure that it is square then weld it together. then take the sheet metal and weld it to the bottom of the long key stalk. then with a piece of sheet metal that is the same width as your plastic block. center your plastic block on the piece of metal you cut and mark the metal with the white marker were the plastic ends on each side then drill a small hole in each corner inside were you marked for your screws. keep the holes as close to the corner as possible to avoid having a screw go in to were you will have to drill on the block. then square up the plate on top of the long key stalk closer to the middle and weld it down
Visit Our Store »
Go Pro Today »
i still havent seen its top speed as a motor yet but its like a bushinged motor . not ment for long use but if you put bearing holders in it and bearings it might last a long time and be useful
I know some don't like the brushes or that its DC. At this scale DC is grate if your powering some needs DC, there loses in AC to DC conversion too. More testing I think is need see if make power that could useful even if not up to par with some AC gens if cost less and ez to make it still may have a place, or maybe just some thing fun play with.
Now what you done is take U type motor and use it core to make a DC motor, or DC gen if you like, U type motor don't have the back EMF, why they are used for high speeds, so your core likely rated 10-20K rpm that maybe good, but does this make good DC gen core, it can turn high RPM, but what it make power wise and at what type speed and load, I think a lot more testing need done to say
Thanks for the build 1/2 want to build one just try it I could a flop but could gold too, Tesla didn't get his at the time.
Rat
AC was invented by Nicola Tesla to overcome the inefficiencies of DC generation. Sliprings are far more reliable than any DC commutator design. You will never match the power to weight to efficiency and cost using a DC commutator over an AC slipring design. Also the placing of the brushes on a commutator is very critical otherwise you will experience severe arcing.
If you want to build a very efficient generator/alternator use a car or very heavy duty truck alternator. They all generate three phase AC which is rectified to DC.
Automotive alternator slip rings however only carry modest currents (~a few Amps to energize the rotating armature), with the 30A range output taken from the fixed surrounding coils. This is low voltage 3 phase AC, which 6 diodes built into the alternator rectify to DC for battery charging.
Go to a auto scrap yard, grab an alternator & pull it apart - it's very educational!
Thanks for posting,
However, as others have pointed out, your terminology is wrong. Judging from the stator you have pictured, it seems that you took it from universal motor, meaning it will run without modification on AC or DC. A pure AC motor looks far different than a universal or DC motor, and is also called an induction motor.
Cool idea nonetheless : )
I never did the try, because all AC motor I seen are 220 V, and all DC motors are 12 V or less. And all my power sources are 220 AC or 12V or less DC.
the dc motors use a fixed magnetic field with magnets while ac motors use the alternating to have a electrical endused magnetic field using magnetic wire
so thats why i think that there is a difference between the two types of source with the type of motor
What you have there is a universal motor - i.e. one that will run on both AC and DC. You have just turned it from a motor with an electromagnetic stator to one with a permanent magnet stator.
Actually, if you could replace the commutator with slip rings and powered it from AC you would have a synchronous motor - something really useful.
