How to Cut Off the Outer Shell of a Golf Ball
7,101
14
10
Published
Introduction: How to Cut Off the Outer Shell of a Golf Ball
About: trying to think of an awesome tutorial.
What you will need:
A saw
A Flathead screwdriver
A sharpie marker
And a golf ball
Step 1: Marking a Line
First you want to take your sharpie marker and draw a straight line around the circumference of the ball.
Then take your saw and cut along the line until you can see a different color inside the cut, do this all the way around the ball.
Step 2: Prying Off the Shell
Now take your Flathead screwdriver and wedge it under one side of the shell by twisting it back and forth.
(BE CAREFUL IF THE SCREWDRIVER SLIPS OFF THE BALL AND HITS YOUR HAND IT HURTS!)
Once you get the screwdriver under one part of the shell shift the screwdriver a bit to the left and continue prying. Do this until the shell pops off.
Step 3: Still Prying Off the Shell
Now wedge the screwdriver under the other half off the shell and pry it off just like the first half.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    10 Comments
    Well, certainly a nice 'ible - good writing and great pictures, but allow me the question: Why?
    If you have a homemade air cannon (potato gun) with a 1.5-inch barrel and have an adventurous imagination when it comes to ammo sources, then you probably already realize that the 5 cm golf ball is just a little too large. But, if you peel off the outer layer to reveal the inner core, you will find that it is almost a perfect match for your barrel. They are very fast; the most impressive thing (projectile) that I have ever shot from my air cannon. Be careful and good luck finding them after they have been shot.
    golf ball with chipped or cracked shell.
    subtract shell.
    Superball!
    I wonder if they bounce well
    I have tried bouncing them and they do bounce but they are still VERY hard balls.
    Glue it back together, add high gloss white paint, dirty it, swap it out with someones ball, thwack, my ball broke!!!
    glue them together and use them as ping-pong balls!! :)
    I actually thought of one.
    Fill with magic stuff, glue together with WEAK glue.
    Now, GO NINJA SMOKE BOMBS!
