How to Diffuse an LED
Introduction: How to Diffuse an LED
If you just got a bunch of cool LED's and you want to diffuse them (for various reasons) this is the instructable for you! Lots of LED's only come in those "waterclear" lens, not diffused. Diffusing makes the LED appear dimmer, but gives a wider viewing angle of the light. I recently bought color changing LEDs that only came in a non-diffused lens, that's when I made this instructable.
Step 1: Supplies
The LED (duh)
fine sandpaper (I used 400 grit and ist worked great, but i haven't tested other sandpapers)
about 5 minutes of your life per LED
Step 2: Grasp the LED
grab the LED by the beginning of the terminals and base of the LED
Step 3: Rub It on the Sand Paper
pretty self explanatory, keep on sanding everything until everything looks opaque or covered in a white dust.
Step 4: Rinse It
rinse the LED under water for a couple of seconds and dry with a towel.
Step 5: You're Done!
see the difference!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    THE BEST way is to spray the LEDs with a light coat of Matt/Flat ( not glossy) white spray paint.TIME EFFECTIVE. Sanding each and every led is a tough and time-consuming job. The Leads could also get damaged due to mishandling While sanding.BEST thing to do is to line up all the LEDs and cover up the leads with something and spray a light coat of White paint
    wow, so simple yet so effective! Thank you so much, exactly what I was looking for.
    Sand some RGBs :) The results are amazing.
    I do this to most of mine! My way is faster though, I just squeeze the leads together on each LED and make a big pile of them! Then I stick them in my power drill 1 at a time! I use a fine grit sanding sponge and if u get it really wet you don't even have to clean them off!
    Amazing! This totally worked like a charm.
    How does this affect the lumen output?
    Awesome, yet as simple as it gets!! I've been racking my brain for the last 2 days and this was in front of me all the time!!
    I would suggest that if you have a large LED display, instead of sanding each LED why not put a couple of pieces of brightness enhancement (prism) film from a dead LCD monitor? Those are the thin white plastic sheets in front of the thick glass/plastic plate. It diffuses the light very nicely, plus it hides the LED's from being seen when the device is not on. If you have no clue what I am talking about, go to youtube and check out the engineer guy's video on lcd monitors.
    This worked pretty well for me. I have a whole bunch of slow fade RGB LEDs that I needed to diffuse for the Eternal Flame project on makeprojects, and I just went at my LED with a fine grit sanding sponge. Turned out great
    Great Ible thanks I'm making a few led light bars in parrellel for my very first led project and needed a way to diffuse.. I didn't know 400 grit would work though.. So thanks! I thought I needed like 1000 grit paper but nevermind! PS if anyone wants to know how to make the led bar I will be posting an Ible on it after my first one is a success.. But anyway thanks a lot! :)
