How to Create Calculator in Batch
8,673
Posted
Introduction: How to Create Calculator in Batch
Before creating a calculator lets go through a simple code tutorial..
1>(echo) code "echo" are used to write a text for e.g " echo Welcome to Instructables".
2>(color 30)code "color" are used to give color to background and font.
3>(set /p =)code "set /p" is used to create console in program.
4>(title)code "title" is used to give title to program
5>(start)code "start" is used to start an external program.
6>(pause)code "pause" is used to pause a program to avoid, crash.
7>(%username%)code "%username%" just adds the name of the profile name of respective OS.
"WIP" (Work-in-progress).
@echo off
title calculator
color 0A
:main
echo.
echo ---------------------------
echo.
echo WELCOME %USERNAME% to
echo.
echo Cal'C Ver 0.2
echo.
echo.
echo /////////////////////////////////////
echo Your previous Calulated number was %sum%
echo.
echo Enter the specified alphabet to continue..
echo.
echo a)Addition
echo.
echo b)Subtraction
echo.
echo c)Divison
echo.
echo d)Multipication
echo.
echo e)Square, Cube or any power (by Prof.Pickle)
echo.
set /p do=Value.
if %do%== a goto add
if %do%== A goto add
if %do%== b goto sub
if %do%== B goto sub
if %do%== c goto div
if %do%== C goto div
if %do%== d goto mul
if %do%== D goto mul
if %do%== e goto power1
if %do%== E goto power1
echo.
cls
echo Invalid value = %do%
echo.
pause
cls
goto main
:add
cls
echo ADDITON
echo.
set /p no1="num1. "
echo       +
set /p no2="num2. "
set /a sum=no1+no2
echo ------------
echo %sum%
echo.
pause
cls
goto main
:sub
cls
echo SUBTACTION
echo.
set /p no1="num1. "
echo       -
set /p no2="num2. "
set /a sum=no1-no2
echo ------------
echo %sum%
echo.
pause
cls
goto main
:div
cls
echo DIVISON
echo.
set /p no1="num1. "
echo       /
set /p no2="num2. "
set /a sum=no1/no2
echo ------------
echo %sum%
echo.
pause
cls
goto main
:mul
cls
echo MULTIPLICATION
echo.
set /p no1="num1. "
echo       *
set /p no2="num2. "
set /a sum=no1*no2
echo ------------
echo %sum%
echo.
pause
cls
goto main
:power1
cls
echo Square, Cube or any power (by Prof.Pickle)
echo.
echo Select the number
set /p num=
cls
echo Select the power
set /p pow=
set /a pow=%pow%+1
set ans=%num%
cls
:power2
set /a pow=%pow%-1
if %pow% LSS 1 goto next
set /a ans=%ans%*%num%
goto power2
:next
echo Your answer is %ans%
echo.
echo To open Prof.Pickle's instrutable's profile type 'I'. Type 'M' to goto main
set /p open=
if %open%== I start https://www.instructables.com/member/Prof.+Pickle/
if %open%== i start https://www.instructables.com/member/Prof.+Pickle/
if %open%== m goto main
if %open%== M goto main
goto main
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
30 Comments
Gud work..! Try adding more mathematical functionality like square, cube, average, percentage, etc.. Nice job for a 14 year old.. Keep it up..!
Thanks, I will try for adding more mathematical functionality.
i made calculator for calculating resistor resistance. and i cant make it to calculate this: 6,6/0,02 and the output is 0...
my code:
@echo off
cls
set /a bv=0
set /a lv=0
set /a la=0
set /a res=0
set /a pres=0
title Kalkulator za upor
:a
cls
echo Vnesite napetost vira (V):
set /p bv=
echo Vnesite napetost za LED (V):
set /p lv=
echo Vnesite tok za LED (A):
set /p la=
goto calc
:calc
set /a pres=bv-lv
set /a res=pres/la
goto d
:d
cls
echo POTREBEN UPOR: %res%
pause >nul
goto a
and when i put in 10 2 2 is output 4 which is correct. but when i put in 9 2,4 0,02 is output 0 instead of 330...pls help
i mean when i put in 10 for bv and 2 for lv and 2 for la.....and same with 9 2,4 0,02..
Really nice work But I thinks its a lot of code for not much you could gave shorten it . I did one too (I'm a newbee to batch programming) what do yo think of It ? :
@echo off
mode con: cols=20 lines=10
Title Calculator
:A
echo Enter your operation
set /p cal=
set /a answer=%cal%
echo *** %answer% ***
GOTO A
wow!..thnx man..this was exactly what i was looking for!
also thanks instructables for making it possible to post this calculator and the creators of the calculator for posting it and helping me, a 14 year old, learn how to work their way around batch.
Here is a program used to generate Rubik's cube scrambles in batch. Long but does its job.
:Prompt
ECHO OFF
SET /a s=0
SET /a f=1
SET /a n=0
COLOR 1A
ECHO Pick a scramble of between 1 and 20 moves.
SET /p s="Number of moves of scramble:"
IF 20 LSS %s% (
ECHO Pick a smaller scramble
GOTO Prompt
IF %s% LSS 2 (
ECHO Pick a bigger scramble
GOTO Prompt
SET /a w=(%RANDOM%*40/32767)+1
GOTO loop
:loop
SET /a m=(%RANDOM%*18/32767)+1
SET /a n=n+1
IF %n% LSS %m% GOTO loop ELSE GOTO sub
:Sub
SET /a a=(%RANDOM%*18/32767)+1
IF "%a%" EQU "1" SET c=R
IF "%a%" EQU "2" SET c=U
IF "%a%" EQU "3" SET c=D
IF "%a%" EQU "4" SET c=F
IF "%a%" EQU "5" SET c=B
IF "%a%" EQU "6" SET c=L
IF "%a%" EQU "7" SET c=R'
IF "%a%" EQU "8" SET c=U'
IF "%a%" EQU "9" SET c=D'
IF "%a%" EQU "10" SET c=F'
IF "%a%" EQU "11" SET c=B'
IF "%a%" EQU "12" SET c=L'
IF "%a%" EQU "13" SET c=R2
IF "%a%" EQU "14" SET c=U2
IF "%a%" EQU "15" SET c=D2
IF "%a%" EQU "16" SET c=F2
IF "%a%" EQU "17" SET c=B2
IF "%a%" EQU "18" SET c=L2
SET /a y=a
SET /a z=a
SET "str=%C%"
ECHO %C%
GOTO Main
:Main
SET /a x=a
IF "%a%" EQU "1" (
SET b=R
GOTO Rs
IF "%a%" EQU "2" (
SET b=U
GOTO Us
IF "%a%" EQU "3" (
SET b=D
GOTO Us
IF "%a%" EQU "4" (
SET b=F
GOTO Fs
IF "%a%" EQU "5" (
SET b=B
GOTO Fs
IF "%a%" EQU "6" (
SET b=L
GOTO RS
IF "%a%" EQU "7" (
SET b=R'
GOTO Rs
IF "%a%" EQU "8" (
SET b=U'
GOTO Us
IF "%a%" EQU "9" (
SET b=D'
GOTO Us
IF "%a%" EQU "10" (
SET b=F'
GOTO Fs
IF "%a%" EQU "11" (
SET b=B'
GOTO Fs
IF "%a%" EQU "12" (
SET b=L'
GOTO RS
IF "%a%" EQU "13" (
SET b=R2
GOTO Rs
IF "%a%" EQU "14" (
SET b=U2
GOTO Us
IF "%a%" EQU "15" (
SET b=D2
GOTO Us
IF "%a%" EQU "16" (
SET b=F2
GOTO Fs
IF "%a%" EQU "17" (
SET b=B2
GOTO Fs
IF "%a%" EQU "18" (
SET b=L2
GOTO RS
:Rs
IF "%y%" EQU "1" GOTO Main
IF "%y%" EQU "7" GOTO Main
IF "%y%" EQU "13" GOTO Main
IF "%y%" EQU "6" GOTO Main
IF "%y%" EQU "12" GOTO Main
IF "%y%" EQU "18" GOTO Main
IF "%z%" EQU "1" GOTO Main
IF "%z%" EQU "7" GOTO Main
IF "%z%" EQU "13" GOTO Main
IF "%z%" EQU "6" GOTO Main
IF "%z%" EQU "12" GOTO Main
IF "%z%" EQU "18" GOTO Main
GOTO End
:Us
IF "%y%" EQU "2" GOTO Main
IF "%y%" EQU "8" GOTO Main
IF "%y%" EQU "14" GOTO Main
IF "%y%" EQU "3" GOTO Main
IF "%y%" EQU "9" GOTO Main
IF "%y%" EQU "15" GOTO Main
IF "%z%" EQU "2" GOTO Main
IF "%z%" EQU "8" GOTO Main
IF "%z%" EQU "14" GOTO Main
IF "%z%" EQU "3" GOTO Main
IF "%z%" EQU "9" GOTO Main
IF "%z%" EQU "15" GOTO Main
GOTO End
:Fs
IF "%y%" EQU "4" GOTO Main
IF "%y%" EQU "5" GOTO Main
IF "%y%" EQU "10" GOTO Main
IF "%y%" EQU "11" GOTO Main
IF "%y%" EQU "16" GOTO Main
IF "%y%" EQU "17" GOTO Main
IF "%z%" EQU "4" GOTO Main
IF "%z%" EQU "5" GOTO Main
IF "%z%" EQU "10" GOTO Main
IF "%z%" EQU "11" GOTO Main
IF "%z%" EQU "16" GOTO Main
IF "%z%" EQU "17" GOTO Main
GOTO End
:End
SET /a f=f+1
SET /a z=y
SET /a y=x
SET "Str=%STR% %b%"
ECHO %b%
IF %f% LSS %s% GOTO Main
ECHO Press any key to see scramble
PAUSE
ECHO %STR%
GOTO End2
:End2
ECHO Enter a number
ECHO.
ECHO 1) Regenerate scramble
ECHO.
ECHO 2) Stop generator
SET /p n=" "
IF "%n%" EQU "1" GOTO Prompt
IF "%n%" NEQ "2" GOTO End2
why not just do this:
@echo off
:a
cls
set /p num=Your question:
set /a num=%num%
echo Final nummber=%num%
pause
goto a
